Old 02-12-2021, 03:11 PM #31
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
Are you sure you are doing it right?
Originally Posted by Johncmng View Post
I have a Daly BMS charger that is capable of charging LIFEPO4 at 180Amp at the correct voltages. The battery is capable of handling 280Amps of charging.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 03:41 PM #32
Johncmng Johncmng is offline
Johncmng is on a distinguished road
What am I doing wrong? The BMS should be able to charge at the correct voltages and current. And the batteries I have are well over the limits of the BMS. Should I connect the BMS to a DC/DC charger? What are the disadvantages or dangers of connecting the BMS directly to the alternator?
TIA
Johncmng is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 04:29 PM #33
are you building your own lifepo4 battery with bms on it? give us the details on what hardware you currently have.
TIA
Old 02-12-2021, 04:44 PM #34
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Per your original question about wire, I would research someplace like WiringDepot. Maybe Marine wire or SXL Cross-Linked wire. Consider enclosing it in sheathing or some kind of flexible conduit if running it externally.
Wire & Cable
Old 02-12-2021, 08:09 PM #35
This one is similar to the one that I have but with 250Amps.
Amazon doesn't have the 180A that I got awhile back.
Amazon.com: DALY BMS 4S 12V 500A LiFePO4 Battery Protection Module PCB Protection Board with Balance Leads Wires BMS for 18650 Battery Pack 12V with Cooling Fan: Electronics
Old 03-28-2022, 10:32 PM #36
rovwel rovwel is offline
rovwel is on a distinguished road
I am looking at the thread and still do not see the answer to the question of what is the best path to run cables from the battery to the back of the car,
I am getting started on my project where I have a DC Power Alternator running through a CB and relay to an Anderson connector on the rear of the car.
The Alternator is installed but still have not found the perfect path to run the cables. My trailer has 2- 100 amp LiFe batteries and 2- 30 amp Victron Orion Smart controllers, and will be a 50 ft run, So the cable is quite large ( 2/O) and I still want to protect it .
Any Pictures?
rovwel is offline   Reply With QuoteReply With Quote
Old 03-29-2022, 11:55 AM #37
you are right. i made some assumption without knowing the details.
Originally Posted by jhguth View Post
why are you recommending a wire gauge without knowing anything about the charging capacity of whatever charge controller he is using?
Old 03-29-2022, 12:07 PM #38
the best path for your wiring is through the frame. inside will be best to protect it from the elements, outside too is okay and use a wireloom and zip tie it and make sure it's not loose anywhere. make sure it's not in the way when you need to do maintenance to the car.
Any Pictures?
Old 03-29-2022, 01:46 PM #39
Thanks,
This is good direction, So far I saw a YouTube video of a F150 job yesterday. The cables are big and if done right could be fairly clean.
Before posting, I Put my T4R on the lift and took a 5 minute look and decided this would need some research and experience of others to do it the cleanest way possible. On my trailer I used stainless cable clamps and drill tapped machine screws into the frame for the power and tie-wrapped the ground to it, Keeping it inside the frame so it would never ground out .
How do I run high current wires to my trailer?-20211004_122521-jpg  How do I run high current wires to my trailer?-20220220_174006-jpg
battery , current , run , trailer , wires
trailer wires hook-up- horrible design Northern Cruiser 5th gen T4Rs 18 08-25-2020 11:16 AM
Running high current lines to cargo area GrantK 5th gen T4Rs 13 07-18-2019 06:31 PM
96 What Color Wires for High/Low Beam From Stalk reelamin 3rd gen T4Rs 6 02-15-2015 03:48 PM
Trailer wires burning out fuel gauges repo 3rd gen T4Rs 0 11-19-2014 03:10 PM
Denso Wires VS NGK Wires (not what ya think) Justin727 3rd gen T4Rs 2 04-21-2010 02:55 PM
