Old 02-05-2021, 01:29 AM #1
Dollar Retriever Dollar Retriever is offline
Dollar Retriever is on a distinguished road
Steering wheel doesn’t go back to centre position after shocks and UCAs upgrade
Hi everyone,
I got installation of new shocks and UCAs.
After upgrades I noticed that my steering wheel can’t go back to centre position/ 12 o’clock position.
When I am driving I release my steering wheel it pull/turn right slightly.
I have checked alignment specs I am in specs.
Pretty confused any other things can cause that?
Did I get lemon job for my upgrades?
Thank you all!
Dollar Retriever is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 01:41 AM #2
spartacus's Avatar
spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all spartacus is a name known to all
spartacus's Avatar
Originally Posted by Dollar Retriever View Post
Hi everyone,
Thank you all!
More caster will usually solves that issue.
Old 02-05-2021, 07:26 AM #3
DigitalVex DigitalVex is offline
DigitalVex is on a distinguished road
Sounds like you just need to adjust the tie rods. Shop should have done this, but you can, too:
How to Center my Steering Wheel
DigitalVex is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 07:57 AM #4
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
A lot of us have a pull to the right even when aligned, myself included. I have no noticeable tire wear as a result, but I do have to counter steer.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 09:16 AM #5
xcalbr2 xcalbr2 is offline
xcalbr2 is on a distinguished road
right pull...
Could this be caused by the rear axle being off center some?
Would be nice to fix this.
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 10:57 AM #6
glwood54 glwood54 is offline
glwood54 is on a distinguished road
Hi everyone,
Thank you all!
It's not stated specifically, so the question - did you get an alignment done after the installation?
glwood54 is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 12:05 PM #7
fkheath fkheath is offline
fkheath has a spectacular aura about fkheath has a spectacular aura about fkheath has a spectacular aura about
This will sound strange to some people, but some states, including mine, REQUIRE a vehicle to be aligned so it pulls to the right. The reason, is if you fall asleep, the car will drift off the road instead of into oncoming traffic.
Even if aligned right on a flat surface, a car will pull to the right due to the crown they put on roads to better drain water off.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 12:58 PM #8
Jeremy556's Avatar
Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about
Jeremy556's Avatar
Post your alignment measurements.
Old 02-05-2021, 02:55 PM #9
Whippersnapper02's Avatar
Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light Whippersnapper02 is a glorious beacon of light
Caster can affect return to center.
Old 02-05-2021, 06:11 PM #10
According to the paper. Caster now is 4.4 4.3
It needs to add more?
Old 02-05-2021, 06:12 PM #11
Oh. The shop didn’t do this I am sure for that
Old 02-05-2021, 06:14 PM #12
Yes. Sometimes I feel that I am pretty weak, I can feel that I use a significant force to counter steering wheel
Last edited by Dollar Retriever; 02-05-2021 at 06:15 PM. Reason: My English is bad
Old 02-05-2021, 06:16 PM #13
X
Not sure about this. How to check rear axle off centre?
Old 02-05-2021, 06:19 PM #14
The shop checked alignment, I am in specs so they didn’t adjust alignment.
Front
0.3 Camber 0.2
4.4 Caster 4.3
0.09 toe 0.10
Old 02-05-2021, 06:20 PM #15
Front
0.3 Camber 0.2
4.4 Caster 4.3
0.09 toe 0.10
Rear is unknown
position , steering , ucas , upgrades , wheel
wobbly steering wheel TE? should I upgrade? user name: 5th gen T4Rs 32 09-18-2016 11:30 AM
Steering Wheel doesn't self Center achha64 3rd gen T4Rs 5 04-21-2014 09:55 PM
Steering wheel upgrade with controls kameleon Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-10-2013 01:57 AM
Key doesn't want to go into LOCK position duffbeer911 3rd gen T4Rs 5 06-24-2013 09:32 AM
steering wheel upgrade - possible? nauticalniremor 4th Gen T4Rs 6 05-09-2007 01:47 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
