Old 02-17-2021, 07:03 PM #1
orcking orcking is offline
orcking is on a distinguished road
Skid plates
I did lot of research on skid plates.
Most if not all of them have a drawback of small opening access for an oil pan access. I am planning on putting valvomax valve but it seems most will not be doable. The only one I liked that looked like it has enough access was the cbi. The one thing that I did not like about cbi is that you have to remove the radiator support brackets before you install the engine skid. I am not comfortable with that. Rci is great but lacks room on the oil drain access . Any one have experience can shed any light..
orcking is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 07:22 PM #2
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
Have planned on ordering a set of RCI skids myself so have no experience. Can you open up the drain section on the skid to allow more access?
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 07:28 PM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
The opening on an RCI skid will fit a average size hand. How is that not big enough?
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 07:29 PM #4
It looks much smaller than an average hand. Can you screw the darin valve for a valvomax oil drain?
Old 02-17-2021, 08:03 PM #5
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Hole size should be fine. Just about all the aftermarket skids you can fit your hand through the drain hole. Same for the filter hole. I know my RSG skid plates made it more than easy enough to put in a valve from Fumoto. Here's a pic for example. Would imagine everyone else is the same or damn near close.
Little off center looking due to my angle of taking the photo.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 08:04 PM #6
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I have the RCI and I have NO problem changing my oil. SO much better than it was taking the stock one off every time. And it didn't get mangled the first time I hit a rock either.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 08:27 PM #7
Thanks much for pic..
Do you have enough room for a torque wrench through the oil filter access door? It seems for rsg you also need to remove the radiator support brackets before you install the skid.
Can any one with rci skid please measure the diameter hole for oil pan or take pic.
Thanks
Old 02-17-2021, 08:43 PM #8
MaddoxPics's Avatar
MaddoxPics's Avatar
Thanks
If you are asking to put a torque wrench itself through, probably not, unless you slide it in at an angle and then do it with the handle on the inside. Seems like that would be a pain. I honestly never torque them down. I go old school with tight and then quarter turn. No issues ever with leaks.
Yes you'll remove the radiator support brackets. Real simple and easy to do.
Old 02-17-2021, 09:04 PM #9
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Orcking, since you and I were the only ones in your other thread, I would be seeking additional input as well.
I just got under my rig and took some measurements for you. The access hole in the RCI skid is just shy of 2.5" diameter. The important dimension for the Valvomax unit is actually the knurled screw in fitting on the drain attachment that compresses the ball valve for draining oil. It is larger in diameter than the unit itself an its removable cap. That drain fitting measures just over 1.5" diameter.
That leaves you roughly 1/2" clearance around the perimeter to work with. My thumb is 1" in diameter and my index finger is 3/4" diameter. As I mentioned yesterday, it's very tight. I plan to mess around with it on my next change as I also have the higher flow Fumoto on standby to replace the older one anyway. There may be enough vertical clearance once it's fished up there for room to work with. I won't know the stack-ups until I try to install it. Not due for oil until July though.
I hope this helps.
5thToy is offline   Reply With QuoteReply With Quote
Old 02-17-2021, 09:15 PM #10
I hope this helps.
Thanks 5thtoy
Keep me posted of your findings
I will hold off on the skid for now...
Old 02-17-2021, 09:20 PM #11
Thanks 5thtoy
It wouldn't sway me away from the RCI skids personally. They are great. I'm fine with the Fumoto even though I'd prefer to use the Valveomax.
Old 02-17-2021, 11:18 PM #12
Gstick Gstick is offline
Gstick will become famous soon enough
I guess that I am just old school but I have the RCI skid with front filler cover & I loosen the 2 bolts on the ff cover, then take out the 4 bolts dropping the skid and then do the oil change. I figure if I were to leave the skid on, I would have oil splash all over the under carridge.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 12:15 AM #13
I use the JDT filter drain hose tool (performs the same function of opening the cartridge drain valve as the plastic insert that comes with the factory filter, but with an attached hose and drip free). Combined with the Fumoto valve nipple and hose for the pan = clean oil change. RCI engine and trans skids overlap and share mounting bolts with spacers.
I prefer to take advantage of access provided so I don't have to mess with skids. It's one of the perks of ditching factory skids.
Old 02-18-2021, 08:41 AM #14
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
I’ve been looking at the Budbuilt skids. They have an option now to have an armored door at the oil drain location. Only problem is that it’s a $95 upgrade.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 11:53 AM #15
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I like this new wide coverage style from C4. 4Runner Full Skid Plates / 5th Gen / 2010+ - C4 Fabrication
TRD PANTHER is offline   Reply With QuoteReply With Quote
access , cbi , oil , plates , skid
Painted Stock Skid Plates (Bash Plates) AggieOE 5th gen T4Rs 0 07-09-2020 09:47 AM
FREE 2017 OEM Skid Engine Skid Plates, Lakewood CA choochoo Free 1 11-04-2019 02:07 PM
Trd skid plate (kdss) plus rci Control arm skid plates barcainho 5th gen T4Rs 8 12-06-2017 04:30 PM
5th gen; RCI full skid plates/fuel tank skid LOCAL ONLY (LOS ANGELES) madlib For Sale: T4R Items 3 02-27-2017 03:58 PM
Skid row 3 front skid plates cheap! spitvenom For Sale: T4R Items 13 08-21-2012 09:47 AM
