Old 02-08-2021, 07:05 PM #1
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Rear wheel studs in the front?
So I just put on some Icon Rebound wheels and the front studs are shorter than the rears. Just enough that the supplied lug nuts only get a little over 6 turns until tight. In my experience that is not enough thread engagement. From my reading the rule of thumb is you need at least the diameter of the bolt (12mm), which is 8 turns on a M12x1.5 lug.
The easy answer is to use ET lug nuts, and doing so more than doubles the thread engagement. However, Icon says that none of their wheels are compatible with ET nuts, even though they are still 60° taper acorn seat. I'm currently using them anyways, they fit and I feel better about the studs not shearing off.
The less easy answer is to use rear wheel studs in the front. I don't know why the fronts are shorter or what it may affect but using longer ones, or if they can even be directly swapped..?
I can't be the first person who has had this dilemma but I didn't find anything on a quick search.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 07:40 PM #2
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I’m running VTX wheels. I did some research on front studs. Yes the rear are a little longer but I think I used Toyota Matrix AWD studs from around a 2006. They also use 12x1.5mm threads. I popped the old ones out and put the new ones in. It’s really easy.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 10:52 PM #3
Jeremy556's Avatar
Jeremy556's Avatar
I've been running rear studs in the front for many years, 230k+ miles.
I almost lost a front wheel, so I bought ARP studs, which ended up being too long. Switched to rear OE studs and no problems since.
Old 02-08-2021, 11:31 PM #4
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
I am using ARP studs in the front. You have to cut them shorter which is a pain but they are very strong. The OEM studs are known for failing when you have a sloppy tire mechanic.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 12:00 AM #5
T4R416 T4R416 is offline
T4R416 will become famous soon enough
Any idea how much longer rears are compared to front ?
T4R416 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 12:01 AM #6
Any idea how much longer these are than the rear OE 4runner studs? Why did you opt matrix as opposed to the rear oe?
Old 02-09-2021, 12:34 AM #7
I think the rears are only 5mm longer than the front. I believe the Matrix ones are 10mm or 15mm longer, not 100% sure. I just felt like why not go longer than OE rear. I didn’t go ARP because I didn’t want to cut. I sourced these from searching on here and an old thread came up with the Matrix studs as a solution.
Old 02-09-2021, 11:00 AM #8
Real Name: Kevin
Real Name: Kevin
Thanks good to know. Unrelated, I'm originally from GJ.
From Rock auto information-
OEM front- 40mm thread and 45.35mm overall length
OEM Rear- 44.1mm thread and 48.8mm overall length
Matrix AWD- 55mm thread and 60.65mm overall length
So the OEM rears are not a lot longer but it gives you about 3 extra turns on the lug nuts.
One thing to keep in mind is they all also have a longer shoulder, not necessarily a bad thing but you may not be able to use them in combination with ET lug nuts. Yes I get that changing studs is a way to not use ET but thought it worth mentioning. Also with the really long ones you'd have to make sure you are clamping the wheel and not bottoming out the threads in the lug nut when tightened.
Old 02-09-2021, 02:30 PM #9
Nice!!! This is very good info. Thanks for doing some digging.
Old 02-10-2021, 10:35 AM #10
Real Name: Kevin
Real Name: Kevin
Because I can't stop digging... I did find some 12x1.5 studs that have 50mm thread. So it should be in between the OEM rear and the Matrix stud. Something like this http://vprojectusa.com/product/50mm-...0mm-v-project/ So far I have only found them in sets of 10 though.
Old 12-16-2022, 02:58 PM #11
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
heres the difference for anyone looking. oem rears are about 1/4in longer and give about 4 more threads
dedonderosa is offline   Reply With QuoteReply With Quote
front , lug , nuts , studs , thread
Length of rear wheel studs Vs front(spacers install) benztech82 4th Gen T4Rs 22 06-21-2023 08:01 PM
Front wheel studs Dezerts10 3rd gen T4Rs 11 08-15-2020 09:27 AM
Front Wheels Studs Too Short For Wheel Spacers Pekoe1111 3rd gen T4Rs 3 04-05-2020 01:04 AM
longer front wheel studs for spacers chipsahoy 3rd gen T4Rs 2 03-27-2020 09:01 PM
wheel studs/front davidtaylorcam Classic T4Rs 0 04-06-2009 09:13 AM
