Hi guys. Been a minute. Here are some updates:
Got the camera mounts welded up with a camera test fit in there. These mount in the center of the spare tire, so on the offset version your camera will be 7 or so inches off center, but it shouldn't be a problem.
All the receivers are drilled for the new 3 plane locking system, and some of the locking components are welded up as well. These parts are fully tig welded.
Next I got all of the lower arms welded to the receivers. I did the mockup on my own vehicle to ensure everything fits well. Also in the pictures you will note that the female part of the receiver protrudes a lot less than it does on my early prototype. Much better looking. The second picture is the unit for
Saker
Lastly, I was able to do a test of the new secondary latch system I mentioned earlier. It works great and performs exactly as expected.
Things left to do:
1) weld on secondary latch plates and spring plungers
2) fully weld striker tabs on lower arms
3) weld on license plate brackets and bungs
4) weld on zip tie tabs for camera/license plate light wiring
5) powdercoat, press in wheel studs and ship!
I am hoping to get at least the first 3 items done this week.
