Old 02-11-2021, 12:41 PM #16
chubbena chubbena is offline
chubbena is on a distinguished road
Originally Posted by pDubs View Post
It's just a different model skid plate. You are over thinking it. Just look at it, and see where the reinforced area that makes contact with the crossmember is. Put a floor jack there to lift the entire front of vehicle.
My OEM skids looked like electroboys, the other guy has a TRD skid plate, which maybe that is why it looks lightly different. Either way it's the same principal.
The photos in Grizzlypath's post #15 shown the two different positions with stock skid. i have more confidence putting floor jack under the protruding circle nearer to the front than the rectangular recess further to the back. Have you put the jack to the latter with no problem?
I'd also like to see what Grizzlypath has to say. Thanks guys.
chubbena is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 01:11 PM #17
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Okay, looking at post #15, the circle near the front (circled in red) is your oil pan (this one has a Fumoto drain valve threaded in instead of a normal oil drain bolt). Obviously, don't jack the vehicle up from here. haha
This photo above, with the circle is where you should be putting a floor jack.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 01:17 PM #18
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
very informative
daprotege5 is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 12:34 PM #19
Per 2018 Toyota manual we are to jack where the orange circle is which is a recess behind the drain pan in post #15. Apparently quite a few have used this as jack point with no problem but I'm hesitant as I haven't got around to remove that part of the skid and see what is above it. The circle is what I would use but could not if I were to change oil filter or any other work above the front skid.
I so missed my 15 year old Jeep which I could jack anywhere along the axles and the frame and sometimes worked on stuff without jacking it up.
Old 02-12-2021, 02:55 PM #20
LakeRunr's Avatar
LakeRunr LakeRunr is offline
LakeRunr has a spectacular aura about LakeRunr has a spectacular aura about
LakeRunr's Avatar
The orange circle in GrizzlyPath's post #7 is in the wrong spot. It does NOT match the diagram in the owners manual (also shown in post #7). Do not lift from here.
In the diagram, the lift point is clearly forward of the double-tear-drop cover for the oil drain plug. GrizzlyPath's orange circle is clearly rearward of that same cover.
The red circle from ElectroBoy's post is the correct spot.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
LakeRunr is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 04:06 PM #21
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
These central jacking points, front and back, are intended to lift the vehicle to put it on jack stands. Then remove the jack. I hope nobody intends to get under the truck while it’s balanced only on one central point.
For changing the oil and filter I just drive the front wheels up on some low ramps to get a few more inches of room to move around more easily.
Old 02-12-2021, 04:25 PM #22
You are absolutely right.
No, I have never worked under a vehicle without jack stand since a bottle jack fell when I tried to change a tire on the road and almost lost my hand.
What was I thinking!?
Old 02-12-2021, 04:34 PM #23
Not sure where the diagram in post #7 is from but I guess it's for 4th gen. You may see the jack point is on the front skid forward of the front wheels.
The diagram in post #14 by ElectroBoy is same as my 2018 manual which you may see the jack point is on the second (engine) skid and behind the front wheels i.e. further to the back.
Regardless, I would use the jack point as the photos in post #8 actually used by ElectroBoy i.e. on the front skid and forward of the front wheels.
Old 02-12-2021, 04:47 PM #24
LakeRunr's Avatar
LakeRunr's Avatar
Grizzly said it was from the factory service manual.
Old 02-12-2021, 05:57 PM #25
Banned
Real Name: Mark
Banned
Real Name: Mark
Rotated and clipped service manual pic and skid plate pic. Looks like the same spot.
Jack Points-2e3d0699-2e5e-4131-b2a6-20795799d72f-jpeg  Jack Points-80e95697-0ab9-4fb1-8592-3af97036e201-jpeg
Old 02-16-2021, 01:10 PM #26
Kindly double check the two diagrams:
The one in your post #25 has the front lift point forward of front wheels.
The one in your post #14 has the front lift point further back from front wheels which is what I have in the manual.
Hope this clears up the confusion.
Old 02-17-2021, 04:58 PM #27
Banned
Real Name: Mark
Banned
Real Name: Mark
Here is a photo of the front jack point to lift both front wheels off the ground. On my 2018 ORP, stock skids. It is slightly in front of the front wheels center point.
Jack Points-93f540ea-de74-45a2-82f6-6192c0e0357a-jpeg
Old 02-17-2021, 06:07 PM #28
I guess the diagram in our manual, which has the lift point further back of the front wheels and what Grizzlypath has been using (see post #15), is wrong. i'm glad he didn't have much issue except a bit off balanced per his earlier post.
Old 04-18-2022, 03:15 PM #29
hrn423 hrn423 is offline
hrn423 is on a distinguished road
seemed like a relevant thread -- apologies if not. Just had to get som roadside assistance with a rear right flat, which was on an angle. Should I be worried that a floor jack was used on the piece in the red square attached? Didn't know any better myself, but looked at the manual just after and it looks as though it should have been next to that spot, but was not sure if that was moreso for the stock/oem jack. I just assumed this guy knew what he was doing. Hoping no damage is caused by this
Jack Points-jackpoint-jpg
hrn423 is offline   Reply With QuoteReply With Quote
5gen , jack , lift , points , put
Where are the jack points? Satter 3rd gen T4Rs 30 09-17-2020 10:24 PM
1990 4Runner Jack Points jay333 Classic T4Rs 3 03-11-2020 07:20 PM
Where are the best floor jack points on our 4Runner? sant6236 4th Gen T4Rs 24 03-17-2019 01:00 PM
new to DIY... jack points for front? amalik 3rd gen T4Rs 6 10-03-2013 10:26 AM
Proper jack points for garage jack? ciaz 5th gen T4Rs 3 02-01-2010 03:14 PM
