Old 02-02-2021, 11:04 PM #1
transistor's Avatar
transistor transistor is offline
transistor is on a distinguished road
transistor's Avatar
Installed the Anytime front camera and now my A/C stays on when the vehicle is off
I bought the harnesses a couple years ago and finally got around to installing it today. Thought I followed the directions, but I must have done something wrong. What could I have messed up to allow the A/C to work with no key in the ignition?
transistor is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 11:24 PM #2
transistor's Avatar
transistor's Avatar
Evidently, the 12v source has to be an ignition wire, not a direct connection to the battery? Still confused why it would matter in this case.
Old 02-02-2021, 11:31 PM #3
spartacus's Avatar
spartacus spartacus is online now
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
How can the ac run without the motor running? not possible because the compressor pulley has to be engaged by the drive belt.
spartacus is online now   Reply With QuoteReply With Quote
Old 02-02-2021, 11:35 PM #4
spartacus's Avatar
spartacus's Avatar
It's probably the blower motor. Either the blower motor resistor is bad or blower motor relay. Some where along that circuit.
Old 02-02-2021, 11:52 PM #5
transistor's Avatar
transistor's Avatar
But I disconnected the 12v line from the battery to the camera relay and it no longer blows. I can't understand how this could be affecting the blower.
Old 02-03-2021, 12:26 AM #6
spartacus's Avatar
spartacus's Avatar
Not sure why but it's energizing the blower motor when you hookup the dash cam. Will have to look at the wiring diagram and how you have it hooked up.
Old 02-03-2021, 12:36 AM #7
Whippersnapper02's Avatar
Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light
Could be the ground you chose. Disconnect the lighting and see if it does it.
Old 02-03-2021, 01:35 AM #8
transistor's Avatar
transistor's Avatar
the switch backlighting?
Old 02-03-2021, 01:45 AM #9
SarcasticSOB SarcasticSOB is offline
SarcasticSOB will become famous soon enough
I am no expert on the wiring involved in this, but the fan is most likely connected to an ignition on only circuit and perhaps you somehow shorted the new camera lead to that ignition on circuit causing it to be live always.
SarcasticSOB is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 02:41 AM #10
Nevermind. I forgot that I used a different switch.
What year is your vehicle? Perhaps the wiring is slightly different. Toyota loves doing crap like that.
Old 02-03-2021, 12:52 PM #11
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
i'd be very concerned that you're energizing something that you shouldn't be, even if relocating the power source fixed the problem
jhguth is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 02:50 PM #12
ElectroBoy's Avatar
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
ElectroBoy's Avatar
Real Name: Mark
Check all of your wiring connections. You connected something wrong.
I sympathize with you. The instructions and wiring diagrams of the Anytime camera kit are not the best.
1st Gen 1987 T4R, sold at 180K miles
3rd Gen 2000 SR5, sold at 239K miles
5th Gen 2018 ORP, just interior mods
Old 02-03-2021, 04:12 PM #13
Saker's Avatar
Saker Saker is offline
Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold
Saker's Avatar
Remove everything you hooked up!
Research your connections, and start over, period!
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 02-03-2021, 04:21 PM #14
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Bingo. For some reason I feel convinced this is likely the culprit.
However! Know the anytime camera peeps change up the wiring. I ordered on camera with a harness and literally no less than 6 months later I had to order the harness again and this time it was slightly different. BUT, the new harness was actually better than the previous one so I didnít have a problem with it. It was actually easier to hook up.
umidkusername is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 04:24 PM #15
T4RUNNER02's Avatar
T4RUNNER02 T4RUNNER02 is offline
T4RUNNER02 is on a distinguished road
T4RUNNER02's Avatar
At least you have a really Cool camera!
T4RUNNER02 is offline   Reply With QuoteReply With Quote
a/c , installed , thought , today , wrong
Anytime Backup Camera and Front Camera - February 2017 Group Buy bjohnston115 Group Buys 101 05-06-2020 11:39 AM
Anytime Backup Camera/Front Camera Group Buy ***CLOSED*** bRYANT619 Group Buys 160 03-14-2020 10:00 PM
Anytime back up camera with front camera boyguan 5th gen T4Rs 13 11-20-2017 11:20 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
