Old 02-07-2021, 06:26 PM #1
Z4_marin Z4_marin is offline
Real Name: Chris
Z4_marin is on a distinguished road
Real Name: Chris
Is there a DIY for Tcase output seal?
After >130,000 miles and 11 years of ownership, I have my first issue! Not bad.
I did a little searching around but didn’t find one. This must not be a very common issue since it seems there are DIY for just about everything else. It’s only weeping now and not “leaking” so it’s not urgent.
Z4_marin is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 10:58 PM #2
Jeremy556's Avatar
Jeremy556's Avatar
It's the same transfer case as Tacoma, 4th gen 4runner, probably several other models, so a how to for those will be the same.
I replaced mine a while back because of a leak - it ended up not being that seal, but actually the O ring for the blank cover for where the speedo sensor would be, if it had one.
Old 02-07-2021, 11:16 PM #3
fkheath fkheath is online now
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The official Toyota repair manual will show you how to do it: TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
P.S. If it is only weeping, leave it alone.
fkheath is online now   Reply With QuoteReply With Quote
Old 02-09-2021, 12:13 AM #4
Real Name: Chris
Real Name: Chris
Many thanks for the info. I think I might clean up the area very well and put some fluorescent dye in there, then drive it around for a day and see exactly where it’s leaking. I suspect mine might be leaking in the same place.
Old 02-09-2021, 12:14 AM #5
Real Name: Chris
Real Name: Chris
Oh cool! Many thanks. I probably should leave it along because it’s not bad BUT my OCD nature precludes me from not fixing it
Old 02-09-2021, 10:58 AM #6
Jeremy556's Avatar
Jeremy556's Avatar
If it is the speedo sensor hole, it is a stupid easy fix. 1 bolt (the one pointing to the passenger side) and it's out. Part number is 96711-24030 $4
common , diy , issue , it’s , weeping
Transfer Case Output Shaft Seal GLP 4th Gen T4Rs 7 01-13-2020 09:56 AM
Output shaft seal on transfer case GX4SEVEND 5th gen T4Rs 2 09-14-2019 08:40 PM
Transfer case output seal atalarico 3rd gen T4Rs 14 08-22-2014 10:46 PM
Tcase output bearing? sam24th Classic T4Rs 5 12-20-2013 03:29 PM
Front Transfer Case Output Seal DirtDawg 3rd gen T4Rs 0 03-22-2013 10:41 PM
