Old 02-10-2021, 10:23 AM #1
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
Door Adjustment
Yesterday I had my first experience with my dealers Service Dept, which unsurprisingly was less than enjoyable. RE: Required 5K service.
One of the things on my list was adjusting my driver door. For me I have to slam (slight exaggeration) this door to ensure it closes.
The Service Dept tells me they couldn't detect any difference with this door compared to the others.
Soooo I'm wondering if there's any tutorial on adjusting doors.
Obviously the adjustment would be minor but I haven't a clue where to start. I'm pretty green on body stuff.
One clue on what the problem is: When I gently pull the handle to open it, there's a more abrupt Pop when it opens. When I gently swing the door under its own weight, it doesn't fully close.
Can Part# 69410 be moved around a bit?
Door Adjustment-door-parts-jpg
3kushn is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 12:52 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Carefully inspect where the striker plate (#69410) enters the slot in the latch. It should be in the center of the slot. If not, it can usually be adjusted by just loosing the mounting screws.
If the striker plate is centered in the slot and you still have problems, lubricate the latch mechanism with WD-40.
If the striker plate cannot be centered in the slot, then you will have to have the door hinges adjusted.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-10-2021, 01:40 PM #3
3kushn's Avatar
3kushn's Avatar
It's really cold right now so I'm going to wait for another day.
So lets say this is the problem. Is the adjustment basically trial and error, or would I loosen the bolts then softly push the door closed to sort of self align.
I'm thinking loose that 69410 can move but still stays in place if not touched. Barely snug.
Old 02-10-2021, 02:08 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Another thing you can check is the gap around the top and sides of the door when closed. Compare it to its mate on the other side if it operates properly. Either the door is off or the latch assy is off. I think adjustment will be trial and error.
Old 02-10-2021, 02:18 PM #5
According to the Toyota OEM repair manual, page 5446: (TOYOTA 2016-2019 4Runner Repair Manual RM27F0U)
(e) Using a T40 "TORX" socket wrench, slightly loosen the striker mounting
screws.
(f) Using a brass bar and hammer, hit the striker to adjust its position.
(g) Using a T40 "TORX" socket wrench, tighten the striker mounting screws after the adjustment.
Torque:
23 N·m {235 kgf·cm, 17 ft·lbf}
Previous pages in this repair manual describe how to adjust the door hinges.
Old 02-10-2021, 02:25 PM #6
Yes. Page 5445 of the factory repair manual shows how to adjust the doors so you have even gap all around. There are pictures in the repair manual that show how much gap you should have.
Due to the weight of the door, you should have the dealer do any adjustment of the hinges, if needed.
Old 02-10-2021, 03:41 PM #7
One more thing to look for: the outer panel of the front and rear doors should be at the same level. If the front door is recessed too far in, the seals around the door would be compressed more than they should be. Then the striker plate would need to be adjusted outward.
Old 02-10-2021, 05:20 PM #8
3kushn's Avatar
3kushn's Avatar
screws.
Torque:
Maybe there's no way to download the Manual?
Maybe I'm too stupid?
Can't get it done.
Would really like to have this.....
Old 02-11-2021, 12:43 AM #9
Can't get it done.
It can be a challenge to download that manual. You have to follow the instructions exactly. Be especially careful of the upper/lower case (they are all case sensitive) and the difference between the number zero "0" and the letter oh "O". if you have everything exactly right, it will download.
It is a HUGE manual, over 8000 pages! You can see why manufactures don't print paper manuals anymore.
Old 02-13-2021, 03:19 AM #10
4runninDrew 4runninDrew is offline
4runninDrew is on a distinguished road
While I am no body expert. I've definitely tweaked some door strikers before, and usually get the desired results. It's not a difficult thing to do.
You'll need to crack the two torx bolts loose. Not so much that you can move the striker by hand, just a couple turns or so on each bolt.
Then I usually use a dead blow mallet to knock the striker the direction I need it to go, you could also use a regular hammer and a block of wood. Don't be afraid to give it a good whack, but at the same time, don't go pounding it with a sledge.
In your case, if your door seems too tight to close, you'll want to bring the striker towards the outside of the vehicle. Try the door after you've moved it a bit, then just keep going more or back the other way until it feels right.
The last thing you want to do before you tighten it back up, is to check that the striker is level with the latch. Grab your door, and close it while holding the handle out so the latch can't engage, and just rock the door back and forth right near the closed position to make sure that the striker hasn't become out of line with the levelness of the latch. If that needs tweaking, just do as you did before to make adjustments, and just knock the striker up or down as required. I wouldn't mess with the hinges at all, or you could be opening a whole can of worms there.
4runninDrew is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 10:04 AM #11
indevo indevo is offline
indevo is on a distinguished road
Short answer yes. I’m obsessed with the doors closing cleanly and have adjusted the strikers on all of my last 4 Toyota’s. The Tacoma’s were the worst of the bunch. Word of advice, use a 8 in or so 2x4 to rest on the striker plate, loosen the torx about 1-1.5 turns, one or two decent smacks in the direction you want to go (usually down to close smoother, or in if door sticks out a little). In my early trials the mallet slid off the striker and hit the inside jam denting it(someone has a ‘16 Tacoma with small dent). The wood block gives more surface area to connect, just don’t rest it on the paint, even then, nothing a little buffing won’t take out. In the chance you drive the striker inside too much, put a thick screwdriver in the middle of the catch vertical and pull, the inside metal securing the bolts will give. There is a lot more forgiveness here than most think.
indevo is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 10:10 AM #12
Also, do it little by little. Hit the striker in the intended direction, then tighten down the torx enough so you can close the door, if good, tighten down to spec, or adjust if needed. The only thing I haven’t been able to avoid is a little scuffing under the plate, it’s not bad and not visible. If worried about rust, just hit with touch up paint. It’s super easy, you can do this, and better than the dealer, or body shop, at least that’s what I’ve learned in my situation. I can also guarantee you this, once you finish the one door, you will do the rest. No more slamming, just a nice light flip and thunk, solid clean close.
Old 02-13-2021, 12:21 PM #13
3kushn's Avatar
3kushn's Avatar
Just want to thank everyone for their input. Everything said make perfect sense.
Then there's this:
4RunninDrew warns against messing with hinges, cause it'll open a can of worms.
Then indevo fine tunes his instruction, then says, after I fix this problem, he guarantees I'll find 3 more problems. Isn't that another worm can? LOL
Speaking of that, I've had the hatch not close a few times too. So there's a 4th problem I'll create from fixing one.
BTW, another member sent me the manual via Dropbox. All set there too
Now all I gotta do is wait for temps to move off Zero.
Old 02-13-2021, 01:00 PM #14
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Do NOT spray anything into the actuator mechanism. There is a cheap $.50 radio control car motor in there that will respond negatively to anything being put in there and then crap out and then you’ll be digging around in the door panel to replace either the motor or the actuator at great cost of time and effort.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 10:26 PM #15
3kushn's Avatar
3kushn's Avatar
Sounds like the voice of experience.
I have no plan to have any aerosols nearby for this adjustment.
Torx Bit, Ratchet, Soft Face Hammer, and patience is all.
All those things are off the shelf items.
Somewhere in my garage.
adjusting , adjustment , door , gently , service
DIY: Replace door courtesy / door jamb switch (fix door ajar light and door sensor) andrewbares 3rd gen T4Rs 17 05-16-2021 03:17 PM
Tan 3rd gen interior door handles $25 and door lock knobs $10 Indiana Mike1202002 For Sale: T4R Items 4 02-27-2016 10:13 PM
Gas door adjustment? T4R2014 3rd gen T4Rs 7 06-13-2013 02:03 PM
