Old 02-13-2021, 12:49 AM #1
scott78945 scott78945 is offline
scott78945 is on a distinguished road
HID bulb turned pink, replace or go LED?
My 6 y/o HID set on my 2014 Trail Edition appears to be on it's way out. My passenger headlight has suddently turned pink and at times flickers to bright white like it should. So, looks like my bulbs are going. I got the kit from XexonDepot. Is it worth it to replace the bulbs since everything else seems to be working, or should I go LED? If going with LED, any recommendations for the low beams? I was unsure how long ballasts last but so far so good. Thoughts? Are there any LED that are plug and play with orignal wiring?
2014 Trail Premium w/ KDSS- Black
scott78945 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 04:03 AM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Easy answer.
Replace both of your HID Bulbs.
LED’s in the side firing halogen projectors will not give you very good output.
Although they will look bright if you stand in front of them, they will not perform as your current HID’s do.
There have been numerous write ups on this subject on the forums.
Hope this helps.
Best Regards,
Saker
Old 02-13-2021, 05:11 PM #3
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I would give Morimoto HID bulbs a try
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 09:41 PM #4
redneckj's Avatar
redneckj redneckj is offline
redneckj will become famous soon enough
redneckj's Avatar
This HID vs LED replacement thing has been beat to death.
This situation is really really simple. There is NO LED replacement bulb that will put out more light through a projector than a HID bulb. LED replacement bulbs are getting better and better, i will agree with that. HID bulbs were designed to be used with a projector housing. Aftermarket LED replacement bulbs are not. NO matter what LED manufacturer tells you, its all hype.
Ask anyone that has had LED bulbs in their 5th gen low beams and then switched to HID about the light output.
Another thing is the kelvin/ color. The lower the kelvin, to a point, the more light output of the HID bulbs. 4300-5000 Kelvin is going to provide more output than 8000 K. Plus the 8000K bulbs work terrible in rain and snow.
Call Morimoto and ask them about LED vs HID in a factory projector housing if you don't believe me. They sell both. Get their opinion.
H11 Morimoto Elite HID Systems | H11 HID Headlights
My 2 cents, if it matters.
redneckj is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 10:45 PM #5
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I love my Morimoto HID bulbs, have used them for years and they never disappoint. I'd definitely replace the HID bulbs if it were me
Old 11-09-2021, 02:50 AM #6
AUXITO.COM AUXITO.COM is offline
Real Name: AUXITO AUTO LED LIGHTING
AUXITO.COM is on a distinguished road
LEDs are light-emitting diodes that convert electrical energy directly into light energy, and xenon lamps are high-voltage electricity emitted through the discharge of xenon gas in the bulb.
HIDs emit a lot of heat and a large portion of their emissions fall in both the IR and UV spectrum.
Therefore, LED will be more energy-saving and environmentally friendly and have a longer lifespan than HID.
If you are worried about the efficacy of LED bulbs, you can first try using LED bulbs at the license plate lights or interior lights first.
In addition, the low beam bulb model that fits the 2014 4Runner is the H11 model bulb.
AUXITO.COM is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 09:25 AM #7
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Sorry, but that's definitely not an apples to apples comparison. Short distance / foreground lighting is important in the two applications you mention. It's one of the least important things you need in a good headlight bulb.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 01:51 PM #8
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
I've been through 2 complete Morimoto HID kids. For me the light either turns green, or pink, and starts to flicker. Usually 1.5 years for me. In the 7 years of using them, just replacing the bulbs I find that it delays something else failing. Either the ignitor or the ballast will then fail. I'm currently on an older set of Xenon Depot kit with the Phillips bulbs before The retrofit source bought them. I'm on year 2 for them, and they seem to be lasting longer than the Morimoto stuff. But I also have 2 brand new Toyota OEM LED headlights ready to drop in when something fails in the Xenon Depot kit.
Cheers! is offline   Reply With QuoteReply With Quote
Old 11-11-2021, 02:43 AM #9
Yes, you are absolutely right.
The lumen value of the headlight bulb, the color temperature and whether the light is diffused and other indicators are very important. That's why we have a 30-day no-hassle return and refund policy. This is also a standard service that every business needs to provide. So that customers are not satisfied with the installation of the product and want to return or replace.
Thank you very much for bringing that up. I am eager to communicate with you more!
bulbs , hid , led , pink , replace
Mobile Grease (Pink Stuff) Turned to Oil? RPC Maintenance/Detailing 3 05-09-2016 09:07 AM
How can I replace this bulb? Carl_G 4th Gen T4Rs 29 10-13-2015 10:04 AM
Best H9 Bulb to replace '06 H11's? Beertinted 4th Gen T4Rs 11 10-17-2012 10:21 AM
so do I want to replace the bulb or the card..... kavalis 3rd gen T4Rs 0 08-05-2011 02:21 AM
replace bulb on 2001 4runner. little help plz. irdaniel Maintenance/Detailing 2 09-21-2010 08:00 PM
