Old 02-09-2021, 12:39 AM #1
Birddog1911's Avatar
Birddog1911 Birddog1911 is offline
Real Name: Kevin
Birddog1911 is on a distinguished road
Real Name: Kevin
Overwhelmed with Toytec lift options
First, I apologize, as this may have been covered. But, after all of this time, I'm going to be getting my first T4R, as well as my first lift. And the amount of the info out there can be overwhelming for someone who hasn't had experience. I'll be honest, my mechanical skills are mediocre, and don't think I'd be up to a lift. And yes, I know that having the dealer do it will likely cost more, but for me, it's the most logical choice.
The dealer typically offers a Toytec 3" coil over lift, as they call it. I haven't gotten the nitty gritty specifics, yet. But, is this the best overall way to go? I'm going to use it for light to moderate, occasional, off roading, some possible overlanding, and generally fighting the winter weather and living in the country. I have used the full range of my TTUE FJC at times here.
I know I don't NEED a lift for what I do now, but I would like to expand my possibilities for the future, without breaking the bank.
Is the 3" likely the best, or is there some other option that would be better? Is there something that I'm missing? Thanks for any suggestions.
Bullets, blades, bourbon, and buoyancy. No necessarily in that order.
'21 TRD OR, Nautical Blue, 3" Toytec lift, 285/70/R17 Cooper Discoverer AT3, Toytec rock sliders, blacked out badges, LED high beams, Sprint Booster.
Birddog1911 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 10:14 AM #2
eevanskiteboards eevanskiteboards is offline
eevanskiteboards is on a distinguished road
I installed the three inch toy tech lift with the coilovers and new springs in the rear with the Bilstein 5100s. The suspension definitely feels solid now. I'm very satisfied with the results a year later. I'll tell you one of the best upgrades I noticed with regards to the suspension was when I upgraded the bump stops. For some reason I guess this factory bump stops are just a lot more rigid than an aftermarket set. When I put the aftermarket set on it definitely smoothed out any bumps etc. I used the energy suspension bump stops in the front
Sent from my Pixel 4a using Tapatalk
eevanskiteboards is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 11:24 AM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I installed the same Toytec lift kit that eevanskiteboards did in my 4th gen, and I’m very happy with it. 3” in front and 2” in the rear, so the rake is gone. I also installed the Toytec 1” body lift, and I’m running 33” tires.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 11:32 AM #4
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Just out of curiosity, what does the dealer change for this kit + labor?
If you're not looking for anything for serious offroading, check out some other options as well. Eibach makes a good kit.
Eibach Lift Kit 5th Gen 4Runner (2010+) - YotaMafia
Also, keep in mind, at 3" you may need to add in the cost for aftermarket UCA to get the alignment back into spec.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 11:58 AM #5
Real Name: Kevin
Real Name: Kevin
Waiting to get the price sheet from the dealer. They have a couple of standard "packages", but there are a few of those things that I don't care about.
I'll know by this evening if I'm getting the only Nautical Blue TRD O/R in Colorado for sale.
Old 02-09-2021, 12:17 PM #6
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
First, I used to live in CO and know the roads. If you want to do some good trails I would go with the Toytec 3" coil-over Lift. You could get by with a spacer lift but the ride will be more harsh and it will rattle your brains.
The toytec CO lift (my guess is this lift LINK )is a fantastic lift and I think you will be very happy with it. 3" is on the average side of lifts but I don't think you will feel it is too big or anything. You will want to get tires as well to fill the void in the wheel well but that CAN be done at a later date if you want. I ran my 3" lift on my 4th gen without getting tires for a couple of months.
I say go for it! You will not regret this lift.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 12:44 PM #7
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Id recommend going directly to toytec since your in CO. They will help you choose / build a lift based on your needs and not just try to push a one size fits all package. If you want to get into specifics, talk to Hugo Huerta who works there either on Facebook or call them up.
El Dusty is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 01:00 PM #8
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Some thoughts to consider when buying a lift: the 4Runner is not a cheap truck, do you really want to cheap lift?
If you’re not doing the work yourself and paying somebody for the install, you’re going to pay a lot to install a cheap lift or a nice lift, consider buying a nice lift.
When considering options, always think about how drivable it will be afterwards. If you plan on keeping it for a long time and using it as a daily driver, I strongly recommend getting a lift that has excellent on road ride quality.
When choosing your springs and how loaded you plan on driving it most of the time, be honest with yourself. I see people hauling air that have heavy duty springs set up and just are miserable and punishing to ride in.
Finally, this is not permanent, you can always redo the lift at a later date.
And a final edit which is more specific for Colorado: see if they will use anti-seize when taking everything apart and putting it back together again, everything rusts to shit in Colorado. Also ask them if there’s any special precautions you need to take for the lift components to wash them or coat them every once in a while to keep them from oxidizing.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-09-2021, 01:40 PM #9
Real Name: Kevin
Real Name: Kevin
Since I've never looked hard at a lift, I didn't know that. Thanks, and I'll consult with them.
Old 02-09-2021, 01:43 PM #10
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Yes, call them. I have the Toytec Boss 3" lift with SPC upper control arms. Mine has the Bilstein shocks which is at the time what they had. Roughly 60k on them so far and no problems.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 07-13-2021, 03:32 PM #11
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
Anyone here with a Pro move to the toytec 3" lift? I've spoke with Hugo at Toytec and he recommended going to the 2.5 Aluma Series because of the Pro suspension package. I also didn't want to do the control arms at this time but could very well in the future. Thoughts on this?
JRod0981 is offline   Reply With QuoteReply With Quote
dealer , lift , toytec , weather , winter
Help the simple and overwhelmed mavrick1903 4th Gen T4Rs 4 07-08-2015 10:48 PM
Anyone else feel overwhelmed? ShooterMcGavin 3rd gen T4Rs 23 05-09-2015 09:44 AM
Lift options tundra TRD springs vs toytec eibach 620 kingin 3rd gen T4Rs 13 02-24-2015 03:35 PM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
A little overwhelmed Cow_doc.308 3rd gen T4Rs 15 08-07-2013 05:00 PM
