Yes, these are the two comparable to stock rates. The Bilstein 1" rear spring (part number on the Bilstein website) is stock spring rate as is their 1.5" spring.
The Eibach 1" is about 10% stiffer than stock. The Wheelers T13 1.5" is a tad softer than the Eibach. I have the Eibach 1" and my actual lift is more like 0.75" and 0.5" or less with typical weight, which is not much.
All these springs are made by Eibach, I think.
I must say that front springs also impact the rear and I think they do so diagonally. So stiffer front springs (I run 650lb) seem to impact the rear height more than softer ones (I have had 4 different sets of front springs). When I corrected the factory front driver lean (non-KDSS), the front became nearly perfectly level but the rear pax side lost an equivalent amount of about 1/4 in.
So 1" is going to be an approximate number.
