Old 02-02-2021, 11:20 AM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Starter Grind
Is there a how-to-guide on inspecting/replacing the starter on the 5th gen? Recently, I noticed an intermittent grinding noise when I start the car. Usually only happens during a cold start after sitting outside overnight.
Some forum members have suggested looking into the starter/flywheel, but I wasn't able to find any pictures or instructions specific to the 5th gen. Most of my search results came back for the 3rd gen.
Chilow is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 12:01 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
It's on the drivers side at the front of the transmission. You can see it through the wheel well. Easiest to access through the wheel well and from underneath, its held on with 2 or 3 bolts. It's the same as a 4th gen (which there are youtube videos), but a little less room to work with behind the exhaust.
Old 02-02-2021, 12:29 PM #3
Thank you! Would I be visually able to inspect it to confirm it's a starter issue? Since I'm troubleshooting a grinding noise, I was thinking I should look at the gears on the starter. Is this visible? I'll take a look at some YouTube videos for the 4th gen for now.
Old 02-02-2021, 01:16 PM #4
spartacus's Avatar
spartacus's Avatar
[QUOTE=Chilow;3599249]Is there a how-to-guide on inspecting/replacing the starter on the 5th gen? Recently, I noticed an intermittent grinding noise when I start the car. Usually only happens during a cold start after sitting outside overnight.
Some forum members have suggested looking into the starter/flywheel, but I wasn't able to find any pictures or instructions specific to the 5th gen. Most of my search results came back for the 3rd gen.[/QUOTE
pic, courtesy of @Ducmonsta
Starter Grind-screenshot_2021-02-02-10-09-17-1-jpg
Old 02-02-2021, 01:43 PM #5
spartacus's Avatar
spartacus's Avatar
Here is pic from the fsm.
Starter Grind-screenshot_2021-02-02-10-39-37-jpg
Old 02-02-2021, 02:21 PM #6
Hmm...I'm guessing I should just replace it altogether. Now that I think about it, I noticed the grinding noise one day after I drove through a puddle caused by a rain storm. The puddle was on the passenger side though. Could that cause it?
Old 02-02-2021, 04:28 PM #7
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Are you sure it is starter grind? A lot of people are having a short valve chatter on startup on cold mornings. Read through this thread:
Clank Sound Start Up
fkheath is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 04:31 PM #8
That was my initial thread but someone mentioned it could be starter grind, which made me create this thread. I do think it's starter grind and not the valve chatter based on the noise.
Old 02-02-2021, 04:44 PM #9
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I had a problem with my starter after driving through a deep river and then it freezing over night. I had my mechanic clean the contacts a couple of times and it finally is working ok. I think the freezing temps caused the water to stay on the contacts too long and rust. But no grinding noise, it just wouldn't start.
Like you I was thinking about replacing it but like you said very little information. I believe it is a PITA to get it out, so if you have the money have someone do it.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 02-02-2021, 04:47 PM #10
I don't have any starting issues, at least not at this time. It starts up how it always has. Just now with a grinding noise sometimes.
5th , gen , start , starter , starter/flywheel
Starter Issue - Grind/loud pop after engine fire shawski Classic T4Rs 12 04-01-2015 02:33 PM
Transmission Grind 94Runner4 4th Gen T4Rs 6 01-06-2014 02:37 AM
Breaks seem to grind? Stuck CAPS 4th Gen T4Rs 19 03-15-2013 11:43 AM
Brake Grind kchamber78 4th Gen T4Rs 5 06-08-2010 05:29 PM
4wd random grind! help! motorheadwannab 3rd gen T4Rs 3 07-26-2007 05:36 PM
