Old 02-17-2021, 01:28 PM #1
Gstick Gstick is offline
Gstick will become famous soon enough
Heater fan switch
My heater fan would not work this morning. I figured that it was a blown fuse, but after I got to my destination & re-started the engine, turned on the fan switch, then it worked as normal. Any ideas why it wouldn't work intially ?
There is only 17000 miles on this 2019 TRD OR, and this is the first of anything wrong.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 11:23 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Manual or climate control system? Most likely a loose connection. Could be corrosion on the switch contacts or one of the resistors in the resistor pack (controls the fan motor speed) going bad. Hard to trouble shoot unless the problem is constant.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 04:22 PM #3
Manual.
Old 02-18-2021, 07:37 PM #4
4Runnergenius 4Runnergenius is offline
Real Name: Chris
4Runnergenius is on a distinguished road
Real Name: Chris
i had a similar issue before turns out the fuse was kaput so i had to get a new one (Toyota Parts - Genuine OEM Toyota Parts and Accessories Online i just had to put in my vin and got a good deal.) problem was solved as soon as i put the new fuse in. im glad it wasnt something else that required some sort of overhaul.
4Runnergenius is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 10:49 PM #5
I don't know how my fuse could be blown, because it started to work again.
Old 02-19-2021, 12:04 PM #6
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
I have had a couple instances where I have started the truck and noticed the heat wasn't working even though the fan speed dial was turned on. When I move the dial it then kicks on. Did you try adjusting the control dial when you noticed it wasn't working?
This has happened so infrequently that I haven't bothered looking for a fix as it has always kicked on when I adjusted the fan speed dial.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 02-19-2021, 12:55 PM #7
If you mean the Temperature control dial, no I hadn't tried to adjust it. But if it happens again, I will try that.
Old 02-19-2021, 01:13 PM #8
Real Name: Doug
Real Name: Doug
No, the Fan Speed dial. The dial on the left in the image below. (Picture pulled from Google).
I would just adjust that when it wouldn't turn on and it eventually would kick on.
Old 02-19-2021, 08:31 PM #9
Yes, I was moving the fan dial "left to right" then back, but it didn't do anything. Meaning that the fan never came on anywhere on the dial movement.
Old 02-20-2021, 01:21 AM #10
mostapo mostapo is offline
Real Name: 2014 TEP, Bilstein 5100's all around set at 2.5 up front, 275/70/17 Falken WP
mostapo is on a distinguished road
Had a similar issue on my 2014 orp. Didn't turn on one cold morning until 30 minutes later after restarting the motor. Replaced the blower (10 minutes and 3 fasteners) never had the issue again. Found it on rockauto for $60 or so. I've read they're pretty unreliable blowers.
mostapo is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 07:57 PM #11
Very interesting, I've never heard about the unreliable blowers. But, its still under warranty so I'm sure that if it happens again, it will be taken care of.
fan , heater , ideas , switch , work
WTB: 01-02 Seat Heater Switch J3FF3RSON Want to Buy/Trade 0 02-13-2014 03:04 AM
heater fan switch melt jeb Classic T4Rs 3 02-24-2013 10:25 PM
Rear Heater Switch? 4Evr4RunN3R 3rd gen T4Rs 6 02-17-2013 11:43 PM
a/c heater control switch 4runnn Problems & Warranty Issues 1 10-16-2010 02:13 PM
COLD & HOT a/c & heater switch K_Labs Classic T4Rs 0 02-19-2008 04:47 PM
