Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 05-05-2021, 11:32 AM #76
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Originally Posted by jhguth View Post
beautiful, someone make a kit for this
No, it is custom fabricated.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 07:16 PM #77
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I saw an update on the carrier, but I’m not going to get ahead of @ctnewman and give it away....
You are going to have to wait for any photos!!!!!
(I like what I am seeing. This is a hard working man, just to let all of the people know that think it may be overpriced compared to the mass production usual suspects)
Best Regards,
Saker
Old 05-06-2021, 01:58 PM #78
ctnewman ctnewman is offline
ctnewman has a spectacular aura about ctnewman has a spectacular aura about
Hi everyone,
Things are still going smoothly on my end. I have welded all the latch plates onto the upper arms. Tonight I am going to weld the wheel mounts on. Some things to note:
A) original design for these 5 units was a single "open" position at 120 degrees swung open. I've decided to add a second, even further" open position. The positions are held by a spring loaded plunger, operation will be as follows.
1) release center clamp holding hitch closed
2) briefly lift the secondary lock pin at the hinge and swing open the tire
3) at 120 degrees the latch pin will drop into a slot and the tire wont flop around
4a) to close, lift the pin and swing the tire closed, when the arm is fully closed the safety latch will drop into place and you can close the primary latch.
4b) if you want to open it further, lift the safety latch again and swing the tire almost 180 degrees out of the way. You wouldn't do this all the time, but for special cases it might be useful. There is also a hard stop right after the "extra wide open" position that cannot be passed so the carrier cannot hit your vehicle.
There are no loose pins to try to get into holes that aren't lined up. If you decide you don't want to have the secondary latch system at all? Well you can just unbolt it and will still have the hard stop!
B) Some notes about the primary latch.
1) all stainless construction
2) true one handed operation. There is no need to line up a hook with a reciever or anything like that, think of it as more like closing a house door and turning a deadbolt.
3) the primary latch has a locking handle itself. The handle must be squeezed (albeit lightly) to be operated. This ensures you don't accidentally bump it open with your leg.
C) some other construction notes:
1) All seams are fully welded. This is less to do with strength and more to do with corrosion resistance. Ever see stitch welds leaking rust? That's because the powdercoat can't get into those small cracks.
2) Wrinkle black powdercoat is applied over a baked on zinc primer to add rust resistance
3) Several wire management tabs will be welded onto the back of upper and lower arms. This allows you to manage your wiring for your license plate lights and your back up camera cables.
4) The camera mount is designed to use your stock camera. I would recommend just getting a used camera off ebay, but you can absolutely remove your stock camera. There is a lot of information out there about how to relocate the camera.
5) wheel mounts are pressed in OEM wheel studs. No fumbling with loose hardware. All six studs will be available, (i think having all the lug nuts on looks best) but you could get away with running only 3 for faster tire changes.
I'm excited to show you guys my "anti-rattle system but I'm going to wait until I get them built to show you how it works. In my opinion it's one of the better designs on the market.
I'll have more information and hopefully some pictures this weekend!
ctnewman is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 02:03 PM #79
TrD4runnerOffRoad TrD4runnerOffRoad is offline
TrD4runnerOffRoad is on a distinguished road
I Agree, been looking for a local shop to build something like this for me ever since I first saw this design.
2017 Toyota 4Runner Trail - KDSS
Suspension & Wheels - Dobinsons IMS 3" & 314/725 / FN FX Pro wheels 17x8 / 295/70/17 BFG KM3's / Spidertrax 1.25" spacers // Lighting - DD SS3 pro sae Fogs / GTR ultra 2 LED / MESO Puddle lights / GTR high output reverse lights // Misc - Tuxmat floor mats / Anytime backup camera / BPF Molle panels / Redarc brake controller / Canvasbak cargo covers / CHT T9 headunit / Pedal commander / BMC air filter / TRD intake / AVS window visors / BGC KDSS blocks / B&M 70264 transmission cooler /
TrD4runnerOffRoad is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 11:44 PM #80
LT4CMG LT4CMG is offline
LT4CMG is on a distinguished road
Very nicely done
LT4CMG is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 09:05 AM #81
As promised yesterday, I got the wheel holders all welded up.
Flux core is very satisfying to weld with. I reverse crowned the stainless wheel plates before welding on them to combat distortion. When cooled the plates were perfectly flat. You will notice I didn't wrap the weld around the gusset. What isn't shown here is that I actually TIG welded the end of the welds in those areas to ensure clearance for the stud head.
Here are all the arms done. Still need the secondary latch added (one is tacked on here) and the license plate bungs on the centered arms.
I had to order the new secondary latch lock plates from the laser shop, so it will be a few days before I weld those on to the lower arms. I think my next move will be to get the receivers welded on. I'll probably use my own truck for mockup/fitup purposes.
Old 05-07-2021, 01:32 PM #82
Saker's Avatar
Saker's Avatar
@ctnewman
It is satisfying to see raw metal being worked to create a quality product. To see the welds and understand the process as well. Most times (unless you order bare) products are powder coated and you never see this stage.
Thanks again, they look good and are coming along fine !
Best Regards,
Saker
Old 05-07-2021, 06:28 PM #83
Ferd_4R Ferd_4R is offline
Ferd_4R will become famous soon enough
What a beautiful piece!! True masterpiece!!!
Can’t wait to rock that on my rig.
Ferd_4R is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 06:36 PM #84
Pirate-Burt's Avatar
Pirate-Burt Pirate-Burt is offline
Pirate-Burt is on a distinguished road
This is phenomenal. Nice job!
Pirate-Burt is offline   Reply With QuoteReply With Quote
Old 05-17-2021, 02:21 PM #85
Saker's Avatar
Saker's Avatar
Progress is still happening on the builds!!!
Saw stuff but will wait on photos.
>>> Thanks @ctnewman
Best Regards,
Saker
Old 05-24-2021, 11:21 AM #86
Hi guys. Been a minute. Here are some updates:
Got the camera mounts welded up with a camera test fit in there. These mount in the center of the spare tire, so on the offset version your camera will be 7 or so inches off center, but it shouldn't be a problem.
All the receivers are drilled for the new 3 plane locking system, and some of the locking components are welded up as well. These parts are fully tig welded.
Next I got all of the lower arms welded to the receivers. I did the mockup on my own vehicle to ensure everything fits well. Also in the pictures you will note that the female part of the receiver protrudes a lot less than it does on my early prototype. Much better looking. The second picture is the unit for @Saker .
Lastly, I was able to do a test of the new secondary latch system I mentioned earlier. It works great and performs exactly as expected.
Things left to do:
1) weld on secondary latch plates and spring plungers
2) fully weld striker tabs on lower arms
3) weld on license plate brackets and bungs
4) weld on zip tie tabs for camera/license plate light wiring
5) powdercoat, press in wheel studs and ship!
I am hoping to get at least the first 3 items done this week.
Old 05-24-2021, 01:23 PM #87
Saker's Avatar
Saker's Avatar
Talking
Things left to do:
@ctnewman ,
Thanks for the progress report.
As usual, your engineering skill are are showing themselves without even trying!
Everyone should see in these photos how well built and how much attention to detail has been thought out on this carrier.
I see you have been doing a lot of the tedious work in the background and now it shines on display.
I see as well the receiver protruding is less! Kudos!
Thanks for the sneak peek on the center carrier, that’s awesome.
Can’t wait to see the next round of progress photos….
You never stop working!
Best Regards,
Saker
Old 05-24-2021, 01:38 PM #88
Thanks for the updates!!!
Once again beautiful work.
I got my license plate lights ready to go!!
Can’t wait!! Xmas will come early this year hahah
Old 05-24-2021, 02:09 PM #89
Saker's Avatar
Saker's Avatar
Same here @Ferd_4R ,
Got backing plate and lights. Has previously ordered all wire and looming needed to relocate my camera and Lic plate lights. Got waterproof connectors so I can remove the carrier at will (if needed) by disconnecting them near the receiver. That’s going to make it really easy to do.
Best Regards,
Saker
Old 05-24-2021, 02:19 PM #90
@ I was going to do it myself but I stumbled on the Rigid Supply license plate kit hahah
hitch , plate , things , tube , welded
FS: CBI hitch mount Spare tire/hi-lift carrier $250 03V84R For Sale: T4R Items 19 12-15-2019 08:21 PM
FS CBI Offroad Swing Down Spare Carrier Hitch Mount, $200, Minneapolis MN zimp132 For Sale: T4R Items 0 03-07-2018 05:14 AM
Hitch tire carrier with spare SF Bay area, Ca Jayjayb96 For Sale: T4R Items 2 10-28-2016 12:05 PM
WTB:CBI hitch mount spare tire carrier HavocRunner Want to Buy/Trade 0 03-29-2015 09:54 AM
Hitch Spare Tire Carrier GREENMONSTER 4th Gen T4Rs 0 03-08-2009 09:57 AM
