Old 02-18-2021, 10:44 AM #1
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
2020 vs 2021 Pro FOX shocks, REAR
I know Toyota says they revalved the fox pro suspension for 2021. The fronts are different for sure. my fronts are being replaced under warranty TSB with 2021 parts ( i have a 2020).
My question is..
Are the rears a different part number 2020 vs 2021? or did only the fronts change?
I would think it would be reasonable to ask Toyota to replace the rears if they are different as different tuning may affect performance. I would ask the dealer, but it took them four tries to figure this out(even though there was a TSB on it).
lewdog998 is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 11:04 AM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Its reasonable to ask. I don't think the rear shocks are different. The front re-valve solved a cold weather clunking problem. The rears didnt have that issue.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 12:39 PM #3
Whippersnapper02's Avatar
It's the same shocks all around since they first came out on the Pro Bro. The only difference in the front is may an internal soft stop to keep the noise down.
Old 02-18-2021, 01:46 PM #4
Rainier42's Avatar
Rainier42 Rainier42 is offline
Rainier42 is on a distinguished road
Rainier42's Avatar
Front springs are also different.
2020 Silver 4Runner Venture w/KDSS, sliding cargo tray, Falken WildPeak A/T3W 265/70R17 tires
Rainier42 is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 01:49 PM #5
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
How can Toyota keep messing this up when people have been installing lifts on their fifth generation since they came out with minimal problems?
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 01:55 PM #6
Didn't know that. If they went up in spring rate then people will say it rides too rough.
Old 02-18-2021, 02:10 PM #7
Rainier42's Avatar
Rainier42's Avatar
I don't know if spring rate is different, the springs are cut different. Somewhere here is a thread showing the difference between the 2021 TRD Pro fronts and earlier ones.
Old 02-18-2021, 02:28 PM #8
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
This is nothing compared to all the documented issues (and denial thereof...) Ford has had with the MT-82 transmission in the Mustang since it was introduced for 2011.
I'd much rather have a noisy shock than bent shift forks, broken shifters, missed shifts from lockout, clutch slipping, etc, all on a stock car.
Muff Muff is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 04:45 PM #9
edgesalon's Avatar
edgesalon edgesalon is offline
edgesalon is on a distinguished road
edgesalon's Avatar
The front springs are open coil not closed coil meaning the coils at the bottom end are farther apart and a different bottom perch also to accommodate the new springs
18 FunRunner
edgesalon is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 05:02 PM #10
lewdog998's Avatar
lewdog998's Avatar
That is correct (about the spring type)
as far as spring rate or valving, somewhere I have heard that the valving has been changed (retuned dampers that Toyota says are intended to improve isolation during trail driving....according to a Car and Driver article)
Not sure if that covers rears as well. Anyways, thought I might be able to score some new rear shocks too (if they are different) If not, no big deal.
I will probably go the dealer parts counter and figure it out...after they reopen from the big snowpacolypse.
Old 02-18-2021, 05:13 PM #11
jamoc jamoc is offline
Real Name: DeLo
jamoc is on a distinguished road
Real Name: DeLo
Why is toyota replacing your fronts under warranty? Whole assembly, or just shocks?
jamoc is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 07:00 PM #12
lewdog998's Avatar
lewdog998's Avatar
See this TSB
https://static.nhtsa.gov/odi/tsbs/20...81779-9999.pdf
Whole assembly....initially I was going to have the dealer place the eibach springs while he had it apart...But they said they were not breaking them down, they were replacing whole coil-over.
Old 02-18-2021, 07:27 PM #13
mmike87 mmike87 is offline
mmike87 is on a distinguished road
I lived that! Crap made in China transmission.
Sent from my SM-N986U using Tapatalk
mmike87 is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 01:11 PM #14
Real Name: DeLo
Real Name: DeLo
See this TSB
Thank you -- I appreciate the link!
Old 02-20-2021, 08:58 PM #15
Muff Muff's Avatar
Muff Muff's Avatar
Same here. One time, I got locked out of a 1-2 shift, and the clutch slipped like a mofo. That's the moment I knew I had to get out of that car.
fronts , pro , rears , toyota , tsb
Going from 2020 to 2021... umidkusername 5th gen T4Rs 35 04-04-2021 09:25 AM
Ignition Tap for Switch Pros 9100 on 2020/2021? FourT6and2 5th gen T4Rs 1 03-10-2021 06:58 PM
FS: 5th Gen / 2020-2021 Toyota 4Runner Grill Saker For Sale: T4R Items 0 11-25-2020 08:38 AM
FS:2010-2020 5th Gen Toyota 4Runner TRD Off Road Front And Rear Shocks Springs Shipped Snohomish Wa SOLD 3RDGENGuy For Sale: Suspension/Wheels/Tires 5 09-07-2020 11:56 AM
TRD Pro Fox shocks (2020 4Runner) point1 For Sale: Suspension/Wheels/Tires 3 08-11-2020 07:18 PM
