Old 01-24-2021, 08:14 PM #1
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Jack Points
Does anyone have an image of the underside of a 5gen 4Runner that circles or points out the points where you can put a jack under it to lift it up to change a tire or lift up to put on jack stands?
Or does anyone want to make one to be the coolest person on this forum?
umidkusername is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 08:23 PM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Where the heck are the jack points?? 2018 TRDORP w/ KDSS
2018 Limited Rear Jacking Point
Floor jack and jack stands
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 12:36 AM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The owners manual shows the jack points. If you don't have one, you can one on Ebay for reasonable price.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 03:46 AM #4
vt100 vt100 is offline
vt100 is on a distinguished road
C'mon, this is body on frame! Any point under the frame will be just fine
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
vt100 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 09:55 AM #5
I open the door and use that... that way i can jack the vehicle up while sitting on the seat
Old 01-26-2021, 12:07 PM #6
JeuTheIdit's Avatar
JeuTheIdit JeuTheIdit is offline
JeuTheIdit will become famous soon enough
JeuTheIdit's Avatar
Then if something goes wrong all you gotta do is replace the door!!
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
JeuTheIdit is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:53 PM #7
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
Alright, lots of super helpful comments already here, but let's see if I can shed some additional light on the front jack point. I know I've searched forums high and low and haven't found very good pics or detailed location information about the single jack point in the front of the vehicle (to lift both front wheels at the same time). Unfortunately I wasn't able to find an actual picture, but I did find this diagram from the Factory Service Manual.
Frame: obviously you can jack anywhere along here, but towards the front or rear wheel is the typical spot to lift from. This'll be where you can place jack stands as well.
Rear differential: this is an easy place to lift both wheels of the rear up at once. On either side of the rear differential you can place jack stands if needed. Usually my go-to when not doing axle work.
Front crossmember: this is shown in the FSM diagram as the forward centered circle. I pulled the below images from a YouTube oil change video. In pic 1 you can see the Fumoto valve circled in red which would normally just be an oil drain bolt. The orange circle shows the cross member with an indentation that would be the jack point. In pic 2 you can see that normally the oil drain bolt location is covered (red circle) - DO NOT JACK FROM HERE, it'll obviously crush.
So I've been jacking from that front crossmember location since I've had the vehicle. I have noticed that if my jack is perfectly centered on the crossmember that the front end does not lift evenly. Usually not a big deal I'll just jack higher. Alternatively I'll position the jack slightly to one side an inch or so and that's enough to offset whatever imbalance exists.
If anyone has any additional information or detail I'd love to hear it!
grizzlypath is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 07:39 PM #8
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
From the thread Bossman linked.
Rear:
https://www.toyota-4runner.org/3363099-post67.html
Front:
https://www.toyota-4runner.org/3364202-post75.html
To lift BOTH front wheels. There’s a reinforced circular area on the stock front skid that sits against the crossmember. The jack goes there. I happen to have my skids off so here’s some pics:
(To lift BOTH rear wheels center the jack on the rear diff pumpkin).
Jack Points-25ac197a-6593-4128-bd19-27f69e5a698c-jpeg  Jack Points-308d23d4-58d1-45ba-8ebb-bbeff9a7cd23-jpeg  Jack Points-4bf45641-f8e7-4cda-99ac-0043c1f28495-jpeg  Jack Points-e83a8842-0334-4239-9e0b-b4a96c02aa4c-jpeg
Old 01-26-2021, 09:10 PM #9
Y’all the best. With this knowledge I can get under mine and spray paint the points. I want to make this as simple as possible for me. Medium size orange dots to make it a no brainer. I don’t even want to question it or second guess when I need to change the tires. Just put jack under the orange dot. I find the stock jack sufficient. From the threads I’ve seen it’s good for changing a tire but not like maintenance work, which is fine.
My wife ripped two tires in her Jeep and it was Christmas Eve and raining and you want to talk about a mess? Anyone tried jacking up a Jeep Compass Elevation model? It’s a damn nightmare. The rain made it worse.
Old 01-27-2021, 03:29 AM #10
onaquest's Avatar
onaquest onaquest is offline
onaquest is on a distinguished road
onaquest's Avatar
I've looked this up a few times myself. The jack point images in my 2018 owners manual are overly simplified, to the point of being unclear enough to want to search here.
Anyway, this thread captures all of the most useful posts and even some more detailed images of the front cross member jacking location.
Thank you @Bossman , @ElectroBoy , @grizzlypath
How can we sticky this thread?
onaquest is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 04:24 PM #11
chubbena chubbena is offline
chubbena is on a distinguished road
Rear:
Front:
This makes sense to me but is a different spot from both Grizzlypath's (the post before you) and the owner's manual's which is further to the back from oil drain cover and is an indent so what gives?
chubbena is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 06:36 PM #12
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
It's just a different model skid plate. You are over thinking it. Just look at it, and see where the reinforced area that makes contact with the crossmember is. Put a floor jack there to lift the entire front of vehicle.
My OEM skids looked like electroboys, the other guy has a TRD skid plate, which maybe that is why it looks lightly different. Either way it's the same principal.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 06:40 PM #13
pDubs's Avatar
pDubs's Avatar
DO NOT use the emergency bottle jack to lift the entire front or rear end of the vehicle. If you are using the bottle jack (which you shouldn't) to do work, just lift it off the frame, litterally anywhere, one wheel at a time.
You should really be using a floor jack and jack stands.
2014 SR5P
Old 01-28-2021, 04:16 PM #14
Banned
Real Name: Mark
Banned
Real Name: Mark
Over the years there have been various diagrams in the owners manual about jacking and lifting points.
In my 2018 manual Emergency section, the diagram shows where to jack to change a flat tire. One at a time, on the front frame and rear axle. See below.
There are other diagrams I’ve seen online that show where a mechanic would position the arms of a swingarm lift (frame and/or cross member). Or where to position a jack on a central point to lift either the front of back ends, then place jack stands (front frame and rear axle). See 2nd diagram below.
Jack Points-ae2dcdb2-5b31-4b2b-a5a7-d7ba78bc7a4a-jpeg  Jack Points-6c1a5710-ad75-46ae-8698-d26f15052713-jpeg
Old 01-28-2021, 06:49 PM #15
Awesome! I've seen that reinforced spot before, but wasn't sure if it was a legitimate jacking location or just skid weak spot reinforcement.
The spot I typically lift from is further back and I believe engages directly with the front crossmember. I'm going to have to get under there and investigate further...
5gen , jack , lift , points , put
Where are the jack points? Satter 3rd gen T4Rs 30 09-17-2020 10:24 PM
1990 4Runner Jack Points jay333 Classic T4Rs 3 03-11-2020 07:20 PM
Where are the best floor jack points on our 4Runner? sant6236 4th Gen T4Rs 24 03-17-2019 01:00 PM
new to DIY... jack points for front? amalik 3rd gen T4Rs 6 10-03-2013 10:26 AM
Proper jack points for garage jack? ciaz 5th gen T4Rs 3 02-01-2010 03:14 PM
