Old 02-21-2021, 09:19 AM #1
carfac's Avatar
carfac carfac is offline
carfac is on a distinguished road
carfac's Avatar
2018 wont go above 2500 rpm
So Im up in Yosemite (on road!) and I left my lights on last night. I used a self-start jumper to get it going, and that must have messed something up.... Engine light on, TRAC light on, and it will not go above 2500, or about 1500 in drive. So it only goes 8 MPH.
ANy idea what I did, how I can fix it in Yosemite?
carfac is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 09:30 AM #2
ATX14 ATX14 is offline
ATX14 will become famous soon enough
I don’t have a specific answer but if you think your 4R battery is strong enough, I would disconnect the negative battery terminal for 10-15 minutes and see if the electronics reset its self. Kind of a reboot for the electrical system.
2017 T4R TRD Off-Road Premium, Metallic Gray, CBI Off-road steel bumper, CBI Aluminum Skid Plates, Smitty Built 10k winch, Fox 2.5 DSC/remote reservoir w/ Eibach 700# front coil spring replacement, Icon 2" rear coil springs with Sumo Springs, Prinsu Roof Rack, Rago Fab. Window Storage Panels, Method Wheels 285/70/17 BF Goodrich KO2.
ATX14 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 10:11 AM #3
a2marian's Avatar
a2marian a2marian is offline
a2marian is on a distinguished road
a2marian's Avatar
If I'm not mistaken, similar symptoms (limp mode) happened to Brenan (@Trail4r) from trail4runner.com.
Check out this link:
Limp Mode on 5th Gen 4Runner & Zero Point Calibration (SOLVED)
If you scroll down to final thoughts, it turns out the issue with his truck was a water leak that eventually corroded some connector pins behind the driver kick panel.
Best of luck!
2018 TRD Off-Road, KDSS, 285 KO2s C, 6112/5160 + B12 rear - 2.5"/1", 1.25" Spidertrax Spacers, Greenlane Off-Road Aluminum Sliders
a2marian is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 11:12 AM #4
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Do you have pedal commander or any other electrical accel control mod?
<<<< is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 11:22 AM #5
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Check your fuses. Some time it happens when people jump started cars and mixed up negative with positive. Most likely ECU fuse.
ax2021 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 11:33 AM #6
SteveH6779's Avatar
SteveH6779 SteveH6779 is offline
Real Name: Steve
SteveH6779 is on a distinguished road
SteveH6779's Avatar
Real Name: Steve
I have a 2017 SR5 with 80k miles and mine had the same thing happen yesterday except the battery wasn't dead. It gets up to speed slowly because it keeps shifting once it hits 2000 rpm. Going to try disconecting the battery to see if that helps
2017 SR5
N-Fab running boards
Tinted windows
Stage II Icon Suspension
17" Icon Rebound Wheels, BFG KO2
SteveH6779 is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 11:45 AM #7
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
As with anything that trips the dash lights...
Confirm your fuses are good. Kick panel and engine compartment. If all check out.. disconnect the battery for 10-30 minutes. That should reset those faults and be good togo. If not... hopefully you have a CEL and can get a co¹de pulled to see whats going on.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 12:03 PM #8
Relentlesskaizen Relentlesskaizen is offline
Relentlesskaizen is on a distinguished road
We see this at times on some other models (Lexus) check either the dc cut fuse or tcc fuse. Possibly ecu fuse but tcc and dc cut are the most common we see with this issue.
Relentlesskaizen is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 12:36 PM #9
carfac's Avatar
carfac's Avatar
AFter an hour is reset and seems to be OK,,,,
Old 02-21-2021, 12:39 PM #10
carfac's Avatar
carfac's Avatar
Sorry, Internet is SUPER slow here...
Yes, battery off for 1 hour reset sytstem and all is good!
THANK YOU ALL SO MUCH!!! I was freaking out!
Old 02-21-2021, 03:50 PM #11
Glad everything turned out ok! Safe travels!
drive , light , mph , trac , yosemite
2018 Wont Start after a wire shorted Waepek 5th gen T4Rs 12 12-19-2019 01:45 PM
Crawl4Christ 2018 - Disney, OK July 6-8 2018 hawkmanjr Off-Roading 0 05-20-2018 09:46 PM
Help Me Decide - 2018 Lexus GX or 2018 4Runner Limited SCTrojans General Discussions 61 04-11-2018 06:26 PM
rear window wont roll down and defrost wont work wanta4runner 3rd gen T4Rs 6 10-17-2016 05:14 AM
92 Four Runner Wont dies and wont start floridaboy6802 Problems & Warranty Issues 0 08-04-2010 10:24 PM
