Old 02-05-2021, 12:01 PM #16
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is a jewel in the rough Cymon is a jewel in the rough Cymon is a jewel in the rough Cymon is a jewel in the rough
Cymon's Avatar
Real Name: Chris
I don't know what kind of trailer you have, but IMO a better approach may be to mount solar panels on your trailer if possible and wire them to the battery. That way it will charge when towing and continue to charge while parked at camp. It will also keep the battery topped off if you park your trailer outside between trips.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 02:47 PM #17
4r-4ever 4r-4ever is offline
4r-4ever is on a distinguished road
i used a 6 gauge wire for my setup from the battery to the back of my 4runner. here's my portable dual battery setup. i use dc-dc redarc charger, 25Amps. to the op, in your case you need to use a 4 gauge wire. see my video, not too much but enough to get some idea. https://www.youtube.com/watch?v=ZbVtZvK-f9s
4r-4ever is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 02:53 PM #18
in your case, you need to wire another positive (you need to fuse it too) from the car battery under the truck and make sure to use a wire loom and secure it to the body and at the end of the wire, install an anderson connector.
Originally Posted by Johncmng View Post
Hi all,
How do I run high current wires from my alternator to a a trailer that I am towing? This will be for my LIFEPO4 battery in the battery box of the trailer. Maximum current will be around 180Amps. Do I run the wires under the truck? If so, what kind of wire insulation is best to cope with the environment?
TIA
Old 02-09-2021, 07:30 PM #19
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
why are you recommending a wire gauge without knowing anything about the charging capacity of whatever charge controller he is using?
jhguth is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 07:53 PM #20
honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light honda250xtitan is a glorious beacon of light
so you want to trickle charge your battery on the trailer? youre way over thinking this.....
2016 TE : Grocery Getter, 285/70R17 Cooper at3 XLT, Prinsu Rack, King Coilovers, DuroBumps, Wheelers T13 coils, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA
2017 F250 6.7: Carli, Fox, Raceline, BajaDesigns, DIY Retrofit headlights
Old 02-10-2021, 04:03 AM #21
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is a jewel in the rough Friggin Idiot is a jewel in the rough Friggin Idiot is a jewel in the rough Friggin Idiot is a jewel in the rough
Real Name: Luke
180amps?! WTH are you trying to do, charge a Tesla while you haul it cross country?!
I also very much hope that you already have the DC Power & Engineering 270amp alternator installed. Otherwise drawing that much power, even on surge, is going to kill your truck battery and/or the OEM alternator eventually. Even with the 270A you're going to need "the big three upgrade" AND a dedicated run to the trailer to handle that level of amperage. Obviously the 7-pin trailer connector isn't good enough as it's only fused at 30A.
@Discovery ran an 8AWG line with Anderson connectors to his trailer seen in this thread.
How big of a cable you need for the 180A at 14v is really a question of length. I always try to use a voltage drop calculator like this one. Just ensure you've got it set to DC 14v at the start, and to account for any vertical distance as well as horizontal. You can change the cable size and watch the voltage drop increase or decrease. Remember that LiPO usually require 13.5+v in order to charge properly, so you're not going to have much tolerance for that voltage drop. Having the LiPO near the tongue of the trailer will simplify your voltage problem by reducing the overall distance.
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 03:19 PM #22
Johncmng Johncmng is offline
Johncmng is on a distinguished road
Thanks all for your comments. I'm building a LIFEPO4 battery pack with a 180A BMS. And yes, I have upgrade my alternator to handle the current output. My thinking is that after a few days camping in one spot, I only need to drive about 2 to 3 hours to fully top off the batteries. Specifically I was asking how I should route the wires to the hitch. Do other people zip tie the cables to the frame? What other method is best to secure the cable? Where along the frame is best to mount the wire?
TIA
Johncmng is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 07:47 PM #23
TIA
having a 180A BMS does not mean that you can just connect it to your vehicle in a dual battery setup and charge at 180 Amps, you still need a DC-DC charger that is rated for Lithium and the amperage capacity of the wiring will need to match the charging capacity of your DC-DC charger
Old 02-11-2021, 09:40 AM #24
Tbasse01 Tbasse01 is offline
Real Name: Troy
Tbasse01 is on a distinguished road
Real Name: Troy
Lol
You hit the nail on the head lifep04 batteries have a circuit (built into the battery) to control charge and discharge rates
You could put a million amps and 2 million volts at it and the on board circuit controls the Amps and voltage rate... So most of these batteries have like a peak 20 amp charge at 60% DOD . What are you going to do with the extra 160 lol
Troy
2016 limited midnight metallic black
68k | LED headlights/fogs | remote start | block heater | LED interior
New to me
Tbasse01 is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 11:23 AM #25
delloro's Avatar
delloro delloro is offline
delloro is a jewel in the rough delloro is a jewel in the rough delloro is a jewel in the rough delloro is a jewel in the rough
delloro's Avatar
Originally Posted by Tbasse01 View Post
Lol
In case ha wants a spectacular meltdown. Need amps for that. 20A is meh.
delloro is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 12:43 PM #26
he specifically mentioned 180Ah and wanted to put it on a trailer. i would say he will need around 25-30 foot wire from the front to the trailer. a 6 gauge wire is what is needed and a 25A dc-dc charger and a 6 gauge wire.
in my case, i have another agm battery with at least 70Ah and i use a redarc 25A dc-dc charger to charge it and used only 15 feet of wire and it works really great during my road trip. the op i think still don't understand it yet but he will once he starts his project.
Old 02-11-2021, 01:14 PM #27
he actually said 180 Amps, that's why everyone is confused
(and didn't say he has a 25A dc-dc charger)
Old 02-11-2021, 02:32 PM #28
Lol
I have a Daly BMS charger that is capable of charging LIFEPO4 at 180Amp at the correct voltages. The battery is capable of handling 280Amps of charging.
Old 02-11-2021, 08:42 PM #29
probably the discharge rating, but more importantly you still need something protecting your starting battery
Old 02-12-2021, 03:01 PM #30
My discharge rating is at 208Amps! Yes, I will be protecting the starter battery.
battery , current , run , trailer , wires
trailer wires hook-up- horrible design Northern Cruiser 5th gen T4Rs 18 08-25-2020 11:16 AM
Running high current lines to cargo area GrantK 5th gen T4Rs 13 07-18-2019 06:31 PM
96 What Color Wires for High/Low Beam From Stalk reelamin 3rd gen T4Rs 6 02-15-2015 03:48 PM
Trailer wires burning out fuel gauges repo 3rd gen T4Rs 0 11-19-2014 03:10 PM
Denso Wires VS NGK Wires (not what ya think) Justin727 3rd gen T4Rs 2 04-21-2010 02:55 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
