Old 02-02-2021, 05:58 PM #1
toolguy toolguy is offline
toolguy is on a distinguished road
power steering fluid type for 2016 4runner trail recommendations?
2016 Trail 4runner
noticed that my power steering fluid, is at minimum cold level.
cant be the only one with this question.
ive read other posts, but looking for current recommendations, or what others are using.
what are you using for power steering fluid?
owners manual says dex III, but local dealer, only have dex IV.
what are you using?
what is working for others?
thanks.
toolguy is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 06:03 PM #2
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
cheap supertech.. dont overthink this one dex III.. if it makes you paranoid then change it yearly to keep it a nice bright red.. its the cheapest, easiest, cleaniest fluid change ever..
1jzgte is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 06:05 PM #3
so no dex iii @ local dealer..
should i top off with toyota Dex IV?
Old 02-02-2021, 06:09 PM #4
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Just go to any parts store, or Walmart, and get Dex III. No reason to get Toyota brand fluid for something like this.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 06:10 PM #5
spartacus's Avatar
spartacus's Avatar
2016 Trail 4runner
what are you using?
thanks.
The dealer is wrong. Just get some dex-iii atf and top it off.
Old 02-02-2021, 06:16 PM #6
the power steering system doesnt work as hard as the transmission does.. DEX III will suffice..
Old 02-02-2021, 10:37 PM #7
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
1000+ psi???
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 12:03 AM #8
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Dex IV is just an upgrade over Dex III. Either will work well. Buy where you find the best price.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 12:50 AM #9
Whippersnapper02's Avatar
Per the manual:
power steering fluid type for 2016 4runner trail recommendations?-steering-jpg
Old 02-03-2021, 01:24 AM #10
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Yup thats what I use in my rig. Bought a gallon of the SuperTech DEXIII fluid. Killed half a gallon using a gas syringe taking all the old fluid out and putting in new fluid and turning the steering wheel several times. Just kept continuing the same cycle over and over for about 20 times. Took about an hour or less.
I’ll kill the rest of the gallon after 50K miles.
mcat707 is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 03:17 PM #11
Okay...i was asking about dex IV bc i have plenty of it leftover from a camry atf drain and fill.
Btw thanks for all the replies..always good to get a few different data points on what others are using
Any harm with using toyota dex IV?
Old 02-04-2021, 04:22 PM #12
spartacus's Avatar
spartacus's Avatar
Either use dex-iii or T- IV. If you already have dex-iii then drain and fill with T-iv My personal preference is not to mix different grades of oil. Don't want to open up the pendora's box of mixing different grades of fluid.
Old 02-04-2021, 07:29 PM #13
Right..meant to write T-IV
Thanks for the reply.
Im just topping off bc im at the low mark.
Ill change out the PS fluid later this spring
dex , fluid , power , recommendations , steering
Power steering fluid type? testrider 4th Gen T4Rs 25 09-23-2019 10:40 AM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Power Steering Fluid 2004 4Runner V-6 mac777daddy General Discussions 6 04-04-2009 02:00 PM
What kind of power steering fluid goes in an '86 4runner? scooter-phx Classic T4Rs 2 12-13-2005 11:53 AM
