Old 02-15-2021, 10:00 PM #16
jp.vegas jp.vegas is online now
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Originally Posted by Scowling Tuna View Post
Well, our Limited's probably have at least 1000lbs on the cars too, so that maybe be part of the "why".
You have more suspension travel and articulation than car based crossovers so that's the biggest reason.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is online now   Reply With QuoteReply With Quote
Old 02-15-2021, 10:30 PM #17
spartacus's Avatar
spartacus's Avatar
courtesy of @BigGreen
TRAction Control system . This is refering to TRAC. automatically helps prevent spinning of the rear wheels (2wd models) or 4 wheels (by adding brakes) when the vehicle is started or accelerated on slippery road surfaces.
Doesn't require push button activation. Works on it's own and is activated when the ignition is turned on. all FJ's have this whether 2 or 4wd model. On automatics, I am assuming this works in 2H or 4H, doesn't matter. If the system detects wheel spin, it adds brakes to increase traction.
A-TRAC is Active Traction Control system automatically helps prevent the spinning of 4 wheels when the vehicle is started or accelerated on slippery road surfaces. (basically same as TRAC, but only works in 4 Lo). To activated, hit the ATRAC switch, shift into Nuetral, and shift the 4x4 lever (short knob) into 4 LO. When in 4Lo, it detects wheel slippage and adds brakes accordingly to give added traction. Again, you must be in 4Lo and hit the "ATRAC" switch.
VSC (vehicle stability control) system : integrates the control of the systems such as ABS, TRACtion control, engine control, etc to prevent the vehicle from skidding when cornering on a slippery road surface or operating steering wheel abruptly.
VSC is activated when the vehicle reachs 9mph or 15km/h.
*VSC automatically turns off (VSC off light on dash comes on) when 4H/HL or 4Lo/LL is activated (AT/MT) or when the Rear Diff is locked.
Old 02-15-2021, 10:32 PM #18
spartacus's Avatar
spartacus's Avatar
Here is a video on awd lc
Old 02-16-2021, 08:33 AM #19
Scowling Tuna's Avatar
Scowling Tuna Scowling Tuna is offline
Scowling Tuna will become famous soon enough Scowling Tuna will become famous soon enough
Well, he was talking about AWD cars slipping on gravel, so in this instance I don't see the suspension as having a benefit. Overall, sure, but not in this instance.
2011 Limited
Scowling Tuna is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 02:48 PM #20
Slipping on gravel while making a slow turn, up an incline is what was typed. So in this instance, it’s very possible that articulation played a part.
Gone
Old 02-16-2021, 07:27 PM #21
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
Yes, and for more imagery ... I help train bird dogs. Getting from the club house to the training area is gravel and several washout areas, one of those is when we make a sharp very slow turn through a gate. The gate is maybe 10' wide but the turn is sharp. We've had people scrape the inside post, therefore a 1mph or less turn. At that point is a washout with loose gravel Plus about a 10degree incline. Basically some are nearly stopped before climbing the little hill.
As far as the size of vehicle?? The AWD SUV's carry 1-2 kennels = 1-3 dogs.
I'm satisfied with the answers here and I think verifies my thinking. The Limited Full Time 4wd may well be AWD but there's a little more going on than most other systems.
3kushn is offline   Reply With QuoteReply With Quote
air , atrac , torque , traction , wheel
ATRAC VS ATRAC/VSC OFF MOD : which do you prefer when wheelin'? ddnww 4th Gen T4Rs 4 07-16-2013 08:07 PM
Help with an explanation for the wife... SShink 5th gen T4Rs 93 03-16-2013 12:03 AM
LSD explanation emsmatt 5th gen T4Rs 10 10-02-2011 07:54 PM
Why IFS is AWESOME - an explanation tineman06 Off Topic 2 04-16-2011 01:32 AM
4WD explanation please: CVsGX470 4th Gen T4Rs 8 04-03-2005 11:16 AM
