It's not bigger than the opening, but once it is on, there isn't enough room to get your hand or a tool around the (then recessed) cap to remove and drain. You could potentially leave the cap off and just rely on the exposed, spring loaded ball valve, but I'm not comfortable with that.
I agree that RCI made that hole unnecessarily small.
I plan to fool around with it a little more on my next oil change. I didn't spend too much time once I saw it was such a tight fit.
