Old 02-12-2024, 03:32 PM #61
Blackgoat Blackgoat is offline
Blackgoat is on a distinguished road
Originally Posted by suvman View Post
Thanks for all the important information.
I have experienced the same bunch or warnings in my 2021 highlander and the dealer replaced my battery and now wants to replace brake switch. I looked under my car at the wiring for my Curt trailer hitch to discover that the ground wire for the Curt taillight converter had broken off and was dangling. I re attached white wire to ground, and have just driven 30 minutes with no warning messages.
I hope this can help others with this perplexing problem.
I will update if there are any changes.
Two days and still working fine. The Curt trailer adapter module was somehow interfering with the brake voltage when the ground wire came loose.
Make sure that is not just what they are telling you!!!
It is a known issue from what I hear..
Blackgoat is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 03:36 PM #62
YotaTurd YotaTurd is offline
YotaTurd is on a distinguished road
I don't have this issue with my 2018 TRD Off-Road.
Never had it with the 2014, the 2010, or the 2006 4runners either.
It seems to have started with the 2021 Toyota models.
YotaTurd is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 01:42 PM #63
Originally Posted by YotaTurd View Post
I've had a rear-wheel speed sensor replaced because that was Toyota's initial diagnosis. They erased the codes as well, but it didn't last long before the issue popped up again.
It went back to the dealership where they then diagnosed it as a problem with the "ABS Brake actuator." Actuator was replaced and they cleared all the codes again. This appeared to work and things were good for about 5-6 weeks, until the same problem has popped-up yet again.
Right now, it's an intermittent issue. The alerts may come on (which subsequently results in various systems being disabled) but then it may go off and all is good. Sometimes it takes a few minutes, sometimes they are on for days.
Toyota really needs to find a fix to this problem, as we are seeing it more an more. So far every "solution" they have come up with has not been a permanent fix to the real issue.
UPDATE: The FIX: It appears as though the root of the issue is a "rear-wheel speed monitoring problem." The Toyota Tech and Engineer did a "live data" road-test and discovered that one of my rear wheel speed sensors was cutting in and out randomly. After another quick inspection it was determined that the sensor itself was fine.
(...no surprise, as that was recently replaced a few months earlier.) A continuity test confirmed it.
Working backwards from there, they identified the problem was, in fact the "rear wheel ABS harness assembly." Turns out the boot that connects to the wheel sensor itself was quite corroded, from obviously getting wet/snow/etc. Now this shouldn't actually happen if the boot sealed appropriately where it connects to the sensor, but this isn't happening. Once corrosion gets in it can really mess up the continuity of the harness. (Again, continuity tests confirmed the actual harness was the problem.)
Toyota replaced the harness and we're all good now. They added a lot of extra dielectric grease to ensure that things sealed up better when connecting to the main harness and the wheel speed sensor.
This is clearly a faulty design of the rear ABS harness. If a good seal cannot be attained, it will always be susceptible to corrosion ..... thus, if they continue to use the same part without re-designing a better solution, it will likely continue to happen again and again, over time.
This is on Toyota, so if it happens again, even if I'm off warranty, they will be responsible. Gotta love electronics. All this from a little corrosion.
Old 03-23-2024, 09:42 PM #64
RichN RichN is offline
RichN is on a distinguished road
This appears to have been a pretty common problem in 2020 and 2021. Does anyone know if this carried into the 2022 and/or 2023 model years?
"They who would give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
- Benjamin Franklin
"So this is how liberty dies; with thunderous applause."
- Senator Amidala (Star Wars III: Revenge of the Sith)
RichN is offline   Reply With QuoteReply With Quote
Old 03-23-2024, 09:57 PM #65
The problem ...and the "fix" I've posting about happened on my 2022 model year. So it's definitely common problem, from 2020 through 2022.
(Sorry, I can't say if it's affecting 2023 models or not, though.)
Old 04-10-2024, 06:25 PM #66
It look like there is more than one cause for this, but some of them are from damaged or corroded wheel speed sensors. Would these help or just trap more gunk and make them corrode even faster?
Jomax Customs
- Benjamin Franklin
Old 04-18-2024, 06:57 PM #67
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
I got all these codes today plus the check engine - 5 different codes on my '23 with 6k miles. I've never even put it into 4WD yet, haven't gotten first oil change yet. My '98 4R SR5 has almost 300k miles and has been to hell and back has never thrown a code in the 24 years I've had it.
Paid almost 60k for this new one and dealer says they need to replace the accelerator pedal assembly, not sure if it's under warranty - the Stealership will let me know, I didn't buy any extended warranty - didn't think it would crap out this soon, ridiculous
98 T4R SR5 V6 4x4
23 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
braking , dealer , driving , it’s , visit
Crawl and hill start malfunction? trdpro2016 Problems & Warranty Issues 0 11-03-2014 06:14 PM
Hill-start Assist Control (HAC) malfunction? MeetJoeAsian 5th gen T4Rs 4 03-12-2012 01:21 PM
Traction Control Malfunction??? glock56534 4th Gen T4Rs 8 06-07-2011 12:44 AM
vsc trac control malfunction tozar 4th Gen T4Rs 1 07-21-2010 03:50 PM
'03 Hill-Start major malfunction! hammersmith 4th Gen T4Rs 49 04-03-2003 12:45 PM
