Old 01-30-2021, 04:52 PM #1
Sp00ner's Avatar
Sp00ner Sp00ner is offline
Sp00ner will become famous soon enough Sp00ner will become famous soon enough
Sp00ner's Avatar
Morimoto 2Stroke 3.0 9005/H10:High/DRL bulbs.
Anyone running these in the High beam/DRL locations?
Thought I did my homework here, but once plugged in they're on full blast no matter what I have the headlights set to.
Am I an idiot (quite possible) or am I missing something simple in regards to hooking these up? I mean... it's a single plug... not exactly a complicated install routine here... Emailed the vendor and Morimoto to see if I failed at my homework, but figured I'd ask here as well.
RCI Sliders & TRD Integration, Transmission and Transfer Case Skids
Eibach TRD Pro Lift, 285/70/17 KO2s
TRD Intake, ARB Breathers
Pioneer 8500NEX
Sp00ner is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 06:13 PM #2
Sp00ner's Avatar
Sp00ner's Avatar
Ugh... the more I'm looking into this, the more I'm starting to think I paid too much attention to the manufacturer's marketing material and not enough to the details of the application regarding the 4Runner itself.
Translated: I'm likely an idiot.
Pioneer 8500NEX
Old 01-30-2021, 06:18 PM #3
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Unless you have a 2021, I believe you’re putting these LED bulbs in halogen housing which isn’t a good idea. If you like Marimoto just put out the dough for the XB LED lights with housing. I think it looks totally awesome on the 4Runner.
umidkusername is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 07:41 PM #4
dakgildea dakgildea is offline
dakgildea will become famous soon enough
You need a resistor to lower the amp draw. Look up the 2.0's on some vendor sites you should see the option to add the dongle thing.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
dakgildea is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:40 AM #5
nerfkhat nerfkhat is offline
nerfkhat is on a distinguished road
The 3.0s should work. I confirmed with them it has drl function. the only other ones other than the 3.0s were the xenon depot leds.
nerfkhat is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 12:03 PM #6
ebadai98 ebadai98 is offline
ebadai98 is on a distinguished road
Has anyone installed and running them in the low beam? I had difficulty getting the passenger side in properly.
2018 TRD Off Road
ebadai98 is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 01:04 PM #7
Sp00ner's Avatar
Sp00ner's Avatar
Yea, the problem is that it seems 'DRL function' to most suppliers just means that it will come on as a DRL, not necessarily be the right brightness. The 4Runner uses PWM to dim the bulbs, not just dropping the voltage. So they come on, full blast, and pulse/flicker at the same time.
You can fix the flicker, but it seems only Xenon Depot makes a driver that can understand the dimming method and actually have the DRLs be 20% output. I was prepared for the flicker and had the right modules to fix that, but theres zero difference between DRL and Brights with regard to the light output of the bulbs.
Pioneer 8500NEX
Old 01-31-2021, 01:06 PM #8
Sp00ner's Avatar
Sp00ner's Avatar
Yea, I have the 2.0's as low beams, if you replace the O-ring with the OEM style O-ring, they go in just like the stock bulbs. You can get them in with the ones that come on them, but it's really hard if not impossible for some folks.
Pioneer 8500NEX
Old 01-31-2021, 02:49 PM #9
Yup, tried that and it does go into the socket better however my issue is adjusting the base so the diode is angled at 3&9. The base is a completely different shape then the 2.0’s.
2018 TRD Off Road
Old 02-01-2021, 05:02 PM #10
Sp00ner's Avatar
Sp00ner's Avatar
Sigh... response from the vendor...
"Thanks for reaching out!
Unfortunately they will not dim to lower output for the DRL, we have seen that across many different style LED's on these applications. There would not be a way to get it off the full intensity, the only bulb we've seen work on occasion and even still have some issues is the Xenon depot bulbs.
Toyota PWM systems for the DRL don't really work all too well with aftermarket bulbs and dimming for the lower output."
Pioneer 8500NEX
beam/drl , homework , hooking , install , morimoto
Morimoto 2stroke 3.0 _Moose Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-08-2020 01:43 AM
Sold: Morimoto 2Stroke 2.0 LED Bulbs fr4c For Sale: T4R Items 6 11-10-2019 10:02 PM
Morimoto 2Stroke LED Bulbs vs DDM Tuning Saber LED hawaiianryan 5th gen T4Rs 10 09-27-2016 12:40 PM
