Old 01-24-2021, 08:03 PM #1
david05111 david05111 is offline
david05111 will become famous soon enough
Is there a way to calibrate the speedometer on our Gen 5s?
I was out in my 2020 today and noticed that my speedometer seems to be off, based on what my GPS is saying.
My car will read 70 MPH, but the actual speed is like 67-68 according to GPS.
It's a TRD Pro, so I thought initially that it might have been because of the different wheels and tires, but it it would read the opposite if that were the case.
It sounds inconsequential, but at that rate if the car has actually done 100k miles, the car will read almost 104,500. That's almost 4500 miles, and not insignificant.
Can Toyota handle this?
david05111 is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 08:10 PM #2
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
We used to take two Siennas on a 700 mile trip regularly.
One would have 60 miles less over the course of a one way trip, 120 round trip.
OEM wheels and tires on both.
One '03. One '04.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 08:21 PM #3
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
The regular answer is no you can't calibrate it.
The more complex answer is anything is possible, but you're not going to want to do it (there are several previous conversations on this forum about it).
FYSA, TRD Pro comes with the same size (265/70R17s) that all other 4Runners come with (except the 20" limiteds).
Upgrade your tire size to 285/70R17s and your speedo will match.
I'm not sure that the speedo and total (not trip) odo are tied together at the same ~4.5% mismatch.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 08:29 PM #4
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
I use an iOS app called Spyglass to check my speed correlation in all my vehicle so I know if it’s reading high or low, typically calibrate at 70 mph as measured by Spyglass to know if my speedo is reading high or low.
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 09:15 PM #5
Thanks. That’s mind-boggling that it can’t be calibrated, but it is what it is.
Old 01-25-2021, 05:38 AM #6
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Your speedometer is calibrated, just not to the P265/70R17 (31.7" diameter) factory tires. Get some 33" tires and it'll be right as rain. I'm running LT255/80R17 Toyos and it's dead on with gps, as well as those radar controlled speed signs which I've specified on a few projects for the state DOT and verified they are accurate.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:20 AM #7
Jeremy556's Avatar
Jeremy556's Avatar
It used to be easier when the speedo was based on the output of a single sensor from the transfer case. In the 5th gen, it is generated by the 4 ABS sensors, so you would need to modify the signal with 4 devices.
Old 01-25-2021, 01:22 PM #8
2Biglabs 2Biglabs is offline
2Biglabs is on a distinguished road
Im surprised no one has made either a FTC or NTSHA complaint about this.
Due to the speedometer being different it would affect your warranty. I realize that its usually in the consumers favor, but what if its not?
I also wonder if it affects the vehicle stability system or the abs negatively. Im sure there is some Toyota tech or other manufacturer tech that could tell us if it does. IIRC when i had a GM product it was in the owners manual that aftermarket wheels could mess up the system.
The error, while annoying, is something I can deal with. Getting hurt cause the sensor (abs,vds) is off is not.
2Biglabs is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 03:25 PM #9
Jeremy556's Avatar
Jeremy556's Avatar
It is within an acceptable margin of error.
The ABS and stability control systems are concerned with wheel speeds relative to each other, hence don't care about wheel diameter/exact overall speed
Old 01-25-2021, 06:26 PM #10
Thank you!
Old 01-25-2021, 07:46 PM #11
Whippersnapper02's Avatar
Since my 2nd gen Tacoma days, the speedo has always been off but the odometer is correct on stock tires. Just drive.
Old 01-26-2021, 12:05 AM #12
pcstockton pcstockton is offline
pcstockton is on a distinguished road
Get a ScanGauge and set its speedo with a GPS speed like GAIA or something. Done.
I do that. I need +6% to match my 295/70/17s. You will also get correct MPG.
Bonus! You get less miles on your rig if you dont correct it.
pcstockton is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 12:25 PM #13
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
the speedohealer might work? all the information is fed to the speedometer by one wire at the speedometer? Some information like mpg etc might still be off, but the display can possibly be corrected. I have too much stuff i'm working on and haven't had time to try to splice the speedohealer in yet.
I'm running 285/75r17 on 4.88 gears, definitely have a speedometer reading too low at higher speeds.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:57 PM #14
Except it's the opposite on mine. When I drive, the car think's I'm driving more miles than I actually am at the moment.
For instance, the car reads about 8000 miles right now. Based on the error, the car has actually traveled between 7650 and 7700 miles. That impacts on my warranty and resale at the very least.
Of course I wouldn't object it it was in my favor, but it's not. The only solution seems to be go up in tire size, which seems kind of funny. We as off-roaders wouldn't object to that too much, but still
Old 01-26-2021, 03:04 PM #15
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I believe the speedometer is intentionally less than actual and the odometer is dead accurate. Have you tested the odometer against the GPS?
My GPS says 70mph when my Speedo says 69mph on 265/70/17s. Speed has always been a MPH under on my 4runners. I tested the ODO many years back on a 3rd gen. While the speed was off, the ODO was accurate.
Its all computers now. The speed and ODO are no longer linked in a linear fashion.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
car , gps , miles , read , speedometer
DIY Video: Stop, Calibrate and Listen -OR- How to fix your spastic 3rd Gen fuel gauge the walrus 3rd gen T4Rs 32 01-13-2023 01:41 PM
Unable to Zero Point Calibrate jaywonger 3rd gen T4Rs 1 08-05-2020 08:15 PM
5th Gen Calibrate NAV for heading always up TRUSTYAXE 5th gen T4Rs 9 07-27-2017 07:01 PM
9.1 mpg and a bad speedometer :( smallstar Classic T4Rs 8 11-07-2014 12:47 PM
HELP...Unable to Circle Calibrate Compass HI808SR5 5th gen T4Rs 8 01-10-2012 11:42 PM
