Old 02-14-2021, 10:47 AM #1
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Question What's acting different when in drive...?
So when I'm in park there's no squeal. But when I put in drive something in the engine is squealing. I tested it with holding the break pedal as well:
Park, brake - no squeal
Park, no brake - no squeal
Park, rev up engine - no squeal
Drive, brake - squeal
Drive, no brake - squeal
Is there a certain belt that is moving when in drive and not moving when in park? My initial thought was a belt. Does something in the suspension system cause this typically?
Clearly there's something different going on when in drive and when in park.
Almost 20K miles.
umidkusername is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 11:01 AM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
In drive you now have a little more load on the engine. I'd look at the easy stuff first - old belt, idler pulleys, etc.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 01:05 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Almost 20K miles.
Probably the serpentine belt. Try belt conditioner on it to see if it goes away. You still may need to replace the belt.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 01:16 PM #4
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Almost 20K miles.
With only 20K miles I assume your under warranty? I'd take it to the dealer and let them figure it out
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 01:24 PM #5
KingPrat's Avatar
KingPrat KingPrat is offline
KingPrat will become famous soon enough
KingPrat's Avatar
Strange that you have a squeal at 20k. Def bring it to the dealer.
When you're in drive and foot on the brake your RPMs drop a bit with the transmission engaged, so could be the belt or tensioner that has prematurely worn out.
Does it increase with RPM and disappear? Or continue?
Is it definitely coming from the engine?
My other thought: is your Defroster on? Could be AC pulley.
Could also be drivetrain-related. Been in 4wd recently? Not fully disengaged?
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
KingPrat is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 11:10 PM #6
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
Does the noise occur in reverse as well? Sounds like maybe a transmission pump making noise?? Common denominator is while in gear, in my experience a belt noise is more consistent with load on the drive belt (ie. turning A/C on) or change in RPM, I guess if a pulley is dragging that slight drop in RPM when in gear could make a difference?
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 11:19 PM #7
spartacus's Avatar
spartacus's Avatar
Not sure about your squeal but the 5th gens have a common brake squeal issue.
Old 02-20-2021, 11:16 AM #8
So went in for service today. All the pulleys, belts looked good. Brakes were good as well. They did take a video and have to send it into Toyota because I made a complaint and it's still under warranty. I would imagine that's a good thing right? Because I told them something is wrong, they can't find anything wrong. The squeal is fairly apparent and it was even louder today when I started up the 4runner, temp around 35 F or so.
Anything else I can check?
belt , brake , drive , park , squeal
New Body ECU already acting up? Or... jross20 3rd gen T4Rs 15 06-09-2020 11:38 AM
Tell me it ain't so....trans acting up. Mudeprived 3rd gen T4Rs 9 03-12-2018 09:04 AM
98 transmission acting up. Black798 3rd gen T4Rs 5 06-13-2016 05:40 PM
TRD supercharger acting up falvare2 3rd gen T4Rs 9 12-11-2012 09:24 PM
