Old 01-28-2021, 01:22 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Clank Sound Start Up
This morning, I noticed a strange clanking noise coming from the front. The vehicle was parked outside overnight and this was a cold start. Car drove fine so I'm not sure how serious this could be.
Not sure how long this has been going on. I normally start the car with the door closed, but this morning I started it up with the driver door open and that's when I heard the noise.
I will try again tomorrow morning, but wanted to see if anybody else experienced this. This is a 2014 SR4 4x4 model with a little over 100k miles.
Chilow is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 02:24 PM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Can you make a sound clip so we can help?
Best Regards,
Saker
Old 01-28-2021, 02:43 PM #3
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
This poor little guy is probably frozen...
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 01-28-2021, 03:42 PM #4
Not my video, but sounds like this.
FJ Cruiser Hard Start Up Sound - YouTube
Old 01-29-2021, 12:37 AM #5
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Just a guess -- sound a bit like valve noise. Caused by the hydraulic valve lifters bleeding down after a long sit. No harm done if it goes away soon after the oil pressure builds up.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 10:50 AM #6
ctnewman ctnewman is offline
ctnewman has a spectacular aura about ctnewman has a spectacular aura about
Yeah, in the video it sounds like a lifter bleeding down.
Next time it does it, turn the car off immediately, wait a couple seconds and restart. If it doesn't happen again, it's probably a bled down lifter.
If it DOES happen again, and it hasn't been this cold in a while, there's a chance that because of the cold, that a heat shield or something that's now JUST close enough to make contact. Metal moves as a function of temperature. It's possible that there due to extreme cold it's moved enough to make contact. My pickup truck did this.
ctnewman is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 11:34 AM #7
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
There are no "hydraulic valve lifters" in this engine.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 11:37 AM #8
Update: started the vehicle this morning and heard it very slightly. Lasted like half a second. Around the same time in the morning as last time. Temperature was about the same as well.
Old 01-29-2021, 11:52 AM #9
Is it just cam on valve? I'm still in the stoneage over here spending most of my time working on old harleys.
Old 01-29-2021, 12:19 PM #10
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Oh yes, there are:
Clank Sound Start Up-screen-shot-2021-01-29-8-16-37-am-png
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 12:30 PM #11
A rose by any other name ----.
The 4Runner repair manual (TOYOTA 2016-2019 4Runner Repair Manual RM27F0U) calls them "Valve Lash Adjustment Assembly", and the OEM parts list (2018 Toyota 4Runner Premium Engine Camshaft Follower - 137500P020 - Genuine Toyota Part) calls them "Engine Camshaft Followers".
Still the same idea: a hydraulic device to take up any gap between the cam and the valve.
Old 01-29-2021, 12:35 PM #12
No, not cam on valve. "Solid lifters", adjustable or not, on cars are long gone. All modern cars have a hydraulic device to take up any valve gap.
They have a one way valve to pressurize a piston with engine oil pressure. The factory repair manual has a good illustration of the device on page 4244.
If the one way valve leaks a bit, they will bleed down, causing a chattering noise until the oil pressure recharges them.
Old 01-29-2021, 01:22 PM #13
When's the last time you checked the oil level?
Gone
Old 01-29-2021, 01:42 PM #14
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Sounds like starter disengaged flywheel and continued to run while trying to re-engage the flywheel. Has nothing to do with valve train.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 01:51 PM #15
08TxRunner's Avatar
08TxRunner's Avatar
Originally Posted by TEujunga View Post
Oh yes, there are:
Nope. A lash adjuster is not a lifter. We should try to use the proper terms.
car , door , morning , noise , start
Click/Clank Sound Diagnosis Help FamousAv8er 5th gen T4Rs 4 09-12-2019 01:59 PM
custom start up sound th0ul0w General Discussions 5 08-03-2014 09:22 AM
Clank clank clank while backing 64nkb Problems & Warranty Issues 1 07-22-2013 10:15 PM
Click sound when trying to start CAN-03runner Maintenance/Detailing 0 01-24-2012 04:50 PM
