03-13-2021, 10:06 PM
#106
Originally Posted by Tuco S.
[snip]
Give 44 psi a try with your oem size KO2's to see if it gets rid of the vibration.
LOL, they've actually been behaving recently. But I still randomly get the steering wheel shimmy. I'll try 44 and see what it feels like.
03-13-2021, 10:18 PM
#107
I just got Yokohamas geolander G003 M/T's and love them. they even come with 45k mile warranty.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
03-14-2021, 05:17 PM
#108
Originally Posted by krhayes79
I had P rated Toyo OC ATII and ran those for 30k and they had plenty of time in the desert w/sharp rocks and they never had any issues.
I recently upgraded to bigger LT Falken AT3W as I got a smoken deal on them used. There is a significant difference in not only the look but the sound and feel. These are much louder on the road than the Toyo, but that is to be expected with a more aggressive sidewall. I can also "feel" the tread when driving slowly which I never noticed with the Toyo.
Overall, I am happy with both, just wish the Falkens were slightly quieter. One thing I was surprised with was I did not lose much, if any, MPGs when I switched to the bigger, heavier tire.
Did you do a C Load or E Load on the Falkens?
If the latter, I would expect a harsher, louder ride than your Toyos, and I’m also curious as to how the LT falkens compare in rain, icy roads, and light snow with the Toyos.
03-15-2021, 12:15 PM
#109
Real Name: Kelly
Real Name: Kelly
They are C load. After 1500 miles, the ride is getting better and the tires are starting to quiet down a little. The cupping (bought them used) is the other reason they have been so loud and that is wearing down as well.
So far, they have been fine in the rain. It actually has been raining here and I have not really had any issues. The back end slipped for a half sec during a turn, but that was on the first day of rain when the roads were still very slick, but otherwise they have been fine. No experience in the snow yet.
The Toyos performed very well in the snow. Took a few trips into the snow and had zero issues. Even pulled a few trucks out of the road as they were stuck in the snow.
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
03-15-2021, 03:08 PM
#110
We just got about 20” of wet, spring snow where I at. Yesterday there was 12-14” of snow when I went out to check on some folks. No hurry, no worry and the 235 80 17 Cooper AT3 LTs did just fine. Today with the melt it’s all 8-12” of heavy wet snow. Still not a problem, but any more (or if I were to go be more adventurous) and I’d be quick to chain up the rear.
2012 Trail Edition, Silver w/ KDSS, Shrock Works front bumper, warn M12,000 winch, RSG Rock Sliders, Full RCI AL Skids w/steel on gas tank, OME 888/889 springs and OME 90021 Nitrochargers, Camburg UCAs, 32” Cooper 235/80/17 LT on Trail wheels, 1.25” wheel spacers, LEDs inside and out.
05-19-2022, 04:30 PM
#111
Okay I have a tire question. A couple actually. Getting my first set of 285/70/17's. I have a 2011 SR5 RWD with the Eibach stage one lift. Hopefully they don't rub, or at least just hit the front where I can do the fender liner mod.
So, I was set on KO2's, but want the C load. I noticed they only come in Q speed rating now. I have been known to push it past 90 going down the highway. I think 99mph rating is a little low. True or am I just being paranoid?
Another choice is the Toyo AT3 that people have been mentioning in the thread. Again, C1 has a speed rating of Q. SL has a speed rating of T, but the max PSI is only 36 psi.
What do you, the people that know what they are talking about, suggest? Because I'm suffering from analysis paralysis big time.
And I just realized this tread is from 2021, so on top of all the above, I'm resurrecting an old ass thread.
05-19-2022, 04:56 PM
#112
99 mph is fine. you are in a 4Runner. no need to go into the triple digits. and that's coming from someone that use to love speed. get the tire for the conditions you drive in. if 99 mph is too slow for you, get a different car/truck.
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
05-19-2022, 05:39 PM
#113
Well speed limits in Texas are 85 in some areas. So going 90 is normal.
05-19-2022, 08:00 PM
#114
I get it. I lived in central CA and everyone cruises around 90 in the desert, and if it was empty I would be a little more spirited, but in the 4runner I would be a little more conservative. When I lived in VA, I would run snow tires on high hp cars and have a q speed rating. 100 mph comes up QUICK when you have 500+ hp in a small car. You decide what tire is right for you. Being 2WD, I think you could get away with whatever tire has the proper load rating you need and has a higher speed rating.
