Old 02-19-2021, 03:19 PM #31
Birddog1911's Avatar
Birddog1911 Birddog1911 is offline
Real Name: Kevin
Birddog1911 is on a distinguished road
Real Name: Kevin
A little more reflection that I would have liked, but you should be able to make them out.
ETA: Having some sort of issue attaching photo. Standby.
Bullets, blades, bourbon, and buoyancy. No necessarily in that order.
'21 TRD OR, Nautical Blue, 3" Toytec lift, 285/70/R17 Cooper Discoverer AT3, Toytec rock sliders, blacked out badges, LED high beams, Sprint Booster.
Birddog1911 is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 11:38 AM #32
Real Name: Kevin
Real Name: Kevin
Finally got it to work.
LED High Beams-20210219_110108-jpg
Old 02-20-2021, 02:55 PM #33
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
So did they just put in an LED bulb? If so, what brand/part number?
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 03:11 PM #34
Saker's Avatar
Saker Saker is offline
Saker's Avatar
My question is this, did they replace the OEM assembly with one that has the high and low in one module?
If they did not and only replaced the OEM halogen bulb with a LED drop in, then when you (@Birddog1911) , turn on your high beams, that LED you took the photo of comes on, is the same as I did and didn’t change the complete headlamp assemblies. Therefore, no harnesses had to be changed or modified.
Best Regards,
Saker
Old 02-20-2021, 05:59 PM #35
Real Name: Kevin
Real Name: Kevin
Ok, I did find out that they're aftermarket. Will call the place on Monday to find out just which brand, and I'll take a picture.
Old 02-20-2021, 07:01 PM #36
Rainier42's Avatar
Rainier42's Avatar
Aftermarket LED Bulbs and not complete headlight units, correct?
Old 02-20-2021, 09:48 PM #37
Real Name: Kevin
Real Name: Kevin
Sorry, yes, that is correct. Just aftermarket bulbs.
Old 02-20-2021, 10:12 PM #38
Real Name: Kevin
Real Name: Kevin
Went out to try and get some comparison photos.
ETA: Fog lights were on, as well.
LED High Beams-20210220_185611-jpg  LED High Beams-20210220_185634-jpg  LED High Beams-20210220_185919-jpg  LED High Beams-20210220_185923-jpg
Old 02-21-2021, 01:25 AM #39
ltsatch ltsatch is offline
ltsatch is on a distinguished road
Originally Posted by Axix23 View Post
Off topic but how’s your 2021 led fogs?
They are great in my 21 TRDOR, LED low beams are nice, halogen high beams are annoying as everything is bright white, then the high beam kicks me back to my 2012 Trail which I just traded in, lol.
ltsatch is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 01:33 AM #40
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
HAHA, one thing i noticed on the 2021 4 runners, the rear tag light is still halogen. Its like Toyota cheaped out on some stuff. But at least they finally got led low beams
Axix23 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 01:56 AM #41
I have only had the '21 for 4 days, are the interior lights leds?
Old 02-21-2021, 03:43 AM #42
SoCalAl SoCalAl is offline
Real Name: Al
SoCalAl is on a distinguished road
Real Name: Al
I have a 2021 ORP, interior lights are still bulbs. No LED.
SoCalAl is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 08:16 AM #43
VENTURE21 VENTURE21 is offline
VENTURE21 is on a distinguished road
This led high beam has peaked my interest as well. Plug and play replacement be sweet.
Do the Pros have a removable high beam? Appears my led low is sealed in there. Is the small 2 wire connector closest to the radiator for daytime?
21 Silver Venture
18 Cement Tundra
04 TJ Rubicon
VENTURE21 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 01:42 PM #44
Saker's Avatar
Saker's Avatar
Originally Posted by VENTURE21 View Post
Do the Pros have a removable high beam? Appears my led low is sealed in there...
The 2021 TRD Pro’s low/high are in one LED Projector Module. The high beam, when activated, moves a shield and allows all of the light from the LED Chip to be projected thru the lens.
In the 2021 TRD Pro, the DRL is still a halogen, located in the place of the previous year model DRL/High Beam bulbs.
Best Regards,
Saker
Old 02-21-2021, 02:11 PM #45
I would love to get a model number for the plug and play LED high beam for my 21 TRD-OR. This is starting to annoy me now, lol. Looks like a simple swap out.
LED High Beams-img_0847-jpg  LED High Beams-img_0848-jpg
beams , difference , led , strobing , xds
Very simple question: why are low-beams in a protective case but high-beams aren't? Da8ron 5th gen T4Rs 2 04-17-2017 06:13 AM
High beams work, low beams don't? Shine4JC 3rd gen T4Rs 22 12-24-2015 05:33 PM
Low beams, high beams, and fogs won't work... twkoch 3rd gen T4Rs 10 05-07-2015 07:33 PM
high beams iliquer 3rd gen T4Rs 1 02-01-2012 03:25 AM
Flashing High Beams without Low Beams? Offroader 4th Gen T4Rs 3 04-02-2006 08:04 PM
