Old 01-31-2021, 04:18 PM #1
videopuppy videopuppy is offline
videopuppy is on a distinguished road
Slight acceleration delay
2010 SR5 with 4.0
Sometimes (mostly) there is a delay (not sure delay is the best word), I give it gas and it barely wants to move and then finally goes! It seems electronic maybe. I know these things don’t have a throttle cable, so maybe it has to do with what has replaced the cable, or maybe a TPS? It does seem to happen more when I’ve been driving and stop briefly, like to check the mail.
Anyone else ever have this, resolve?
Thanks
videopuppy is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 04:36 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by videopuppy View Post
2010 SR5 with 4.0
Thanks
When you want to go, there are a number of changes that take place in the engine. Probably the one that takes the most time is the valve camshaft repositioning. Also, keep in mind that the power output from the engine is torque times RPM, thus at low RPM, the power is low. When the RPM gets higher, you have more power. Thus it seems to be weak (less power) when you first start out .
Sadly, what you experience is common on modern cars due to the environmental and economy mandates from the government.
fkheath is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 04:43 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Ls swap.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 05:48 PM #4
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
How's your transmission fluid level? When is the last time it was changed?
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 08:37 PM #5
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough
Sprint booster on race 5. Problem solved.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
Old 01-31-2021, 09:32 PM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by Charlievee View Post
Ls swap.
Haha, I see what you did there!
Wouldn’t that be awesome?!?!!
Best Regards,
Saker
Old 02-01-2021, 05:52 PM #7
djeepin djeepin is offline
djeepin is on a distinguished road
"Sometimes" you are in overdrive - check gear ratios and understand how transmission works. Shift from D to S and in 4s gear give some throttle. Be safe.
djeepin is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 06:22 PM #8
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
2010 SR5 with 4.0
Thanks
My 2013 has a slight dead spot in the throttle travel. The first small distance, there is no response from a stop, then it's OK. I know it's not throttle linkage slack.
I have learned to press gently but quickly at first (to get past the small dead zone), then press as needed/wanted. If I'm too quick to press, then it jerks at first. Takes a while to make that motion become automatic. It can be a real nuisance when off road on rough patches, I have to work at it.
One of the Throttle Commander type units will probably help if it's worse than mine.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 11:15 PM #9
lawn_gnome lawn_gnome is offline
lawn_gnome is on a distinguished road
I had a similar problem in my 2010 Trail. For me it was only when I was at low speeds, often when turning a corner in a residential area, I would take the corner hit the gas and it took a second for it to get going and shift gears. There was a technical service bulletin for it. They updated some software and I had the transmission fluid replaced. The issue largely went away. I've noticed it only a handful of times in the 3+ years since.
lawn_gnome is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 12:46 PM #10
Camping4R Camping4R is offline
Camping4R is on a distinguished road
Clean the MAF?
2020 SR5 Premium • Super White
BF Goodrich KO2 285/70R17 • TRD Wheels • AnytimeBackup Camera • VLEDs Interior • Gobi Stealth Rack
Camping4R is offline   Reply With QuoteReply With Quote
cable , delay , happen , replaced , tps
Ac delay after starting. mrmachinist 5th gen T4Rs 15 08-17-2019 08:03 PM
Delay in acceleration help newtonfb 4th Gen T4Rs 3 09-04-2018 10:00 PM
A/C Delay Manitou74 General Discussions 1 05-02-2015 12:02 AM
Slight Whining Noise coming from engine bay during acceleration samdajellybeenie14 3rd gen T4Rs 7 05-29-2012 11:32 AM
Slight Hesitation in Acceleration Nate613 General Discussions 0 09-13-2010 11:51 PM
