Old 02-17-2021, 04:31 PM #1
fastcat27 fastcat27 is offline
fastcat27 is on a distinguished road
Drop in Primary Battery
Is there a Napa or advanced battery that's bigger that i can just drop in without spending on an Optima or needing to lift the battery? I tried to read all the threads and i'm more confused now than when i started. =)
Thanks!
Thanks,
Darrell
2022 SR5 4X4
fastcat27 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 05:36 PM #2
Chilow Chilow is offline
Chilow will become famous soon enough
Lead or AGM battery? Most people here upgrade to AGM, but you need to keep in mind these batteries require more voltage to stay healthy; thus also adding a voltage booster.
A popular option is the slightly larger 27F size, but I believe that requires a battery tray from the 4th gen 4Runners. If you want to step up to Group 31 or larger, you have to factor in additional costs of getting a beefy battery cage and still risk cracking fender.
Are you just needing more capacity? I personally went for an AGM Northstar battery in the same stock size paired with a voltage booster. Didn't have to buy a battery tray, worry about cracking my fender and it dropped right in.
Chilow is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 08:28 PM #3
pcstockton pcstockton is offline
pcstockton is on a distinguished road
A 27F drops right in without the need for any trays. I took out the stock tray and dropped it in!
pcstockton is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 12:31 PM #4
aabottom aabottom is offline
aabottom is on a distinguished road
My 2016 SR5 is now a Die Hard machine. I installed it's 1st battery.
Die Hard GOLD 24F-6.
750 Cold Cranking Amp baby.
Original tray and battery clamps fit perfectly for the install. Now it starts like a champ.
2016 Toyota 4Runner SR5 Premium 4WD Sliver
R.I.P.: 1999 Toyota 4Runner SR5 4WD V6 5Speed_Manual Red
aabottom is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 01:35 PM #5
mrbrenan's Avatar
mrbrenan mrbrenan is offline
official vendor
Real Name: Brenan
mrbrenan is on a distinguished road
official vendor
mrbrenan's Avatar
Real Name: Brenan
Originally Posted by Chilow View Post
A popular option is the slightly larger 27F size, but I believe that requires a battery tray from the 4th gen 4Runners. If you want to step up to Group 31 or larger, you have to factor in the additional costs of getting a beefy battery cage and still risk cracking fender.
Yeah, running a 27F here. No spacer is needed for the Northstar or the X2 Power (another really popular 27F battery). There is no need to lift the group 27s, same for the 31s but for the 31s you may need to extend out your terminals as the terminal placement is on the outside closer to your headlights.
To the OP:
The "drop-in" battery you want to look at is the Northstar Group 27 and the XPower Group 27. You can also look at the Odyseey Group 34 but you will need to buy their riser bracket. The battery snaps right into it and then you drop it in. Those are both straight swap drop-in batteries. I have run both batteries but I really like the Northstar Group 27 as it has higher rated CCAs and Ah, although it does weigh a bit more than the Group 34 (68lbs vs. 51lbs).
Read more here:
NorthStar Group 27F Vs. X2Power 27 Group Vs. Odyssey Group 34R
My 4Runners; 1999 SR5 4WD Jade Green, 2014 TEP KDSS White, 2016 SR5P White, 2016 TEP KDSS MGM (Jade) and 2023 SR5P on Portal Axles.
Trail 4Runner (5th Gen 4Runner Mods):Trail4R.com
6th Gen 4Runner Mods
https://6g4r.com/
mrbrenan is offline   Reply With QuoteReply With Quote
Old 08-04-2021, 02:48 PM #6
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
Ac delco agm 27f dropped right in 150 shipped eBay excellent
Mudballz is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 10:08 AM #7
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I got a 34 Odyssey battery which works great, buying a $5 spacer bracket isn't the end of the world, it snaps right on, shoot my last Odyssey came with the bracket so I had an extra one
Old 08-05-2021, 03:58 PM #8
curmudge1 curmudge1 is offline
Real Name: Dave
curmudge1 is on a distinguished road
Real Name: Dave
I bought a Sears AGM Die Hard in 2016, no voltage booster, it seems fine. Probably going to test & maybe replace, after 5 years.
it was a Gold AGM EP-34R, it dropped in just fine. As I recall, it had a bit more juice than the stock size battery.
Guess you would need to get one at Advance Auto parts now.
YMMV.
curmudge1 is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 04:56 PM #9
bcbud bcbud is offline
bcbud is on a distinguished road
Mudballz, do you have the model number of the Acdelco 27F battery
bcbud is offline   Reply With QuoteReply With Quote
Old 08-05-2021, 05:05 PM #10
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I put in a Napa Premium 24f this spring. It has about 200 more Cold cranking amps than the Panasonic.
Drop in Primary Battery-img_0678-jpg
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
battery , confused , drop , read , threads
WTB: 2003-05 OEM primary cat Bkt4runner Want to Buy/Trade 0 12-03-2019 06:12 PM
2016 Presidential Primary Poll scd969 Polls 11 04-07-2018 06:26 PM
FS: 3rd gen Toytec Panhard drop & 4th gen Diff. Drop & TPMS $45,$30,$45 VT schindlerslist For Sale: T4R Items 4 01-30-2015 06:33 PM
OME HD Primary Solution for Heavy Front? classic72 5th gen T4Rs 6 07-24-2014 07:12 PM
Primary Arms Multi-Reticle Red Dot & Primary Arms 3x Magnifier xskydivingdudex For Sale: Non-T4R Items 1 12-08-2012 03:21 PM
