Old 02-03-2021, 12:29 AM #1
BobWheelerJr BobWheelerJr is offline
Real Name: Bob Wheeler Jr
BobWheelerJr is on a distinguished road
Question Best oil for the 2014 Limited?
I believe there are two engines, and mine is the bigger of the two. Just bought this and it's time for an oil change. I want this thing to run forever, so what do y'all recommend?
BobWheelerJr is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 12:34 AM #2
Whippersnapper02's Avatar
Any off the shelf oil of the correct viscosity.
Old 02-03-2021, 01:07 AM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
What does your owners manual say? Mine specifies 0W-20, however it also has this text, "An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions."
Do you regularly operate your vehicle under any of the special conditions listed in the manual? I've taken the hint to use a slightly higher viscosity such as a 5W-30 or 10W-30, especially because of trips from Phoenix to Flagstaff (elevation change 1200 to 7200 feet with grades ranging from 4-6%) at speeds of up to 85 MPH during the hottest days of summer. (Phoenix set new temperature records of 53 days above 110 and 14 days above 115 in 2020.)
If you want more details, consider searching for 1GR-FE posts written by Bryanccfshr on other forums. He lives in Texas and drives under special operating conditions. It appears he knows a lot about engine oils, history of oil specifications and history of Toyota engine design. He doesn’t use 0W-20.
DougR is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 01:24 AM #4
spartacus's Avatar
spartacus's Avatar
Use the 0w20 oil that is specified Mobil one is a good choice Toyota oem is also good or something that you can afford, If you off road or tow replace it between 5k and 7k miles if not you can go up to 10k. Make sure to replace the filter every oil change.
Old 02-03-2021, 01:53 PM #5
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Whatever with the correct viscosity that is on sale
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 02:00 PM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Your engine is the exact same as every other 5th gen.
0w-20
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 03:08 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
2 engines?
Old 02-03-2021, 03:37 PM #8
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Originally Posted by flyrv9 View Post
2 engines?
Slow, and slower.
Noisy, and noisier.
Outdated, and more outdated.
delloro is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 05:53 PM #9
Nice rig. How much was that front bumper, installed, and would it screw up the weight distribution with a 2" lift?
Old 02-03-2021, 05:54 PM #10
0w-20
I was under the impression there was a 3.7 and a 4.7 liter.
Old 02-03-2021, 05:56 PM #11
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
None of the above. The only motor available in a 4Runner since 2010 is the 4.0 liter 1GR-FE.
5thToy is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 06:13 PM #12
flyrv9's Avatar
flyrv9's Avatar
The 4.7 V8 was available in older 4 Runners; but not in the 5th Gen. I have a 4.7 in a 2000 Tundra; and it's been a good reliable engine. In 21 years I've had very few issues: I've replaced 2 coil packs and that's it for problems. I did change the timing belt and water pump at 90K as suggested.
The 4.0 V6 in my 2013 4Runner has been bulletproof so far. A good reliable engine with no issues over 35K miles. Being retired, we don't drive much. Trips have been great with fair mileage as most are seeing.
I have used all recommended by Toyota fluids with no issues. I figure they know more than I do!
Old 02-03-2021, 06:16 PM #13
pDubs's Avatar
pDubs's Avatar
Nope.
Maybe you are confusing 4th gens, which there was a 4.0 V6 and a 4.7L V8
edit: flyr beat me to it.
I would stick with 0w-20. Toyotas (and the 4runner in specific) are some of the most reliable vehicles on the planet and the engineers recommendations for oil is what I will always stick with.
2014 SR5P
Old 02-03-2021, 07:12 PM #14
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
There was a 2.7 I-4 available in the 2wd SR5 in 2010. But it didn't sell well, and was discontinued.
02SE is offline   Reply With QuoteReply With Quote
Old 02-03-2021, 07:26 PM #15
That's right. I forgot about that one.
forever , oil , run , time , yall
2014 Trail Premium Red Barcelona VS 2014 Blizzard Pearl Limited Edition Gursi Tiwana 5th gen T4Rs 39 01-02-2016 05:57 PM
2014 trail wheels on 2014 limited mag grey ? rok medic 5th gen T4Rs 17 12-09-2015 01:17 AM
FS 5th gen OEM running boards for 2010-2013 SR5/limited and 2014-15 limited Dsgoat For Sale: T4R Items 1 10-31-2015 07:24 PM
2014 Grand Cherokee Overland vs. 2014 Toyota 4Runner Limited forwheeler 5th gen T4Rs 2 04-17-2014 03:36 PM
