Old 02-15-2021, 06:34 PM #1
Vermonster76 Vermonster76 is offline
Real Name: Justin
Vermonster76 is on a distinguished road
Real Name: Justin
Front suspension question
Over the weekend my neighbor and I installed a Fox 2.5 DSC suspension front and rear with Eibach 1in springs and Icon DJ UCA’s.
There’s a total of 2.5in lift in the front and according to Acutune with that amount and the 1in springs it would be level.
So here’s my question, the front is noticeably higher than the rear. Does it need to settle after a few weeks or should we get back in there and adjust height.
Thanks!
92' 4Runner SR5, Manual, Work Truck, Still Kicking
02' 4Runner SR5 Sport: SOLD
15' 4Runner Trail Premium w/KDSS
08' Audi S4 Avant, Imola yellow: SOLD
15' VW GTI
Vermonster76 is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 06:50 PM #2
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
I would drive it for at least a week after a fresh install before making any height adjustment as both front and rear should settle, I would at least dial in the alignment as best as you can for now.
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 10:14 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Thanks!
so I’m guessing you didn’t change the rear springs or add any spacer. Did you measure the fronts and rears before and after addingthe front coil overs ?
Normally stock height is 20” fronts and 22” rears. So if you added 2.5” Coilovers, you should be at 22.5. That should make the fronts leveled with the rears. Usually 1/2” (22.5”) extra is needed to make it level to the rears.
Let’s see some side profiles
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 12:06 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
It has been my experience that what is advertised is not always what you get. For example, I put in the Rough Country leveling kit (spacers) that is supposed to lift the front 2" and the rear 1", but it ended up more like 2.5" front (and 1" rear). Since with spacers the original springs, shocks, and struts are used, there is nothing to settle.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 01:28 AM #5
acidrane acidrane is offline
acidrane will become famous soon enough
I did a 1.7" front lift (bilstein) and added 1" rear coils and kept the same front rake as stock, just higher. Initially everything was 2/1.5" higher but then it settled down a bit.
2020 TRD Off-Road Premium w/KDSS | Nautical Blue | TRD Cold-Air Intake | MagnaFlow Exhaust | LASfit LED Lights | TRD Pro Grille | FNWheels Countersteer Type X | BFGoodrich K02 275/70 | Bilstein 6112/5160 w/Eibach 1" Springs | Dobinsons UCA | WeatherTech Window Deflectors | C4Fab Sliders | C4Fab Ladder | Sherpa Crestone | Ironman 4x4 Awning
acidrane is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 01:42 AM #6
Real Name: Justin
Real Name: Justin
I’ll get some photos up tomorrow.
I did change the rear springs to 1in Eibach at the recommendation of Accutune.
Went down some rutted roads today to help settle them a bit. Anyway, photos up tomorrow.
15' VW GTI
Old 02-16-2021, 02:10 AM #7
Pictures and measurements is what I usually do. I measure from hub to fender and also fender to ground.
Today I adjusted my passenger side preload from 10 turns to 7 turns and achieved ~23.5 (~38.5”.). Drivers side is ~23.75” (38.75”) without me in the truck.
This is my third time adjusting the heights since installing them. I waited about two weeks to let it settle.
Old 02-16-2021, 02:07 PM #8
Real Name: Justin
Real Name: Justin
Here are the side profiles. It feels like it just has to settle a bit but I could be wrong
Front suspension question-49e1593d-e2c3-41a7-84c8-4512b4ec14a1-jpeg  Front suspension question-eecfb15c-a005-4a9f-8689-93fb3d83bedc-jpeg  Front suspension question-8ad6ec6b-a96e-4c25-8efa-58b30a4ba5b9-jpeg  Front suspension question-9c492e91-00da-4a6a-a824-8fa3ba5892f7-jpeg
15' VW GTI
Old 02-16-2021, 02:20 PM #9
Spyder4runner's Avatar
Spyder4runner Spyder4runner is offline
Spyder4runner will become famous soon enough
I have the same setup from Accutune, and yes it will settle after 500 miles or so. From your pictures it looks like it’ll settle evenly.
Spyder4runner is offline   Reply With QuoteReply With Quote
Old 02-16-2021, 02:46 PM #10
Jmatroni Jmatroni is offline
Jmatroni is on a distinguished road
Looks great
Jmatroni is offline   Reply With QuoteReply With Quote
1in , front , rear , springs , suspension
front suspension question part #'s 3bears 3rd gen T4Rs 3 05-01-2018 02:23 PM
Quick Front Suspension Question 4Runner4TW 3rd gen T4Rs 10 10-15-2015 03:05 PM
Front suspension question Bigmd 3rd gen T4Rs 5 10-20-2014 07:03 PM
Question on front suspension hayk 4th Gen T4Rs 0 05-18-2009 10:30 AM
