Old 04-08-2021, 04:35 PM #16
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
@mbumpus11 - great write up thank you!
@ElectroBoy - I was thinking about the same sort of mod (for scene lighting in the back when I am dispersed camping and I noticed that @Phil Frames had done a similar thing but at a lower point in the bumper. Note he says that bumper removal isn't required, if that's a concern.
I can't tell what lens he used, but you can get work/scene lenses for the S2 that covers 120 degrees, so you'd get uniform coverage I suspect.
Also, an alternate route you can use for the wire is inside the frame rail. There are holes near the engine and in the back so you just need some fish tape/sticks. I've talked to a few people that went that route. Not sure it's necessary - what the OP used is pretty solid (the BD extensions already come sheathed so he effectively doubled up) - but another option.
Originally Posted by ElectroBoy View Post
Thank you for these instructions, good work.
The lights sure are bright.
A few of questions:
1. My biggest apprehension is bumper removal. Do you have instructions for how to do this?
2. You ran the wires externally. Did you consider a way to route wires through the cabin and out to the bumper?
3. Connecting the wires to the lights. Did you make the connections first then install the bumper, leaving some slack? Then tie wrap the excess wire?
4. Is there slack, or an inline connector, so you can remove the bumper in the future without breaking the wires to the lights?
rageandlove is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 03:30 PM #17
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Yep - I used the work/scene lens for that wide throw of light...these are meant for near field vision while reversing, and/or when behind the truck using it for trailers/night camping setup light/worklight at the ranch/etc.
Do you have examples of the wiring through the frame rail?? I had thought about that, but didn't really explore very far due to thinking I was losing my mind and getting "too creative," haha.
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 11-03-2021, 06:53 PM #18
@mbumpus11
So sorry I missed this. Somewhere I found a thread where someone had pictures. Can't find it again. But it was pretty simple - they used cable fish sticks and threaded the wire into a hole in frame rail on the driver side of the car (there are a bunch of holes facing the spare) and then had it emerge around the front shock where they fed it up into the engine compartment where it attached to a Switch-Pros.
I have a friend that's done the same thing on a Tacoma.
Looks pretty easy. Still pondering how to put lights on the back (I love what you have done but I'm too chicken to cut my bumper so fiddling with my Sherpa roof rack) but I think it would be easy enough if I went the bumper route in the end.
Old 05-17-2022, 03:48 PM #19
Slvr5Spd Slvr5Spd is offline
Slvr5Spd is on a distinguished road
Thanks for the write up. Following your lead I copied your wire run and hook up. I did modify it a bit. I used the Nilight waterproof plugs with all soldered connections.
Slvr5Spd is offline   Reply With QuoteReply With Quote
flush , led , mount , pod , rear
FS Rigid SR-M Flush Mount Backup Lights - $150, Austin, TX Dark Lord For Sale: Non-T4R Items 3 07-08-2020 12:05 AM
3G4R_Thundercloud's Rear Hatch Lights Write-Up SilverBullet8404 3rd gen T4Rs 5 07-04-2020 05:45 PM
Rear-facing aux lights - Outside mount or inside mount? Nashvegas34 3rd gen T4Rs 1 02-21-2012 08:14 PM
Flush Mount rear view camera RR90 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-14-2010 01:30 AM
Looking for pics / write ups of rear fog lights Lowpro 4th Gen T4Rs 1 12-24-2008 08:47 PM
