01-25-2021, 09:01 PM
Help me choose tires
I have stock tires on the 4Runner and I am lifting it so I need some new ones so it doesnt look stupid . Here is the list.
Grabber X3's - $948.00
Geolanders M/T g003 - $977.84
We live on the Gulf so we get a ton of water and I was leaning toward the Grabbers or the Geolanders for the longer life. Anyone have any of these and can give some real reviews and how they like them or don't?
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Reason: Narrowed search down
01-25-2021, 09:31 PM
Is there a specific reason for only considering these tires?
Cooper SST Pro - $1136 ( Not on sale)
Geolanders M/T g003 - $377.84
Wrangler MT/R with kevlar - $1091.68
From my understanding the Falken Wildpeak & Toyo Open Country are highly recommended tires as well.
I must admit it will be hard to help you determine the correct choice without having a bit more informations
(i.e. What size tires? Are you lifting the vehicle as well? Primary purpose of tires?)
01-25-2021, 09:51 PM
I like MTRs, I think I'm on my 7th set. They measure true to size and are light for their size, fantastic in rocks and desert. Usually get about 30k miles out of a set. They will get unbearably loud and vibes from the tread pattern if you're not diligent in rotating them.
I wouldn't run them if I still lived in the southeast US as there isn't enough opportunity to use them.
01-25-2021, 11:29 PM
I've used BFG KO2 several times and am pleased with them. They are made by Michelin.
01-26-2021, 03:33 PM
Real Name: 17 cement pro
Have BFG now and live on the gulf coast. Sucks in rain. I hear nittos are better for water.
01-26-2021, 04:24 PM
I'm still on the stock Pro Nittos (~25k on them) and they're not bad at all in rain. It rains like 70% of the year here too.
2019 TRD Pro Voodoo Blue "Cobra Commander"
01-26-2021, 09:08 PM
I think the most important question is how you are planning on using these tires. After we understand that I think we can make some good recommendations. Ill be probably in the minority here but I think from functional perspective unless your truck is a dedicated off road vehicle that sees a ton of mud MTs are going to be more harm than good.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
01-27-2021, 09:18 AM
I have not seen anyone else mention these tires but I have Pirelli Scorpion All Terrain Plus and have put about 3k miles on them. They balanced easily, are quiet, and great on wet/rainy roads. I haven't taken them off road yet.
01-27-2021, 09:56 AM
Really tire search it’s been beaten to death my choice is in order
1. Falken wildpeaks absolutely best all arounder great rain tire
2. Yokohama geolander great tire
3. Grabbers x3
4. Michelin Ltx
The rest fail in rain to me
Can’t go wrong with anything above
But really the falken is best choice
Mike
01-27-2021, 02:45 PM
You might consider looking at Tire Rack. Click on an AT tire for the 4R and scroll down. There will be a line that says Compare Tires in This Category....or something to that effect. Click on it and you can see ratings for how the tires compare in a number of ways.
01-27-2021, 02:58 PM
I would add to your consideration:
1. Falken Wildpeak M/T
2. Grabber AT/X
01-27-2021, 06:55 PM
285-70-17, dirt trails and overlanding, 3 inch lift,
The Build
01-27-2021, 07:03 PM
Thanks everyone I think I am going with the Geolander M/T G003 they are 821 locally installed and they seem to be newer than the others and come with a 45000 ish mile warranty. The grabber X3's are only 834 but the Yokohamas look a little bit more beefy than the Grabbers. I used to have Grabber AT2's and they were great so I have no doubt the Grabber X3's are great but the new tech in the Yoko's seem to have the edge until something new comes out.
The Build
01-27-2021, 07:23 PM
Real Name: Eddie
Real Name: Eddie
I'll cast another vote for Falken Wildpeak AT3W. I put these through their paces over the past 1.5 years on winter elk hunts and trips to the desert and they are great. On the desert and hunt trips, I went over some very gnarly terrain including rocks, 12+" of snow and mud with nary a blip. Good ride and wear also.
Also, while these are P rated tires, I read they have an extra ply in the sidewall so can handle the more challenging off-roading you might put it through. Based on some of the terrain I encountered, I can certainly believe this.
You should be able to find these on sale, installed, for about $650. Great value IMHO.
Good luck,
Eddie
2001 T4R SR5 - 180k miles and counting.
01-27-2021, 07:34 PM
Hang on.
If your main concern is rain/water, is there a reason you're focused on MTs? I know MTs have improved, but ATs are definitely more adept at dealing with water...
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
