Old 01-26-2021, 05:56 PM #16
Michael-Dallas Michael-Dallas is offline
Michael-Dallas is on a distinguished road
I built a house with 8 foot garage doors - problem solved.
Michael-Dallas is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 07:50 PM #17
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
My 2018 ORP still fits with a 3"/2" lift, 285 Falkens, LFD 7/8 rack with 5" long bolts mounting my traction pads. I took my Plano case off before I did the lift and tires and I think I would fit with it on.
Oh, and I live in SoCal w/6'10" from floor to garage door clearance. I do come in at an angle which i believe helps. With that said, I will not park in a commercial parking garage. Those things are scary and I know I will hit, especially with items on the roof rack.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 03:57 PM #18
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
I bought a house to fit my toys. Inside the garage I have a 10' ceiling and about 5-7' of space in front or in rear to the walls depending on where the vehicle is pulled in to. However, I do slightly rub the door frame with my crawler when pulling in and out and the 4Runner has maybe 2" to spare on each side of the door frames. Plenty of room to work on the trucks even with everything inside. I use a heater during the winter when I'm in there. Will be insulating it at some point.
Garage Clearances-0-1-jpg
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
Old 04-25-2023, 09:09 AM #19
AlexaDuffy's Avatar
AlexaDuffy AlexaDuffy is offline
AlexaDuffy is on a distinguished road
AlexaDuffy's Avatar
I have a 2018 4Runner and I've had to deal with garage clearances before. I installed a lifted rack on top and it barely cleared the height of my garage door. It can be a hassle to constantly search for outdoor parking, especially if it's your main vehicle. What I ended up doing was removing the rack altogether, but I understand that might not be the best option for everyone. One thing that helped me was checking the clearance height of parking garages before entering them. I know it sounds like a hassle, but it's better than risking damage to your vehicle. Oh, and by the way, have you heard of Grease Monkey Direct? They have plenty of tools and products that can help with DIY car modifications. I've found some great deals on their website for things like lifts and racks. Maybe it could be a helpful resource for you too.
AlexaDuffy is offline   Reply With QuoteReply With Quote
Old 04-25-2023, 06:23 PM #20
dotrunner dotrunner is offline
dotrunner is on a distinguished road
Took off the pro roof rack
Had to remove the pro roof rack. Been desperately trying to get rid of it ever since.
dotrunner is offline   Reply With QuoteReply With Quote
Old 05-01-2023, 01:07 PM #21
Tcw1184 Tcw1184 is offline
Tcw1184 is on a distinguished road
Thankfully my pro rack just clears.
Tcw1184 is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 01:20 PM #22
Nick B Nick B is offline
Nick B is on a distinguished road
I was just going to start a thread with the same question as the OP until I saw this . Am looking at a 24 Pro and was wondering about the fit in my garage which has a 84” high opening.
My Raptor that I use to own fit so I kind of figured a Pro would fit but wasn’t 100% sure .
Nick B is offline   Reply With QuoteReply With Quote
Old 05-14-2024, 03:53 PM #23
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
3" icon lift on 35s, gobi rack with light bar on top - i can fit into my 7' garage and almost every parking structure/car wash ive come across so far...
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 05-14-2024, 04:22 PM #24
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
It depends on if the bottom of the door (when up) is the issue or the opening is the issue. My door hangs down a little below the opening and inch or two. Not a problem as I don't have a lift. But, the door height can be adjusted by adjusting the springs - if you have the type of door with the springs across the top of the header. Caution - you have to be very careful when playing with the springs - get some winding bars and learn how to adjust - there are several youtube videos on this.
If that won't give enough clearance, then you could raise the header like one member did a few years back. It's a lot of work though!
garages , it’s , outdoor , parking , stock
3rz-fe valve clearances Schady44 3rd gen T4Rs 15 05-14-2016 09:15 AM
3RZ-FE Valve clearances ok? triangles 3rd gen T4Rs 13 03-02-2016 02:02 AM
valve clearances gnarlynick2072 3rd gen T4Rs 21 02-26-2015 11:57 AM
06 V6 exhaust valve clearances 0694 4th Gen T4Rs 0 11-17-2013 08:18 PM
Valve clearances mkslrs 3rd gen T4Rs 5 09-24-2013 01:06 AM
