Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-27-2021, 08:22 PM #46
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I made my own hitch mount spare tire carrier.
i'm also interested in a centered one, pending how will it clear my gobi ladder. i would like to see something similar to detours of maine. Also the tire on the dom seems to be higher ?
Originally Posted by ctnewman View Post
Anyhow, all the tubes are cut and beveled for welding (a lot of companies do not pre-bevel their tubing and it results in a lower strength product). Right now I cut enough pieces to do either 2 centered, 3 offset OR 3 centered, 2 offset. I'm still not certain which route I should take.
@Saker wants a centered one @CajunMikeR want's an offset one
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-27-2021, 09:47 PM #47
TrD4runnerOffRoad TrD4runnerOffRoad is offline
TrD4runnerOffRoad is on a distinguished road
I’d be interested if there’s any spots remaining. I’m a center mounted on, pending if it would work with a ladder as well. Can you pm me the details?
Thanks
2017 Toyota 4Runner Trail - KDSS
Suspension & Wheels - Dobinsons IMS 3" & 314/725 / FN FX Pro wheels 17x8 / 295/70/17 BFG KM3's / Spidertrax 1.25" spacers // Lighting - DD SS3 pro sae Fogs / GTR ultra 2 LED / MESO Puddle lights / GTR high output reverse lights // Misc - Tuxmat floor mats / Anytime backup camera / BPF Molle panels / Redarc brake controller / Canvasbak cargo covers / CHT T9 headunit / Pedal commander / BMC air filter / TRD intake / AVS window visors / BGC KDSS blocks / B&M 70264 transmission cooler /
TrD4runnerOffRoad is offline   Reply With QuoteReply With Quote
Old 04-27-2021, 09:59 PM #48
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Thanks
Let me suggest that you pm @ctnewman so you can ask questions.
Or email him at ctnewman at gmail
He is in the process of working on them as I type this, so time is important.
He may have already cut the tubes
Best Regards,
Saker
Old 04-27-2021, 11:58 PM #49
bboy626's Avatar
bboy626 bboy626 is offline
bboy626 is on a distinguished road
bboy626's Avatar
PM'd for inquiry!
bboy626 is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 08:41 AM #50
ctnewman ctnewman is offline
ctnewman has a spectacular aura about ctnewman has a spectacular aura about
Hey guys,
The center mounted ones will NOT clear a ladder. That is the reason for the offset. When I designed this my main intention was to have a close fitting design where the tire hugged the rear hatch, because all the ones on the market stuck out so far.
See pics below for reference of fitment with gobi ladder. I suppose that you could put spacers behind the wheel... but then what's the point of the tight fitting design.
Also, I made the executive decision and decided to make 3 offset and two centered. One of each is spoken for.
Additionally, here is some more information that i was asked in a PM but thought group knowledge would be helpful:
1) the camera mounts on an armored extension that peeks through the wheel centerbore.
2) higher license plate sits in different places depending on whether or not is is offset or centered:
you can see there there are two plate mounts. The upper mount is for the centered setup, the lower mount is for the offset. Only one plate mount will be on there, though.
3) the offset is to the right, not out away from the vehicle. The wheel on the offset version is shifted 8" off center to the right. It should clear your gobi ladder assuming it's installed in the factory specified spot. I have seen some installed more centered. the picture below shows the offset version. For reference the one on my truck is offset 10" to the right and the gobi ladder is installed in the factory specified position.
ctnewman is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 09:22 AM #51
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I've toyed with the idea of making my own using this receiver for better departure angle and a pre-built spindle.
It would be quite similar looking to yours.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 09:41 AM #52
SendInTheCavalry SendInTheCavalry is offline
SendInTheCavalry is on a distinguished road
Looks amazing!!
I wonder how long the sleeve has to be to support a bike carrier or rack thing?
If that hitch receiver protruded past the bumper just enough for your swing arm stock that thing would be the best hitch swing on the market!
SendInTheCavalry is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 10:15 AM #53
Originally Posted by SendInTheCavalry View Post
Looks amazing!!
Correct. It could absolutely be shorter, but how much shorter depends on what loads you're adding.
Old 04-28-2021, 10:27 AM #54
great work OP. It's refreshing to see someone build something on these forums.
Old 04-28-2021, 11:44 AM #55
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Would love to get in on this, just can't justify it at the moment.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 01:37 PM #56
Hey guys,
For the center option, what will be the offset ? I’m just trying to decide either center or to the right :-)
Old 04-28-2021, 01:47 PM #57
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
i wish someone would go through this design effort for a rear tire carrier that attached to the frame under the bumper cover instead of the hitch
jhguth is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:04 PM #58
The center option is zero offset.
Old 04-28-2021, 03:06 PM #59
Originally Posted by Saker View Post
Center
i get that there's a center option. my concern is the distance from the ladder to the back of the tire when installed. for example, the ultraswing (rigd) has a 7" offset from back of the tire carrier to the hatch. i know the gobi ladder is ~ 3" from the hatch to the ladder.
so my conceren is the distance from the ladder to the back of the tire carrier. from ultraswing it's 4". i'm hoping this one (center option) has an offset of less then 3". i think 1" is good
this will determine if i choose center of offset carrier.
Old 04-28-2021, 03:06 PM #60
Absolutely doable. Easier and better if you're willing to cut up your bumper for access. If you're trying to go around the bumper, you're not going to gain much, as you will still wind up having just as much steel and not a significant improvement in the way it attaches.
hitch , plate , things , tube , welded
FS: CBI hitch mount Spare tire/hi-lift carrier $250 03V84R For Sale: T4R Items 19 12-15-2019 08:21 PM
FS CBI Offroad Swing Down Spare Carrier Hitch Mount, $200, Minneapolis MN zimp132 For Sale: T4R Items 0 03-07-2018 05:14 AM
Hitch tire carrier with spare SF Bay area, Ca Jayjayb96 For Sale: T4R Items 2 10-28-2016 12:05 PM
WTB:CBI hitch mount spare tire carrier HavocRunner Want to Buy/Trade 0 03-29-2015 09:54 AM
Hitch Spare Tire Carrier GREENMONSTER 4th Gen T4Rs 0 03-08-2009 09:57 AM
