Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-28-2021, 03:09 PM #61
ctnewman ctnewman is offline
ctnewman has a spectacular aura about ctnewman has a spectacular aura about
Originally Posted by daytonaviolet View Post
i get that there's a center option. my concern is the distance from the ladder to the back of the tire when installed. for example, the ultraswing (rigd) has a 7" offset from back of the tire carrier to the hatch. i know the gobi ladder is ~ 3" from the hatch to the ladder.
so my conceren is the distance from the ladder to the back of the tire carrier. from ultraswing it's 4". i'm hoping this one (center option) has an offset of less then 3". i think 1" is good
this will determine if i choose center of offset carrier.
Hi!,
Did you happen to see the pictures I posted of the carrier on my rig? There is very little distance between the back of the wheel and the hatch. (about 1.5")
If you have a gobi (or probably any other brand) ladder installed, the ONLY option will be offset.
ctnewman is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:26 PM #62
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
This is why I selected offset. I'll be adding a ladder in the future and, based upon the pics, could tell that the price for such a tight tuck was the need for an offset carrier to make it work.
If I weren't going to do a ladder, I'd have gone with centered. But alas, I have a wife with a case of the short, so a ladder will be needed down the road.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 03:31 PM #63
And quite frankly, the whole reason I made the carrier to begin with. All the options had such a nauseating gap between the hatch and the tire, I wanted everything tight and tidy. I understand why DOM and Rigd keep the tire so far from the hatch, because they want to make a universal product at a low (in theory) cost. But people buying one of mine would be doing so for a specific reason.
Old 04-28-2021, 03:46 PM #64
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Absolutely doable. Easier and better if you're willing to cut up your bumper for access. If you're trying to go around the bumper, you're not going to gain much, as you will still wind up having just as much steel and not a significant improvement in the way it attaches.
i want to cut a hole on the right side for the spindle to stick through and have the rest behind the bumper cover
there is foam between the top of the cross member and bumper cover, that space could be used for any support needed and there is also space between the cover and cross member particularly in the corners.
jhguth is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 04:16 PM #65
Yes if you are willing to cut a hole in the bumper cover it becomes a lot easier. The biggest problem that jumps out initially (which isn't insurmountable), is that you'd probably need another penetration for the latch. Latching it at the pivot would not be sufficient. There are other options but it would need to be thought through.
Old 04-28-2021, 04:45 PM #66
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I made my own hitch mount spare tire carrier.
Hi!,
Ohh so if I have a ladder, I won’t be able to use the center carrier. Only the offset carrier will be available as the distance from the hatch for both options is the same.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 05:44 PM #67
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Like the "slim line" front bumpers. Cut out the plastic valence. Could probably use the stock hitch bolt locations and sandwich it in with longer bolts.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 06:31 PM #68
yeah its been done. i've seen the pictures on IG i think. or on here somewhere.
Old 04-28-2021, 06:42 PM #69
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Yes, Both offset and center carriers clearance between it and the rear hatch are the same.
These carriers are tightly tucked close to the hatch.
So from the photos it appears the center carrier would interfere with the ladders.
Offset will be your choice. Tightly tucked and clearance of ladder location.
Best Regards,
Saker
Old 04-28-2021, 08:22 PM #70
Saker's Avatar
Saker's Avatar
So, here is an update on the upper horizontal arm pieces.
2 Centers and 3 Offset Arms.
I made my own hitch mount spare tire carrier.-6b360b40-46c6-4252-8499-a6353425ffaa-jpg
Best Regards,
Saker
Old 04-29-2021, 11:43 AM #71
Sioux runner Sioux runner is offline
Real Name: Jeff
Sioux runner is on a distinguished road
Real Name: Jeff
Great work sir! I would certainly be interested not in you building one of these for me but sharing the design and cad files for me to fab myself. Certainly for a reasonable fee of course! Something that others might be interested also. Thanks in advance!!!
Sioux runner is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 09:35 PM #72
Saker's Avatar
Saker's Avatar
@CajunMikeR
Just got a progress report from ctnewman.
He should start assembling the carriers this week!
Here is a the run bored and bushed!!!!
I made my own hitch mount spare tire carrier.-0a158f2a-50ce-4efa-bc52-f95abb34805c-jpg
Best Regards,
Saker
Old 05-04-2021, 12:16 AM #73
jawt4r jawt4r is offline
jawt4r is on a distinguished road
Very cool! Sent you an e-mail.
jawt4r is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 11:34 AM #74
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Hadokyn on IG has this: Login • Instagram
I made my own hitch mount spare tire carrier.-hadokyn-bumper-carrier-jpg  I made my own hitch mount spare tire carrier.-hadokyn-bumper-carrier-mount-only-2-jpg  I made my own hitch mount spare tire carrier.-hadokyn-bumper-carrier-mount-only-jpg
dezertbomber is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 07:31 AM #75
beautiful, someone make a kit for this
hitch , plate , things , tube , welded
FS: CBI hitch mount Spare tire/hi-lift carrier $250 03V84R For Sale: T4R Items 19 12-15-2019 08:21 PM
FS CBI Offroad Swing Down Spare Carrier Hitch Mount, $200, Minneapolis MN zimp132 For Sale: T4R Items 0 03-07-2018 05:14 AM
Hitch tire carrier with spare SF Bay area, Ca Jayjayb96 For Sale: T4R Items 2 10-28-2016 12:05 PM
WTB:CBI hitch mount spare tire carrier HavocRunner Want to Buy/Trade 0 03-29-2015 09:54 AM
Hitch Spare Tire Carrier GREENMONSTER 4th Gen T4Rs 0 03-08-2009 09:57 AM
