Old 02-22-2021, 10:58 PM #16
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Originally Posted by sn_85 View Post
Complexity is your enemy and if electrical is not your strong suit then don't get a dual battery set up
I disagree. With YouTube having instructionals, even the off grid you recommended has an excellent YouTube video, even a caveman can do it. You literally just follow the given instructions.
umidkusername is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 11:26 PM #17
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
That's up to @Signal to decide. If he says he isn't confident enough to install it himself then that's up to him. It's not my choice to make. I only made the comment about complexity in reference to his electrical competence. It's one thing to install something correctly but another thing to be able to trouble shoot it and fix a problem in the field. You don't want any electrical gremlins and certainly don't want to short anything out and cause a fire.
I do agree with you though, instructions are dead simple enough anyone who can turn a wrench can install it. I installed most of my mods including the OGE kit and I can truly say pretty much everything you need to know is on this forum, youtube or instruction manual. Actually emailed Matt Carter, owner of OGE, on a weekend while installing the kit and he replied promptly. Also had an issue with a cracked battery tray and he sent me a replacement free of charge as well. OGE is definitely a standup company.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 11:47 PM #18
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport is a glorious beacon of light 4RunnerAquasport is a glorious beacon of light 4RunnerAquasport is a glorious beacon of light 4RunnerAquasport is a glorious beacon of light 4RunnerAquasport is a glorious beacon of light
Real Name: Brett
Adding a winch with several electrical accessories can be a deep rabbit hole. Power management, and not using multiple accessories at one time will also be a key factor.
One thing you might consider, whether or not you do a dual battery set up, is the big 3 cable upgrade. (Positive battery terminal to positive alternator terminal, Negative battery terminal to chassis ground, and engine ground to chassis ground)
This will help ensure your winch under heavy load situations is getting all the juice it needs.
Most winch sessions are short in duration and won't over tax your system, but having heavier cable and solid connections will help with that potential problem in the long run. Remembering to power all accessories down (radio, blower fan, lights, etc) during a winch session will be a must as well. A 300 amp draw for several minutes is not uncommon for a winch cycle.
I decided to go with a dual setup to be able to tie both batts together in these situations.
Keeping all your connections maintained is key also. Which reminds me I haven't gone through mine in quite awhile. Your abilities in these situations are only as good as your preparedness, and mine could leave me stranded right now, because of poor maintenance.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 09:42 AM #19
Signal Signal is offline
Signal will become famous soon enough Signal will become famous soon enough
I have no problem giving it a go. I just don't want to mess it up and have issues.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 11:27 AM #20
Jeremy556's Avatar
Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about Jeremy556 has a spectacular aura about
Jeremy556's Avatar
No, you don't need dual batteries.
Get a good deepcycle/starting battery like an Odyssey and a jump pack and you'll be fine. I have been running that setup for many years with a 12k winch, dual onboard air, fridge, etc.
IMO, simplicity and less weight far outweigh any extended run time from a secondary battery. My ARB, and I assume most/all 12v fridges will have a lot voltage shut off to prevent killing your battery, so as long as you drive it every couple of days or connect a charger, it works fine.
battery , dual , fridge , issues , stock
Dual Battery Vs. Portable Battery nick_rabbo 4th Gen T4Rs 27 03-06-2021 10:57 PM
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual Battery Planning, Dual Group 31s mikeySA 3rd gen T4Rs 10 11-04-2017 04:25 PM
Cheap Dual Battery, Battery! SirWilliamGoes General Discussions 21 05-30-2017 10:59 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
