Old 02-05-2021, 06:22 PM #16
Dollar Retriever Dollar Retriever is offline
Dollar Retriever is on a distinguished road
Originally Posted by Whippersnapper02 View Post
Caster can affect return to center.
Mine is
0.3 Camber 0.2
4.4 Caster 4.3
0.09 toe 0.10
For caster there is a 0.1 of difference, does it matter?
Dollar Retriever is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 06:34 PM #17
Jeremy556's Avatar
Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about
Jeremy556's Avatar
Try swapping your front tires and see if that changes anything. Those alignment numbers are decent and with the toe in and over 4 degrees caster it should self center just fine.
0.1 degree difference in caster is nothing to worry about or noticable.
Old 02-05-2021, 06:36 PM #18
Jeremy556's Avatar
Jeremy556's Avatar
Originally Posted by Dollar Retriever View Post
Oh. The shop didnít do this I am sure for that
You would only need to do that if your steering wheel was off center when the vehicle is driving straight on its own. If you are having to steer to make it go straight, it is not just a steering wheel centering adjustment.
Old 02-05-2021, 06:41 PM #19
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
SAI - Steering Angle Inclination
Ask the shop to check this. If itís within spec, your steering should turn itself back to center when you release the steering wheel after a turn.
engeeoh01 is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 10:56 PM #20
Yes I hold steering wheel and keep it at centre position, car goes straight, no problem.
But I release it or reduce the force that holding steering wheel, my car goes right and steering wheel turns as well.
Seems there are 2 unequal forces on the 2 sides of the car.
Old 02-05-2021, 10:57 PM #21
Okay. Thank you! I will swap my tires this weekend
Old 02-05-2021, 10:59 PM #22
I will double check on this one.
Thanks!
position , steering , ucas , upgrades , wheel
wobbly steering wheel TE? should I upgrade? user name: 5th gen T4Rs 32 09-18-2016 11:30 AM
Steering Wheel doesn't self Center achha64 3rd gen T4Rs 5 04-21-2014 09:55 PM
Steering wheel upgrade with controls kameleon Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-10-2013 01:57 AM
Key doesn't want to go into LOCK position duffbeer911 3rd gen T4Rs 5 06-24-2013 09:32 AM
steering wheel upgrade - possible? nauticalniremor 4th Gen T4Rs 6 05-09-2007 01:47 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
