Old 02-09-2021, 08:06 PM #16
bear1998 bear1998 is offline
Real Name: Bryan
bear1998 will become famous soon enough
Real Name: Bryan
Originally Posted by yotantexas View Post
Mountains = more coasting down hill compared to flat ground.
Also thinner air at 8000 feet so the truck calibrates how much fuel it delivers based on how much air the engine is sucking in.
But I bet your truck seems to have a good bit more pep at sea level.
Dont you drive up the same hills to get back??
bear1998 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 09:06 PM #17
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
When I worked in Colorado Springs I lived in Monument. Every day if I reset my mileage calculator, I had a drastically different mileage for driving to work, downhill, then driving home, uphill.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 09:25 AM #18
Drheim Drheim is offline
Drheim is on a distinguished road
Thanks for all the replies guys. It was definitely different in Vail as there were not many stop signs or stop lights within 30 miles of my house(lots of round-a-bouts), but originally my gas mileage honestly stayed above 23mpg. I probably accelerated slower than average jumping on the interstate, and a good part of the year you are driving slightly slower in 4wd because of conditions, but remember for first few years that my gas mileage range was always above 400 miles. I would reset once a year or so sample size should have been good, and noticed mpg slowly came down to 21 over a few years. I am not 100% on the cause of the drop, but sounds like my 4runner is normal which is what I cared about. I am now getting 17.3 in solo suburb driving and if you guys say that is normal, then that is exactly what I was looking for. A few people in the mountains use to say that diesels were a lot more efficient at altitude. On my dirt bike, I typically was up above 9000' and had to put much smaller jets on it because when there is less air for a carb, the engines run too rich, but I always assumed that even with the proper air/gas ratios the engines just would simply not perform as efficient.
I love Toyotas because they are just so reliable. I also had a TRD truck up there with 275k miles that ran perfectly fine when I sold it, but now starting to think about getting one of these new Broncos. Just need a convertible again after living in the mountains for 14 years, and really wish Toyota would bring back the old FJ40s where you can take the top off again.
Drheim is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 01:13 PM #19
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
My anecdotal experience -- I gained 1-2 MPG moving from Dallas to front range Colorado. In Dallas I'd be averaging 16-17 and in CO I'm seeing 17-18 average over the last few months.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 01:20 PM #20
I haven't scientifically proven this, but in my experience, if you keep the speed lower on the climb up, the fuel savings when coasting down can offset the increased fuel need on the climb up.
For example, when approaching Loveland Pass on I70, I am typically at around 55-60 mph in the right lane. If I were to try and keep up with traffic doing 65-70, my FE would tank. When coming down, I'm usually in 4th and able to maintain speed. At this point there's no fuel being fed at all, given RPMs are high enough for the ECU to shut fueling off. Driving like this I get marginally better fuel economy in the mountains than I do on I25 doing 65-75. I'm sure some of that has to do with the speed in the mountains being lower as well.
Old 03-09-2021, 01:44 PM #21
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Since you noticed a "change", I would suspect a maintenance item might be to blame.
Simple things like air filters and plugs. Dirty fuel injectors. Dirty MAF and/or throttle body (both easy to clean). Bad o2 & F/A sensors. Tire inflation pressures, etc.
More complicated things like wheel bearings, brake drag, etc.
I get 19.3 everywhere. It dipped a little when my throttle body was dirty and when I ran lower tire pressure.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 09:03 PM #22
Old3Tow Old3Tow is offline
Old3Tow is on a distinguished road
FPNI, start with basic maintenance and a little love.
Change oil, air filter, clean MAF, throw a bottle of BG/Techron/etc in the tank, and most of all—sparkplugs. And spring for the double iridium ones while you’re at it.
That’s all I got
2012 Trail Edition, Silver w/ KDSS, Shrock Works front bumper, warn M12,000 winch, RSG Rock Sliders, Full RCI AL Skids w/steel on gas tank, OME 888/889 springs and OME 90021 Nitrochargers, Camburg UCAs, 32” Cooper 235/80/17 LT on Trail wheels, 1.25” wheel spacers, LEDs inside and out.
Old3Tow is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 09:25 PM #23
DangerDan DangerDan is offline
DangerDan is on a distinguished road
Gas mileage Is definitely more efficient at altitudes, that's probably 90% of your "problem," if not all of it.
Sent from my SM-G960U using Tapatalk
DangerDan is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 08:58 PM #24
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
OP, you did not clarify where at sea level you are at.
But I am with Electro Boy on this. Being from SoCal our fuel blends change from winter to summer. (AQMD rules) this effects MPG.
I also agree with adding or buy fuel that contains Techron to keep your injectors clean. I have done this for years and believe that it works.
I am not familiar with Colorado fuel but do they have season blends for there gas? I have been to Denver and if they don't they should.
Ethanol added to gas helps with emission but it hurts MPG.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 07:17 PM #25
IjmRunner IjmRunner is offline
IjmRunner is on a distinguished road
Sounds like you are getting about the same mileage as everyone else, I don't see much to worry about.
IjmRunner is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 08:14 PM #26
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
You are currently getting just about dead on overall EPA stated mileage for the vehicle. I don't see a problem.
5thToy is offline   Reply With QuoteReply With Quote
gas , level , road , sea , trips
Worse gas mileage after changing O2 sensor manp0899 4th Gen T4Rs 6 10-01-2021 12:12 AM
2013 4Runner 2013 TRAIL front end FOR SALE Fort Worth Texas $350 OBO Mighue For Sale: T4R Items 1 10-18-2018 03:31 PM
Think I have my worse-than-normal fuel mileage licked Nuke 4th Gen T4Rs 3 05-05-2014 07:48 PM
Worse mileage after K&N?!?? MtnBkr 4th Gen T4Rs 16 09-28-2012 08:01 PM
Why do bigger tires cause worse mileage? HuntRunner 4th Gen T4Rs 38 01-09-2006 11:47 AM
