Old 02-11-2021, 12:40 AM #1
Dollar Retriever Dollar Retriever is offline
Dollar Retriever is on a distinguished road
Angry Squeak sounds after rear shocks upgrade
Here is a brand new 2021 TRD off-road with KDSS.
Changed rear stock shocks to Bilstein 5160 with stock coil springs.
Squeak/chirp sounds when driving on wahsboard, over sharp speed bumps/ potholes. Quiet on pavements / roads.
Already retorqued the nuts that been touched.
It’s annoying. Especially after a long day.
Dollar Retriever is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 01:57 AM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
retorque the kdss sway bar bolts located near the rear diff housing.
I had the same issues you described, and when i went to install a diff skid, i noticed that the bolts were easy to torque off (which it shouldn't be).
When i reinstalled those bolts, i torqued to spec and my squeaking went away.
Old 02-12-2021, 02:28 AM #3
Thanks. I try it this weekend.
Actually I need to do a complete retorque.
I torture my vehicle since day 1.
Old 02-12-2021, 03:02 PM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Did you torque the suspension bolts while lifted or on the ground? You should rock vehicle on ground by hand with bolts loose and then torque to prevent binding in the bushings. Could that be the squeaks you are hearing?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 03:37 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
If nothing resolves the noise, you can always swap back the stock shocks .. one at a time.
R and R can isolate noise issues
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 02:10 PM #6
aweaver65 aweaver65 is offline
aweaver65 will become famous soon enough
Check the Parking Brake Cable Bracket on rear trailing arm
The Parking brake cable runs through a little metal bracket that is bolted to the trailing arm. If that bracket is putting a bind on the cable where it passes through, you will get squeaking.
You can bend the bracket to relieve the tension and/or spray silicone or lithium grease into the tube section the cable passes through...
2020 Army Green TRD Pro, RSG Flat Sliders. SV.4 LED's from Headlight Revolution, RAM Mount for Cell Phone (got my cup holder back!), Deleted Roof Rack (sold). Canvas Back full Cargo Liner (for my Dog "Donkey")...
Icon Stage 2, Body Mount Chop, Method MR305's and BFG KO2 285/75/17's (34 Inch Tires) (No rubbing at all), East Coast Gear 4.56 Diffs Front/Rear
aweaver65 is offline   Reply With QuoteReply With Quote
rear , shocks , sounds , speed , stock
Right rear squeak- sometimes gaswede 4th Gen T4Rs 4 10-11-2019 03:58 PM
Rear End Squeak eskimochaos 4th Gen T4Rs 5 05-05-2019 12:29 PM
Stock speaker upgrade, what have you done? Hard to believe it sounds so good! fugereb 5th gen T4Rs 14 02-09-2019 11:03 AM
Help with axle / driveshaft squeak, pop, scraping, binding sounds JohnOfTheJungle 3rd gen T4Rs 15 01-29-2019 11:10 AM
Squeak From Rear DallasSR5 4th Gen T4Rs 6 07-12-2015 12:03 AM
