11-09-2021, 12:05 PM
#31
Real Name: Ryan
Real Name: Ryan
I've been kicking around the idea of mounting these in the flat spot sports on each side of the rear spoiler. Not sure I want to cut into my spoiler quite yet though.
The other thing to consider is if you want to use them when the rear hatch is open, that location won't work.
11-09-2021, 01:03 PM
#32
Rear Mounted Pod Lights
Nice… really like Diode Dynamics. Agreed, I’d hate cutting the spoiler. And ya, my set up is useless with the hatch up. (I installed bright DD LEDs to replace the OEM hatch lights… good enough for now at a campsite, etc.)
11-09-2021, 01:49 PM
#33
Real Name: Todi
Real Name: Todi
Originally Posted by DriftingOverland
Scroll through this “candy” store of aluminum parts.
TNUTZ
I’ve purchased several bits and pieces, including the 8020 (seen here) used by many of the roof rack companies.
+1 on TNUTZ; fast service, good prices and now they are running all bunch of specials on cross bars
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
11-09-2021, 04:33 PM
#34
TNUTZ
this x2. heck they even sell little zip tie holders that slide in the crossbars. invisible zip ties!
11-09-2021, 07:42 PM
#35
Oh my. These things? Those are brilliant. I now need to re-do all the wiring in my roof rack.
@ DriftingOverland
- do those clear lights in your picture illuminate the back without getting too much blocked by the rear spoiler?
11-10-2021, 04:09 PM
#36
@ DriftingOverland
- do those clear lights in your picture illuminate the back without getting too much blocked by the rear spoiler?[/QUOTE]
Somewhat. I couldn’t tell you the actual angle. They aren’t too bad for my application.
And YES Honda… can’t see any of my wiring unless you know where to look .
11-10-2021, 04:13 PM
#37
@ DriftingOverland
my s2's are mounted on the under side of the rear cross bar and theyre great as dust lights but not as area lights unless youre away from the back. off the side angled down would prolly work better as an area light for the back. but i wanted low profile and only as dust lights
11-10-2021, 06:24 PM
#38
This
11-10-2021, 06:30 PM
#39
Following
11-11-2021, 12:25 AM
#41
TNUTZ
did you use a specific harness to wire this or did you piggy back off of another harness?
11-11-2021, 09:33 AM
#42
he said its tied to his switch pro's.
mine are ran down the passenger side of the rack, under the windshield weatherstrip and to a relay, battery, fuse, then inside to a OEM style switch. I bought some heat shrink fabric to cover the wires from one end of the roof rack to the other. turned out pretty decent. it was a pain shoving 2 wires into it though.
11-11-2021, 10:56 AM
#43
Built my own. Ran wiring along the 8020 to the driver’s side. Then down into the rubber boot/OEM wiring under the spoiler and into the rear left pillar. From there I ran the leads down the left side of the rig up and through the firewall to the Switch-Pros.
Someday I’ll do a “build” page.
11-11-2021, 12:17 PM
#44
I got a pair of Baja cornering lights that are 2500 lumens for setting up camp and backing down narrow roads if needed. I mounted them to a magnetic mount so they can be placed in a few locations or rotated.
The magnetic mount can hold 55+lbs
And with the quick release i can move the lights around or disconnect and move them to the front of my 4R and use them as ditch lights.
I am prewired for ditch lights up front with a switch so i can simply unplug the lights and remove them with the magnets from the rear then mount them magnetically to the hood up front as ditch lights. But i can also just rotate these forward and use them as ditch lights from the back since they are super bright. So incredibly versatile, i am glad i went with the magnetic mount and the super small bright Baja's.
11-11-2021, 02:28 PM
#45
I’ve been playing around with amber chase light options for traveling in dusty conditions. I think rubber covered magnetic mounts make sense.
Before a group trip, I wasn’t prepared to mount something permanent, so I bought an amber emergency light from Amazon for about $18 bucks. You can run the power down the side of the hatch to the rear 12v socket.
Amazon sells a variety of magnetic light bars.
I am also playing around with a pair of Rigid pod lights with magnetic mounts.
2020 TRD ORP with KDSS. 285/70 17 BFG KO2s. Bilstein 5100s w/ stock springs on top perch in front, and Bilstein lift springs in rear. SPC UCAs. RCI rock sliders. C4 Fab Low Profile front bumper with Smittybilt H20 12k winch. Factor 55 Flatlink E. RCI roof rack, Baja Designs and cheap Amazon led lights, Switchpro 9100, BeyondWraps hood scoop stamp.
