Old 01-26-2021, 11:50 PM #1
bandi bandi is offline
bandi is on a distinguished road
Battery Randomly Dead...
Did some quick searching on the forum/web with no luck...
Curious, We have a 2016 4runner and every since we have had it, we have experienced 3 occasions over the last 5 years where the battery was dead after 30-60min in a store or half day at work, and such... A quick jump and she's running again each time... no further issues on starting or such (until it happens again)...
Checked the terminals, cleaned them, etc.... battery water level in mid' of the low/high levels (never filled or touched)...
There is no loss of cranking power at any other time other then these 3 occasions (including today again)... At these occasions the interior/headlight lighting is dim when checking... and of course attempting to start the engine you get the 'click=click-click-click...' of the starter solenoid lacking of power..
I did add a remote start to her, but that was a month ago and would not explain the 2 prior occasions...
SOOOoooo... I would just like to know if anyone else has experienced this issue... I've been thinking interior light not going out, or DRLs staying on and not noticing... ? ? ?
Appreciate any comments...
bandi is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 12:16 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Those occasional problems are the hardest to solve. As you said, it could be leaving interior lights on, or the automatic lights not working right.
After five years, it is also possible that the battery is on it's last legs and has (much) reduced capacity, so anything left on could drain it quickly.
Suggest you do a thorough electrical system check out. Start by measuring the battery voltage at engine idle and with the engine off. At idle the voltage should be about 14 to 14.5 volts. With engine off, should be above 12 volts. With engine off, check battery voltage with the headlights on; if the voltage drops too fast with the headlights on, the battery is on it's last leg.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 12:36 AM #3
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
I had an intermittent and temporary issue that initially looked like a dead battery (no crank). Never could prove the root cause because it was intermittent, but basically if I tried cranking it anywhere between 1 and 20 more times it would finally crank without problem. It definitely wasn't a battery issue as no crank was zippo and when it engaged it lit right up.
My suspicion is that the dealer installed 'alarm' / anti-theft whatever doohickey that they spliced up the ignition wires to install went on the fritz (after a deep water crossing). Took about two months to resolve itself 'magically'.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 01:02 AM #4
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Probably a dead cell in the battery
Old 01-27-2021, 01:57 AM #5
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
At this point your due for a new battery. Next time it happens take time to measure voltage drop across all fuses. Measuring current is more accurate. However, disconnecting a battery cable to measure current could reset the problem.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 01-27-2021, 11:55 AM #6
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
My mom was having this issue. She changed the battery and it worked fine since. Dealer said it was a bad battery from the factory after multiple visits (feels like dealers just say things).
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
battery , occasions , power , start , time
Dead battery = Dead 4runner? PedroV 4th Gen T4Rs 12 02-21-2023 02:15 PM
07 SR5 Dead battery after 1 day evan1242 4th Gen T4Rs 6 10-12-2020 02:07 PM
Battery light flickering randomly mlc2000 4th Gen T4Rs 6 02-18-2018 05:24 PM
Dead battery? or something else? tcatl Problems & Warranty Issues 4 09-03-2012 12:23 AM
Dead Battery Help strangler Problems & Warranty Issues 8 09-09-2009 11:43 PM
