Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-23-2021, 03:35 PM #196
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
OK, so first mod deviating from design. I had a spare rubberized cap for my Fumitomo valve, so I put it on the lock latch bolt to prevent metal to metal contact.
Other than that, all done except cleaning the nasty spare. I tapped into the 7pin on the running lights (green wire) and ground (yellow wire) to power the LED license plate lights. The tabs were PERFECT for making a nice, orderly routing with a nice finished look after the zip ties are trimmed.
It's 101F (feels like temp) with 55% humidity, I'm going to shower and relax a bit before getting ready for some offroad adventures tomorrow.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 05:33 PM #197
CajunMikeR's Avatar
CajunMikeR's Avatar
One other note for you guys, and an idea of the detail @ctnewman applied to this project...
Don't worry about remembering which side is up on your camera, the port for it is cut so that it can only be inserted right side up.
2019 MGM TRD ORP
shootn4runner on IG
Old 07-24-2021, 06:33 PM #198
CajunMikeR's Avatar
CajunMikeR's Avatar
OK, so we went out to play in Kisatchie NF today. Nothing loosened up, no noise, hardly any movement when going over obstacles (you had to be watching to even see it, you couldn't feel it). When we stopped for gas before heading home, I yanked and pulled in it and just about every direction and everything was tight.
The only issue I found was a squeak when opening it up to access the back, I probably need to grease it some more, but the amount of dust that was all over everything could choke a camel... so I expected something to make noise until I wash it off.
2019 MGM TRD ORP
shootn4runner on IG
Old 07-24-2021, 06:51 PM #199
ctnewman ctnewman is offline
ctnewman has a spectacular aura about ctnewman has a spectacular aura about
Great news. You may want to play with the preload on the pivot pin. I didn’t have anything to set it up by because I was building them on a pallet so I just guessed on nut preload. Also I didn’t jam the two nuts together really tight or use loctite on the jam but because I just assumed everyone would disassemble before installation. But I’m a little guy.
Was there not a rubber tip in the bag w the latches? I was assembling them at 1am so maybe I missed it. You can buy replacement rubber tips for those clamps from McMaster. I thought they came with them though.
If they weren’t in the bag and you feel strongly about it I will order some and and send you them! Let me know!
McMaster-Carr
ctnewman is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 08:13 PM #200
CajunMikeR's Avatar
CajunMikeR's Avatar
I'd planned to go through and check tightness on everything and grease it again after it getting a workout today. But no matter which way I tugged, pulled, pushed, lifted... nothing gave, shifted, nor complained (other than a lot of dust causing a small squeak).
Mine came with a plain bolt, no rubber, but no big deal. I've got it temp rigged until the rubber bumper style come in.
Right now, everything is filthy and I'm tired. We left at 7am and didn't get back until after 5pm. I'll put a closer eye on everything after it gets cleaned, but so far it's definitely stout enough to withstand the first round of abuse. I made my own hitch mount spare tire carrier.I made my own hitch mount spare tire carrier.
2019 MGM TRD ORP
shootn4runner on IG
Old 07-29-2021, 10:27 PM #201
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Finally found the time to install my @ctnewman rear tire carrier!
It is everything ctnewman, stated it would be and then some. The install went without a hitch, well except the I have a camera continuity issue I need to nail down…
Edit: It wasn’t any connector or connections I made , but the OEM connector that the camera harness connects to.
Working at this point.
Hey Matt @SouthernSS take a peek.
I made my own hitch mount spare tire carrier.-20a66289-3b73-4246-b129-24ae692d088e-jpeg  I made my own hitch mount spare tire carrier.-aadb7acb-aa9b-47fe-a34e-c151eec74c6d-jpeg
Best Regards,
Saker
Old 07-30-2021, 05:24 AM #202
Ferd_4R Ferd_4R is offline
Ferd_4R will become famous soon enough
Damn mine still sitting on the trailer!!!
Called a couple of times and they say the Salt Lake hub is pretty busy I made my own hitch mount spare tire carrier.I made my own hitch mount spare tire carrier.
Ferd_4R is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 08:24 AM #203
I'll look into it and get back to you.
Old 07-30-2021, 08:51 AM #204
It’s okay man. I did call twice.
They told me it hasn’t been unload yet.
Online it says it’s on trailer. I’m hoping early next week. Or I’ll go unload that damn trailer myself I made my own hitch mount spare tire carrier.
Old 07-30-2021, 09:32 AM #205
CajunMikeR's Avatar
CajunMikeR's Avatar
I'd just call them to find out what their hours are for pickup.
When I ordered my sliders, they were in the nearest larger city 3 days before they were scheduled to be delivered. I came in from offshore 2 days before delivery, called them on the drive home, and picked them up as I passed through.
Having learned my lesson, I asked that the carrier be held for pickup. They had some odd pickup hours, but again I picked it up on my first day home from work.
2019 MGM TRD ORP
shootn4runner on IG
Old 07-31-2021, 12:28 AM #206
Finally got the call and picked it up today.
Now I’m starting a stretch of 5 night at work so it won’t get installed until late next week I made my own hitch mount spare tire carrier.I made my own hitch mount spare tire carrier.
It least it’s home and I get to stare and drool at the beautiful welds as I walk in the door. I made my own hitch mount spare tire carrier.
Old 07-31-2021, 09:57 AM #207
Saker's Avatar
Saker's Avatar
I nailed down the continuity issue. It wasn’t a connection or connector I made, but seems to be an OEM connector that the camera harness plugs into.
Appears to be fixed for now.
I used Cat5E for my wiring and made up the connectors so I ended up with a minimum of splices.
Here are a couple of pics.
I made my own hitch mount spare tire carrier.-e4a2d2b1-c094-4a4e-ab77-25f32c076e61-jpeg  I made my own hitch mount spare tire carrier.-5a48bdbe-80c3-4443-b55a-9e35a2ceaf19-jpeg  I made my own hitch mount spare tire carrier.-f74d33de-54ab-48f8-bb7b-7c7b7f495b93-jpeg
Best Regards,
Saker
Old 08-02-2021, 09:02 PM #208
Saker's Avatar
Saker's Avatar
So I took a drive over to Southern Style Offroad today. Met Matt @SouthernSS & a couple other guys that work for Kevin. They looked over the carrier and design. So now the ball is in their court to make some kind of decision and contact @ctnewman to possibly work out any details if they choose.
I hope they see there is a desire for a really good carrier that many hasn’t had the opportunity to purchase and pick its design up.
Best Regards,
Saker
Old 08-02-2021, 09:34 PM #209
CajunMikeR's Avatar
CajunMikeR's Avatar
Hell, you should've let me know you were going, I'd have driven over to meet up!
2019 MGM TRD ORP
shootn4runner on IG
Old 08-02-2021, 10:42 PM #210
Saker's Avatar
Saker's Avatar
Sorry Mike........
It was a last minute, had to go now type of thing!
Best Regards,
Saker
hitch , plate , things , tube , welded
FS: CBI hitch mount Spare tire/hi-lift carrier $250 03V84R For Sale: T4R Items 19 12-15-2019 08:21 PM
FS CBI Offroad Swing Down Spare Carrier Hitch Mount, $200, Minneapolis MN zimp132 For Sale: T4R Items 0 03-07-2018 05:14 AM
Hitch tire carrier with spare SF Bay area, Ca Jayjayb96 For Sale: T4R Items 2 10-28-2016 12:05 PM
WTB:CBI hitch mount spare tire carrier HavocRunner Want to Buy/Trade 0 03-29-2015 09:54 AM
Hitch Spare Tire Carrier GREENMONSTER 4th Gen T4Rs 0 03-08-2009 09:57 AM
