I have a 2021 TRDORP with KDSS, Fifteen52 Turbomac HD wheels (17x8.5 0 offset), stock otherwise.
These are my first AT tires, I always had highway tires on all my vehicles prior.
EDIT: I went for another drive, alone this time (without the kids) and having reduced the pressure to 32 PSI (dealer had them at 35 which was too much). I really focused on driving dynamics again, reassessing acceleration, braking and comfort. Also tried to pay close attention to wobble and shake at high speed. Either I'm getting used to the tires or adjusting pressure solved a lot of issues.
They are good. They actually slightly rub on my passenger mud flap, but that's also due to the more aggressive wheel fitment. They are much bigger than stock however, certainly much wider.
They are slightly louder than the (highway) winter tires I had on the stock wheels since taking delivery in November 2020 (Bridgestone Blizzak DMV2, stock size SL load rating) at lower speeds, but barely louder (if at all) at highway speed.
The ride is slightly harsher and I do feel the added weight versus the "stock" setup in acceleration mostly, braking and cornering to a small extent, but not by much. I just feel like there is more inertia if that makes sense. The overall driving experience feels (very) slightly less refined and forgiving.
I feel like they may be more sensitive to the "grooves" worked in the road or the overall condition of the road if that makes sense. They tend to wander a bit more than less wide highway tires but it could also be due to the wheel width and offset, but it's likely a combination of both.
As for balance, I initially thought I felt a wobble but I can't anymore. I was just on the highway up to 80-85 mph going through turns, inclines and declines, and there was no wobble or shake.
They're definitely great in the rain. I drove in rain at near freezing temperatures and there was no slippage or hydroplaning.
I'll give them a bit more mileage to see what happens. The definitely feel A LOT better at 32 psi than 35.
I also realize, I've always driven sports/luxury cars and I am very sensitive to driving dynamics overall. Probably more so than most. It's all quite subtle, but I'm get used to the feeling already.
The wheels weigh 26 lb each so very similar or slightly lighter than stock, so it's not coming from there.
I have to give credit where it’s due, they do look great! Ok some pics:
