Old 02-14-2021, 12:30 AM #16
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Originally Posted by MAST4R View Post
Many thanks for the heads up. I would not complain if my CVs last 90k, given how I use them.
I am thinking of picking up a 40$ 460 CV from a junk yard to have a trail spare. Rear drive shafts can be found for 75$ from a 4x4 SR5. I don't use my right foot much in rocks, but just in case. Tie rods are hard to get from a yard, btw.
The OEM takes a 35mm on a 5th gen, right?
I think itís the same for the GXs, 4th and 5th, and FJC.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 02:35 AM #17
Eltigreblanco Eltigreblanco is offline
Eltigreblanco is on a distinguished road
Just got a 2020. Hope it holds out as well
Eltigreblanco is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 03:04 AM #18
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Originally Posted by CutthroatSlam View Post
I do all the maintenance. Shocks, brake rotors and pads been the only major items. Learned that you must road force balance the tires from new or you will get the steering wheel shakes at 60 mph. Could have been the reason for replacing rotors I thought were warped. Use all non-OEM fluids. Oil change every 10K. Changed the differential and transfer case fluids twice now. Done one transmission flush and another is coming up.
That's nice and all, but you didn't have the peace of mind by changing the oil every 5K. Fail.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front, IMS59-50705 & C59-325 rear; Dobinsons diff drop; Ironman UCAs; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 03:51 AM #19
aggrobot aggrobot is offline
aggrobot is on a distinguished road
Originally Posted by bcolts View Post
Mileage update. My 2010 limited just turned 255,000 miles. So far four tires, two batteries, a windshield, set of brake pads, one wheel bearing and normal oil changes and thatís it. Iím hoping at least to get 300,000 out of it. (Although I probably jinxed myself by bragging.Ö)
In fairness, I bought the truck with 138,000 miles on it, so that 255,000 is not all me. But according to the dealers records, the previous owner had only done standard maintenance when he got rid of it.
Great to hear! No xreas replacement/issues? Thank you for sharing!
aggrobot is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 10:24 AM #20
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has a spectacular aura about CutthroatSlam has a spectacular aura about CutthroatSlam has a spectacular aura about
SR5, does not have XREAS
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 10:25 AM #21
You wouldnít believe how much sleep I lost over this.
Old 02-14-2021, 10:44 AM #22
Originally Posted by LandCruiser View Post
Boots were fine, the innards were shredded on the driverís side and it was rumbling and grumbling.
I decided to replace both of them, the passenger side didnít look that bad but since I had the whole truck apartÖ
You must be doing more extreme off-roading.
Old 02-14-2021, 12:10 PM #23
Yes, I realize that but if you look at who Iím actually quoting, youíll see itís someone with a limited.
Old 02-14-2021, 12:40 PM #24
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is just really nice Jivewalker is just really nice Jivewalker is just really nice Jivewalker is just really nice Jivewalker is just really nice
Jivewalker's Avatar
Congrats! I'm at 215k now. I started changing my oil every 5k around 120k after I found the PCV and OCV screens with some sludge. Pretty sure it was caused by long idles in extreme heat but been doing 5k OCI ever since in case sludge was elsewhere. So far so good with a solid 19.3mpg.
2012 TE KDSS | Black| 265/70R17 C KO2's | 217,000 miles |Link To Inside Fishing Rod Holder Mod
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 04:30 PM #25
Sorry, posting on an iPhone and did not see that.
Old 02-14-2021, 04:50 PM #26
bcolts bcolts is offline
bcolts is on a distinguished road
This Is actually my second 4Runner. The first was a 2003 sport model that when I traded it on this one had hit 273,000 miles, and the only reason I got rid of it was the AC went up and was going to cost $3500 to fix. Both had/have the XREAS system and neither failed. And again, I know I am tempting fate to say that!
bcolts is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 09:34 PM #27
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
nice. I've had my TRD ORP a little over a year now and just hit 38k.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 09:54 PM #28
Ive read a number of posts that frame the situation like XREAS failure should be expected anywhere between 60K and 150K miles, that inevitable, expensive, and best to just rip and replace. Iím happy to hear thats not necessarily the case.
Old 02-14-2021, 10:20 PM #29
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough
67k when it failed for me
NB17Limited is offline   Reply With QuoteReply With Quote
250k , approaching , great , odometer , truck
Approaching 200,000 miles planeboy95 Maintenance/Detailing 14 03-26-2020 05:58 AM
Approaching 200k - the good, the bad and the ugly: Jan777 4th Gen T4Rs 6 02-11-2020 04:47 PM
Approaching 137,000 miles 4dailyRunner 4th Gen T4Rs 16 05-15-2012 05:27 PM
Suspension swap day is approaching, have ?? PWGUNNY Engines / Suspension / Wheels / Tires / Audio / Accessories 0 09-22-2010 09:10 AM
Approaching 50,000 miles......any maintainence suggestions? arouth 4th Gen T4Rs 2 10-26-2006 07:45 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
