Old 01-26-2021, 12:44 PM #1
xpress xpress is offline
xpress is on a distinguished road
Rattle noise underneath vehicle
I have a 2014 Limited. Been noticing a rattle coming from the back of the truck esp when idling. Upon checking I noticed there is aluminum looking pan under the truck that somehow got loose. Further investigation looks like it is screwed at various places and one spot seems to have suffered corrosion and is dangling which is what is causing the rattling. Anyone know what this is called and whether it is easy to replace ? Alternatively what type of place fixes this? A body shop?
Rattle noise underneath vehicle-image0-jpeg  Rattle noise underneath vehicle-image0-1-jpeg
xpress is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 01:20 PM #2
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Thats a heat shield for your exhaust. Won't hurt anything by removing. Doing a quick search I couldn't track it down but I'm sure a replacement is out there somehwere.
Here is a thread where this is discussed: THREAD
2005 Sport Edition Build Page
2017 TRD Off Road Premium
PSA: Stop Quoting Pictures
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 01:38 PM #3
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
You're lucky you saw it now. Mine came completely loose on a road trip and was dragging on my driveshaft. Needless to say, I noticed immediately and was like WTF is THAT??!!??
Pulled over, rearranged it just to get home. No dice, started dragging again 2 minutes later.
Pulled over second time and ripped it out of there bare handed (careful, it's sharp). Never gave it a second thought and I have been without it since. That was like almost 2 years ago.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 01:51 PM #4
catchx46 catchx46 is offline
catchx46 is on a distinguished road
any shop with a lift should be able to 1)pull it off or 2)replace it. you could ask them to take it off when you go in for anywork.
catchx46 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:34 PM #5
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
Mine fell off recently after some hard wheeling out in CO. It's been off for a few months and haven't seen any heat issues. It's also been cold, so that could be a moot point.
Aluminum heat shield + steel bolts + underbody location = prime candidate for galvanic corrosion. Not at all surprising that we're seeing these falling off.
I looked all over the parts diagrams for the truck and wasn't able to find any callouts for that heat shield. Not sure if someone with better access can find a PN but I'm guessing it's not normally a replaceable part.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 02:40 PM #6
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough
Angry Heat shield
Ya poorly done Toy. but yes off should be ok , I tried save mine with a larger washer worked for awhile then just shredded off so as ^^ stated !
2011 SR5 Mgm 4x4 Depo TE head & tail lights level 8 trackers wheels & p285/70/17 cooper at3s,bora 11/4 adapters, 51s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 51s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams osram h11 with laminx yellow fogs
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 03:25 PM #7
spartacus's Avatar
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
part code 58155
Part Description
Insulator, Front Floor Heat, NO.3
58155-60070
INSULATOR, FRONT FLOOR
Old 01-26-2021, 04:57 PM #8
Don't need a shop. Mine was done with 0 tools on the side of the road and no jack even needed. Now if you still have a couple bolts hanging on, either remove them or take a $10 pair of tin snips and cut it off on an angle before the bolts just so that they are each left holding only a tiny piece of the corner. As I said, it's sharp in places, wear gloves. Time and money saved.
You have to wrangle with it a bit to get it to come out but it's like an easy 10 minute job. It's soft enough you can bend it all around by hand.
Old 01-26-2021, 06:01 PM #9
Saker's Avatar
Saker Saker is offline
Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold
Saker's Avatar
Can you re-drill and place a SS bolt a couple of washers and a nut.
Is that an option?
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 01-27-2021, 12:07 AM #10
fkheath fkheath is offline
fkheath has a spectacular aura about fkheath has a spectacular aura about fkheath has a spectacular aura about
Heat shields are there for a reason, so it is best not to remove it. If you remove it, you could have the interior floor get too hot, damaging the carpet or sound deadening (think catching fire!). Fix as suggested above or replace.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 10:07 AM #11
I agree that you dont need a shop to do this but OP asked what kind of shop he would need to go to for this so it doesnt appear likely OP would be able to get under there and take it off.
Old 01-27-2021, 10:29 AM #12
I am going to try the washer fix. I also seem to have lost the nut. Any idea what size nut I would need?
Old 01-27-2021, 10:50 AM #13
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough
<<<<'s Avatar
That shield is essential for preventing condensation and moisture forming under carpet due to warm exhaust air vs cool interior in cold climate. I replaced my on 4th gen. Super easy 3 nuts and $90 part. Don't even need the lift, put a cardboard down and go for it.
TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Al Trans Skid / B&I CF Dash / TRD Stealth Shift / LED Floor Ambient Light / Prado Al Pedals / Ellis Precision Al Battery Holddown / Northstar AGM Battery/LED interior / ARB on-board Air / LC custom Engine Cover / CF GC Shelf / Fire Ext & MagLite
<<<< is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 10:53 AM #14
<<<<'s Avatar
<<<<'s Avatar
Important: hit those studs with PB blaster hours before removing nuts so you don't snap them off in process of disassembly.
Old 01-27-2021, 12:17 PM #15
Real Name: Doug
Real Name: Doug
Here is a link to the part.
$60 doesn't seem worth it to me plus it will be a PITA to get in there.
Exhaust Components for 2017 Toyota 4Runner | Conicelli Toyota of Conshohock
places , rattle , spot , suffered , truck
Rattle Underneath 4Runner - Need Help JayceeP 5th gen T4Rs 24 06-13-2013 01:39 PM
HELP! vibrating metal-on-metal rattle underneath floorboard hrt4me 3rd gen T4Rs 17 11-12-2012 07:04 PM
Rattle underneath spehrparts Problems & Warranty Issues 4 10-14-2011 01:54 PM
Weird noise from underneath dashboard hulk311 Problems & Warranty Issues 3 09-10-2011 11:49 PM
Rattle noise from underneath... mole177 4th Gen T4Rs 3 02-04-2006 05:36 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
