02-07-2021, 05:45 PM
Suspension replacement need to know
i have a 2011 TR4 SR5 with 4WD with about 140K miles. Its in need of new shocks. I really have no idea where to start. I would like to maybe add a 1" lift to it but I dont want to have to do anything else. Can I buy new shocks that accomplish this or is this some separate that needs to be done. Also what brand and model would everyone suggest? Do I need to replace the springs as well? See lots of questions...a link to better instructions and options. Thank you in advance
02-07-2021, 07:23 PM
Real Name: Howard J. Turkstra
You will get lift from either different springs or spacers for the stock springs. Shocks won’t give you any lift by themselves.
If you’re looking for only 1” of lift, I would recommend spacers. I don’t know about 5th gen suspension geometry, but for a 4th gen you will get 1” of lift in the front with 1/2” spacers. You might need longer studs to fit the spacers on top of the shocks. If you are also looking to lift the rear by 1”, again, for a 4th gen you need a 1” spacer to get 1” of lift.
If you’re trying to level your ride, you can just do the front lift.
I had a 2.5” front/1.5” rear lift with a Daystar spacer kit and stock shocks. I’m now running a 3” front/2” rear lift with Toytec springs, Bilstein 5100 (+2”) shocks and a 1” Toytec body lift (as shown below in my pic). I have been happy with both setups.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
02-07-2021, 09:23 PM
Real Name: Nick
Real Name: Nick
If you need new shocks get bilstein 5100 or a step up 6112. You can get a 1" lift with these.
02-07-2021, 11:21 PM
02-07-2021, 11:36 PM
For a small amount of lift, you don't need to get longer extension shocks. Use spacers as others have recommended. I got the Rough Country leveling kit (2" front, 1" rear spacers) with stock front struts and rear shocks. You don't need new springs for modern springs don't "sag", but the stock springs are s bit soft for some peoples taste. There are many quality shocks available. What I have used on my other cars (my 4Runner is too new to need shocks yet) are Eibach and KYB. I also like Koni shocks, but I don't think they make them for the 4Runner.
02-07-2021, 11:47 PM
Real Name: Kevin
Real Name: Kevin
Hey ads2539, how do you like the Toytec?
I'm getting ready to buy my first TRD, and looking to have the dealer put on the Toytec. Just not certain what the best way to go is.
Bullets, blades, bourbon, and buoyancy. No necessarily in that order.
'21 TRD OR, Nautical Blue, 3" Toytec lift, 285/70/R17 Cooper Discoverer AT3, Toytec rock sliders, blacked out badges, LED high beams, Sprint Booster.
02-08-2021, 01:13 AM
So far, so good! My stock shocks and springs were worn out, and I was getting a lot of body roll, and even some rubbing when just turning over small bumps with a spacer lift kit. I thought I needed a body mount chop, but with the Toytec springs and Bilstein 5100s, my suspension is a lot better. No rubbing, even with 33” tires! The new springs and shocks have made my suspension stiffer, but not too stiff.
I also did a Toytec 1” body lift, and changed my UCAs. I did all the labor myself, except for the alignment, and saved a lot of money. I bought everything directly from Toytec, and had them assemble the front shocks/springs.
Thanks to COVID, I’m only driving about 100 miles per month, so I don’t have a long term opinion yet.
02-08-2021, 02:20 PM
If I were doing a minor lift I might consider something like this, shocks and springs...
Wheeler's 2010-Present Toyota 4Runner Suspension Lift Kit | Low Range Off-Road
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
02-08-2021, 09:02 PM
Eibach pro truck , solves your problem !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
02-09-2021, 12:17 AM
Real Name: Christian Gonzalez
Looks Good!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
