Old 02-07-2021, 08:59 PM #1
orcking orcking is offline
orcking is on a distinguished road
Alignment on highway
2020 limited.
I drive mostly on city roads. Alignment seems fine.
Took a long trip on highway. It seems the car steering is not comfortable. I am very picky about that. The truck at times goes straight with a little tendency to pull to left and at others it pulls harder. I know the crown of the road matters. But I feel that it likes to wander around . And sometimes it pulls right .
It's hard to describe it but it's not comfortable.
I remember driving big trucks like Ford F150 and steering is nice and comfy.
Anyone else had similar experience?
orcking is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 09:32 PM #2
meRockboost meRockboost is offline
Real Name: Rock
meRockboost is on a distinguished road
Real Name: Rock
Dealing with the same on my 21. Pulled left from when we left the dealer with 12 miles on it. Got it fixed this week, dealer said left side was put and we must’ve hit something. But it still wants to pull left. If I turn slightly right on the highway it will return to center and then drift left. If I turn slight left, it will stay not want to return to center. Going back Wednesday.
2021 Nightshade (wifey’s). 1998 Limited-locked, lifted, armored, sold. 2015 SR5, stock and sold. 2002 Sport edition, sold.
meRockboost is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 11:24 PM #3
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by orcking View Post
2020 limited.
You are right that the crown on the road can cause pulling to one side. But if on a level (no crown) road, it wants to wander left then right, the toe in is wrong. The factory does not always get it right. Toe in is a simple adjustment of the tie rod ends; no need to adjust the caster and camber.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-07-2021, 11:36 PM #4
Espresso_OI Espresso_OI is offline
Espresso_OI is on a distinguished road
Interesting - I've got a new '21 and my steering wheel has to be pointed at 11 o'clock to stay straight. I got and alignment after a lift and no change.
Espresso_OI is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 12:53 AM #5
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
i just picked up this issue.
but my suspension has been very heavily modded. , will get my shop to highway roadtest it when i drop it off for my replacement rcv axles.
I almost don't want to drive it nowadays due to the way it handles on the highways.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 11:06 AM #6
Steering wheel offset (11 o'clock position) has nothing to do with wandering left or right (wheel toe in). Your steering wheel was probably installed wrong from the factory. You should have your dealer install the steering wheel right under warranty.
While it is possible to correct steering wheel offset by adjusting the tie rod ends, on modern cars with stability control, it is very important that the steering position sensor be centered when driving straight ahead.
Old 02-08-2021, 11:12 AM #7
Steering wheel offset (11 o'clock position) has nothing to do with wandering left or right (wheel toe in). Your steering wheel was installed wrong from the factory. You should have your dealer install the steering wheel right under warranty.
Do you take it for alignment at dealer or an Indy shop?
Old 02-08-2021, 02:21 PM #8
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
What do you wanderers have the caster set at?
Tell the alignment guys you want 3.5 degrees caster.
Then you will be able to drive on the hiway and track straight and not look like a drunken pirate.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 03:09 PM #9
rayofsi's Avatar
rayofsi's Avatar
thats where i think my issue is too
i have my lower control arms pushed forward 1"
and they might still have my caster set to 3.5 or higher.
Old 02-08-2021, 07:42 PM #10
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I’m at 4.7 with Ironman pro forge UCAs. No wander on the highway. Truck drives very straight.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 10:06 PM #11
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Yup, me too.
Drives much better with higher caster, imo.
...i dont have the sweet ironman UCAs though.
3* to 3.5* might be all stock UCAs will do.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 02-09-2021, 12:31 PM #12
sawman1's Avatar
sawman1 sawman1 is offline
sawman1 is on a distinguished road
sawman1's Avatar
2020 limited.
May want to have an alignment shop take the measurements vs spec. If all checks out correctly, you might consider having them dial in just a little more toe-in on it. Yes, tire wear can be affected, but a very minor adjustment can give a lot more feeling of stability as toe-in loads the steering linkage. I've done this & sold this many times before in my career, especially on lifted trucks etc and it has worked well for me and others.
sawman1 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 03:58 PM #13
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
post your pre and post alignment report and people here will tell you if it's good or not
jhguth is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 10:59 PM #14
NiceToyo NiceToyo is offline
NiceToyo is on a distinguished road
Limited Alignment
I have a 2017 limited with about 19k miles. After having the truck shipped, alignment was off with truck pulling right. I had to have a dealership align the vehicle twice to get it right. I would bring it back, tell them that it is not right and describe the problem. Toyota dealership should stand behind their work and do it again.
NiceToyo is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 10:16 AM #15
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
word to the wise: dealers will not be able to properly align lifted vehicles. don't bother. find a good independent shop where the tech knows what they are doing and actually cares about their work to some degree.
tm965 is offline   Reply With QuoteReply With Quote
alignment , comfortable , highway , pulls , steering
Alignment Revolution- post your alignment print off sheets. 3rd Gen TacticalSR5 3rd gen T4Rs 66 02-17-2024 04:35 PM
Alignment issue help. Pulling to right but alignment OK jason2000SR5 3rd gen T4Rs 44 02-15-2018 10:56 PM
4LO...on the highway? Climr 4th Gen T4Rs 2 02-05-2012 07:03 PM
This alignment shop is trying to tell me I need a 4 wheel alignment.... MudbogPete Maintenance/Detailing 6 12-20-2003 04:22 PM
